Old 19th November 2016, 11:48   #40261  |  Link
ryrynz
ryrynz's Avatar
Do you have a "groundtruth" to compare to in any of your tests? Maybe an old SD encoding of some anime for which a Blu-Ray is now available?
For one I do, my settings including Avisynth actually produced a fairly similar image. Anyway I have a screenshot that kinda shows what I'm talking about.
Originally Posted by aufkrawall View Post
Yes, I got this too. Normally madVR causes just some electric buzzing and not this high "coil whine" sound, which is very strange.
It depends on the type of load required by the card, generally the harder it has to work the louder the whine. Best thing you can try and do to minimize it is try overclocking or just replace the card with one that doesn't do it.
Madshi,
http://screenshotcomparison.com/comparison/191145
This is with Lanczos 3 as second upscaler, normally I'd use Jinc but w/e, this kinda helps exacerbate the issues anyway..
This is just clean NNEDI3 64 vs NGU HQ SE1, SE2 is just too blurry to be used for any real comparison.
Originally Posted by Sunset1982 View Post
sadly, NGU high is still to much for my rx480.
That sucks, my 960 breezes through it, doesn't use much more performance than NNEDI3 64 neurons, extra few ms render time that's it =/
I've only tested 480 > 1080 though..
Old 19th November 2016, 11:48   #40262  |  Link
madshi
that was NGU only without any other renderstep using showrendertimes because everyone has different chroma scaler and stuff like that. didn't worked out...
FHD -> UHD normal rendertimes
NGU med 25-30 ms
nnedi64 32 ms
NGU high ~80-100ms
nnedi3 256 110ms
nnedi3 128 55ms
NGU med is about 10 ms faster now since i disabled showrenerstep and reset all settings. NGU high doesn't seem to care.
Still far from what you should get. I don't suppose it helps if you switch the first flush setting "after intermediate render steps" to "don't flush", does it? Does turning on/off "use D3D11 for presentation" or "use separate device for presentation" make any noticeable difference at all?
Old 19th November 2016, 11:52   #40263  |  Link
madshi
ok, had showrendersteps activated too.
Performance is a bit better now:
can use NGU med with chroma and luma. 30ms
choma reconstruction soft and double luma with NGU med: 23ms
choma reconstruction soft and double luma with NGU high: 59ms
As I said (multiple times now). The performance by itself doesn't matter. I need NNEDI3 comparison, otherwise there's no reference point to compare to.
That looks pretty ugly. I don't really see an issue with lines being too thin here, though. What I do see is that NGU hates compression artifacts. But I suppose you'll probably get somewhat similar results when using NNEDI3 + SuperRes 4?
Old 19th November 2016, 11:57   #40264  |  Link
"don't flush" no change.
"use separate device for presentation" no change
using D3D9 present in advance with FSE instead of D3D11 gave me maybe an 1 ms but NGU rendertimes are unstable anyway.
Old 19th November 2016, 12:00   #40265  |  Link
ryrynz
ryrynz's Avatar
There's an O on his helmet, looking at the top line of that right in the middle you can see NGU really thinning that area far more than it should.
SuperRes4 looks even nastier but then it doesn't thin the lines, naturally.
So you could see why I'd prefer NNEDI3, after Awarpsharp etc has taken care of it I get a very nice sharp & clean image.
Old 19th November 2016, 12:05   #40266  |  Link
Sunset1982
some quick tests:
Chroma & Luma doubling both @ NGU med: 32ms
Chroma & Luma doubling both @ NGU high: 79 ms
Chroma & Luma doubling both @ NNEDI32: 25 ms
Chroma & Luma doubling both @ NNEDI64: 36ms
Chroma @ NGU med & Luma doubling @ NGU High: 60ms
luma & Chroma doubling set to NGU high (luma) and NGU med: 78 ms
So, still NGU high is no option on rx480 yet.
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 19th November 2016, 12:13   #40267  |  Link
ryrynz
ryrynz's Avatar
some quick tests
I wouldn't even bother with chroma doubling with this in it's current state, but that's me.. not sure if it'll make enough of a change in performance for you to run it. But like madshi said, there isn't a huge visual difference between medium and high. But I guess you're just testing rather than anything else..
Old 19th November 2016, 12:20   #40268  |  Link
madshi
I see what you mean. However, why is that part of the O gray in the source and not black, like the rest of the O? If the whole O had the same line thickness and line color in the source, NGU wouldn't "focus" some parts of the O but not others.
In order to properly upscale low-res images to hi-res in a way to get as near to the groundtruth as possible, NGU needs to decide which lines in the source were likely bloated through downscaling and were much thinner in the original hi-res image, and which lines were already thick in the hi-res source. NGU can't just thin all lines by a certain factor (as awarpsharp does). While that might produce pleasing results for very low quality anime sources with high compression artifacts, it would produce results very far from the groundtruth for high quality sources.
That's "good" to hear. So it's really mostly caused by the bad source quality. I think what you need most of all is a good algorithm to remove compression artifacts.
some quick tests:
Ok, so no joy with the RX480, for some weird reason.
I'll try my luck with D3D11 shaders, maybe that solves the issue.
Old 19th November 2016, 12:23   #40269  |  Link
well maybe wait for a working RX 480 driver...
i would down grade to a better driver but i can't remember a driver that doesn't have serious issues and is working with the RX 480.
Old 19th November 2016, 12:26   #40270  |  Link
AndreaMG
AndreaMG's Avatar
"install.bat" hangs
@Madshi Windows1064bit latest and gtx970 here, "install.bat" hangs and won't install, never had such problems before.
Raven RVZ01 * i7-4790k * 16GB RAM * Zotac GTX 970 4G * SSD 850Evo 500GB * Blu-Ray Burner Slot-In * PSU SFX 80+ Gold 450Watt * Windows 10 64bit * MPCHC+MadVR+SVP * Panasonic 50" VT30 ^^
AndreaMG is offline   Reply With Quote
Old 19th November 2016, 12:27   #40271  |  Link
ryrynz
ryrynz's Avatar
Yeah, I understand. NGU isn't tailored to this sort of content and NNEDI3 does particularly well here. If you ever did another version of this that went a little less towards ground truth then I'd give it a shot, this sort of content needs something a little less aggressive with it's line prediction.
That would certainly help, I could take care of this in my script but that wouldn't solve my main contention with this.
Old 19th November 2016, 12:45   #40272  |  Link
madshi
Here's a test build for those of you who still have problems with keyboard shortcuts and NGU not working:
http://madshi.net/madVR91c.rar
Installation instructions:
1) Make sure you're in release mode.
2) Overwrite the files.
3) Activate debug mode.
4) Create a short log file and upload it somewhere for me to look at (don't attach to this forum).
Old 19th November 2016, 13:04   #40273  |  Link
Sunset1982
I'm ready to do some tests. Let me know if I can do some testing for you.
They bring new beta drivers every week atm, but sadly just optimized for new games instead of bringing a bug free fro multimedia use.
Old 19th November 2016, 13:29   #40274  |  Link
wanezhiling
same here
win10 14393 64-bit
Old 19th November 2016, 13:38   #40275  |  Link
chros
chros's Avatar
I don't have time right now to try this, but 0.91b doesn't work for me either (keyboard shortcut). 0.90.24 doesn't have this issue. (Optimus system.)
Thanks for the new version!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz)
Old 19th November 2016, 13:44   #40276  |  Link
MariaX9
Originally Posted by MariaX9 View Post
Performance:
R9 GPU
chroma and image doubling NGU High: 20s
chroma and image doubling NNedi 64: 22s
I did a reset of the Settings and the NGU High render time lowered to 18s with the same Settings as before. Dont know why, but the IQ look better now as before IMO.
MariaX9 is offline   Reply With Quote
Old 19th November 2016, 13:54   #40277  |  Link
madshi
It's not supposed to work. It's supposed to create a log file with information that might help me figure out why it's not working...
Old 19th November 2016, 14:01   #40278  |  Link
Thunderbolt8
3) NGU is currently available for both doubling and chroma upscaling. The chroma upscaling algo does currently not make use of the luma channel. I plan to try adding that to a future NGU version, but that will take serious development time, so don't expect it too soon.
what does this mean specifically when watching a (non animated) movie? that the algorithm only makes use of half of the picture or picture information so to say? that it is incomplete atm?
the install and unistall batch file of that new version dont work for me. when I execute it nothing happens e.g. the black cmd window remains opened without anything happening (admin rights activated). I do have an optimus card.
is there any other way to install this manually? I did regsvr32 madvr.ax and same with madvr64.ax, but in mpc-hc madvr remains not installed in fact. its working fine with 0.90.24 though.
Laptop Acer Aspire V3-772g: i7-4202MQ, 8GB Ram, NVIDIA GTX 760M (+ Intel HD 4600), Windows 8.1 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64)
Old 19th November 2016, 14:21   #40279  |  Link
Ver Greeneyes
Some chroma upscaling algorithms like Bilateral and Reconstruction use the luma channel, which has twice the horizontal and vertical resolution, to guide the way they upscale the chroma channel. This can be very helpful when there's a lot of overlap between the chroma and the luma (e.g. if a change in color is usually accompanied by a change in brightness), but it can also lead to artifacts where they don't match well enough. NGU for chroma upscaling doesn't make use of this technique yet.
Old 19th November 2016, 14:21   #40280  |  Link
CarlosCaco
I will try NGU tonight... i don't have time now for tweaking so I want know, you guys suggest don t use any sharpener? And enhance details ?
Enviado do meu iPhone usando Tapatalk
Desktop, i5 2500, 8GB, N570 GTX TF III PE/OC
Asus X555LF, i7-5500U, 6GB Ram, Nvidia 930m/HD 5500
Windows 8.1 Pro x64
CarlosCaco is offline   Reply With Quote
