#30262 | Link |
I have a problem with Potplayer x64, if I use Madvr everything is black out but there is sound and I can scroll to see on the thumbnails previews. If I disable madvr the video is back. potplayer x32 works fine.
I tried reinstalling potplayer x64 5 times, trying different configurations, just black screen as soon as I try Renderer Madvr Last edited by x7007; 21st May 2015 at 14:14. |
#30263 | Link | |
8700K @ 5Ghz | ASUS Z370 Hero X | Corsair 16GB @ 3200Mhz | RTX 2080 Ti @ 2100Mhz | Samsung 970 NVMe 250GB | WD Black 2TB | Corsair AX 850W | LG 32GK850G-B @ 165Hz | Xonar DGX | Windows 10 LTSC 1809 Last edited by XMonarchY; 21st May 2015 at 14:35. |
#30264 | Link | ||
Troubleshooter
check your x64 filters in a video
Is it? Code:
Filters currently loaded: - Default DirectSound Device - XySubFilter (=> madVR) - madVR - LAV Audio Decoder - LAV Video Decoder - LAV Splitter Source
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. |
#30265 | Link | |
If it accepts DP and HDMI, try both. If you're running particularly high resolution or refresh rate, try a lower one. Maybe its exceeding bitrate limits. Or it just doesn't accept it at all, and uses the FRC after its internal color/gamma processing.
#30266 | Link | |
![]() Yes it's LAV 0.65 Why splitter source ? I registered the Lav Splitter , no Lav Splitter Source |
#30267 | Link |
What is the difference between LAV Splitter and LAV Splitter Source?
8700K @ 5Ghz | ASUS Z370 Hero X | Corsair 16GB @ 3200Mhz | RTX 2080 Ti @ 2100Mhz | Samsung 970 NVMe 250GB | WD Black 2TB | Corsair AX 850W | LG 32GK850G-B @ 165Hz | Xonar DGX | Windows 10 LTSC 1809 |
#30268 | Link | |
Soul Architect
Somehow, the DirectX 11 rendering path isn't working with a source of 60fps. CPU is running only at 30-40% so it's not a CPU overload.
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 24th June 2015 at 07:08. |
#30269 | Link |
WOW! My 2009 Samsung CCFL SPVA LCD HDTV can do 12bits, but only @ 23Hz because @ 60Hz I get all kinds of strange artifacts all over the screen! Yey! I don't see any dithering on desktop or anywhere else though, aside from madVR.
#30271 | Link | |
Check with some "true" 60p files (not SVP), to see if your problem is limited to SVP or all high framerate content. Check SVP content with some light setting in madVR, even all bilinear scaling to make sure it's not some performance problem. |
#30272 | Link |
Its all the way from 2009 though! Still, image quality at 12bit + Ordered dithering is much better than with 8bit + ED dithering! All transitions are SO SMOOTH!
#30274 | Link |
I wonder if I need a new 3DLUT for 12bit...
#30275 | Link | ||
#30278 | Link | |
#30280 | Link |
Thanks
![]() dispcal.exe -dmadvr -Yp -R -yl -P 1,0,10,10 Code:
C:\ProgramData\Argyll_V1.7.0\bin>dispcal.exe -dmadvr -Yp -R -yl -P 1,0,10,10 Uncalibrated response: Black level = 0.0423 cd/m^2 50% level = 27.48 cd/m^2 White level = 127.53 cd/m^2 Aprox. gamma = 2.21 Contrast ratio = 3016:1 White chromaticity coordinates 0.3135, 0.3330 White Correlated Color Temperature = 6431K, DE 2K to locus = 6.6 White Correlated Daylight Temperature = 6430K, DE 2K to locus = 2.4 White Visual Color Temperature = 6200K, DE 2K to locus = 6.3 White Visual Daylight Temperature = 6350K, DE 2K to locus = 2.3 Effective Video LUT entry depth seems to be 12 bits |
