Old 23rd December 2008, 01:56   #161  |  Link
IanB
Avisynth Developer
@Fizick,
I assume you mean this disgusting piece of text :-
LangString StandAlone_Bubble        ${AvsLang} "Install the main files in the Product directory \
                                                (Nonfunctional non-Admin install) \
                                                (Must choose Standalone template)"
I gave up trying to rephrase this meaningfully within the space available.
And yes I will have to do another build to get the up to date changelists/release notes for Russian and English
IanB is offline   Reply With Quote
Old 23rd December 2008, 13:24   #162  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
How about "Unpack files to install directory, but don't register AviSynth with Windows (for use with applications that can use AviSynth directly)"?
np: Tocotronic - Drüben Auf Dem Hügel (Schnelle Version) (Nach Der Verlorenen Zeit)
now playing: [artist] - [track] ([album])
Leak is offline   Reply With Quote
Old 23rd December 2008, 18:19   #163  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
IanB, current text is not so bad.
The most trouble is "Standalone" type name. It is not commented any way (no any help).
May be replace it to more long? such as
"Standalone non-functional"
or
"Standalone non-registered"
or
"Semi-portable non-registered"
or similar to prevent any normal user to select it
Leak's suggesting may be considered too.
Old 23rd December 2008, 19:23   #164  |  Link
Leak
Leak's Avatar
How about "[Just] Extract files" (or "Unpack files [only]") instead of "Standalone installation"? (Or some other combination of those words...)
np: Tocotronic - Original Single Mix (Pure Vernunft Darf Niemals Siegen / Remixe)
Old 23rd December 2008, 22:01   #165  |  Link
IanB
Avisynth Developer
I like this "Unpack" word
Old 23rd December 2008, 22:15   #166  |  Link
Leak
Leak's Avatar
So - what royalties did you have in mind?
np: Tocotronic - Explosion (Kapitulation)
Old 24th December 2008, 07:54   #167  |  Link
IanB
Avisynth Developer
How about a 0.1% share of what I get for supporting this project.
Old 25th December 2008, 13:13   #168  |  Link
Wilbert
Okay here is a full 4.0Mb installer package. If we are happy with the look, feel and translations (thanks Wilbert) I will put this up as the formal RC5 in a day or so.
Thanks, it seems to work fine! I will update my nsis package (i still have 2.0.3)
Old 25th December 2008, 22:18   #169  |  Link
IanB
Avisynth Developer
I think I might go with this :-
LangString AVS_Standalone           ${AvsLang} "Standalone Unpack Files"
LangString StandAlone_Bubble        ${AvsLang} "Unpack all the files into the Product directory \
                                                (Nonfunctional non-Admin unpack) \
                                                (Must choose 'Standalone Unpack Files' type of install)"
thanks Leak
Old 26th December 2008, 16:49   #170  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
"Standalone Unpack Files only" ?
EDIT:
I translate this variant to Russian at CVS
Old 26th December 2008, 21:59   #171  |  Link
IanB
Avisynth Developer
Okay
LangString AVS_Standalone           ${AvsLang} "Standalone, Unpack Files only"
                                                (Must choose 'Standalone, Unpack Files only' type of install)"
