Old 16th March 2010, 03:53   #7161  |  Link
Balthazar2k4
Originally Posted by soneca View Post
Thanks for the tip! I was reading right now that the Totalmedia Theater has the DTS-HD decoder ...
I'll do some experiments.
No problem. Hope that helps.
Balthazar2k4 is offline   Reply With Quote
Old 16th March 2010, 06:54   #7162  |  Link
shikyo
PSP Anime Uploader
shikyo's Avatar
Hello.
I've been using RipBot for god knows how long without any serious errors. Only until recently did I start getting mad, with this error I can't convert any videos.
Everything I do is the same as usual. Set up my videos and what not, I start converting. It'll go through the process of encoding the audio, but once that finishes I get this error:
after that it automatically starts muxing, with only audio. but nothing happens. it moves on to the next video and repeats the results.
Everything was working just fine a couple of days ago. The time everything started getting wacky was when I downloaded v1.15.1 and updated my ffdshow. I've since tried going back to v1.15.0 and installed an older version of ffdshow, but nothing works. Any help on my situation?
EDIT:
I've also tried uninstalling and reinstalling Haali Media Splitter and AviSynth, but the outcome is always the same.
shikyo is offline   Reply With Quote
Old 16th March 2010, 08:05   #7163  |  Link
Balthazar2k4
Originally Posted by shikyo View Post
Hello.
EDIT:
Are you running an overclocked machine? Typically this is a sign of system instability on a hardware level.
Old 16th March 2010, 18:23   #7164  |  Link
pacaveli211
shikyo:
do you really only have an x86 machine?
if not, open the ini and enable x64 bit
or try reinstalling (rextracting) ripbot. or simply just the \Tools\x264 folder.
pacaveli211 is offline   Reply With Quote
Old 16th March 2010, 18:35   #7165  |  Link
Lighto
The Black Reaper
Lighto's Avatar
The new ffdshow is quite irritating, I need to add avs2avi.exe into the whitelist.....
Those with the ffdshow problem can try messing with the configuration.
Lighto is offline   Reply With Quote
Old 16th March 2010, 19:13   #7166  |  Link
pacaveli211
I just installed 3305, no problems. did you get 3316?
Old 16th March 2010, 19:16   #7167  |  Link
shikyo
PSP Anime Uploader
shikyo's Avatar
I haven't messed with anything to overclock it; I don't know if that's the problem but I'll look into that.
Originally Posted by pacaveli211 View Post
shikyo:
Yes, i'm still on an x86 machine. I've already tried reextracting RipBot and the x264 folder a couple of times.
Old 16th March 2010, 19:44   #7168  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
have you read first post?
Old 16th March 2010, 19:46   #7169  |  Link
Atak_Snajpera
This only happens if you do clean instalation. For some unknown reason whitelist is not created by installer.
Old 16th March 2010, 20:18   #7170  |  Link
nekrosoft13
Atak_Snajpera, is there a way/setting to ignore Haali version requirement? Since few pages back it was established that it was only VC-1 playback issues, nothing to do with encoding. There is no reason for old Haali version requirement.
nekrosoft13 is offline   Reply With Quote
Old 16th March 2010, 20:59   #7171  |  Link
Atak_Snajpera
Why do you need new broken haali media splitter?
Old 16th March 2010, 21:19   #7172  |  Link
soneca
I need to register or do something to the file (ASAudioHD) in the tools/ax for the dts decoder to work properly?
soneca is offline   Reply With Quote
Old 16th March 2010, 21:30   #7173  |  Link
Atak_Snajpera
Just put all required files to that folder and ripbot264 will do rest.
Old 16th March 2010, 21:36   #7174  |  Link
soneca
But the files are already there!
Old 16th March 2010, 22:00   #7175  |  Link
Atak_Snajpera
eeee. Can you remind me what is your problem?
Old 16th March 2010, 22:13   #7176  |  Link
shikyo
PSP Anime Uploader
shikyo's Avatar
I have read the first post. I've used both tools, and they both show no instability problems. No errors at all; I was honestly hoping for an error to show so I could at least know what the problem was.
Old 16th March 2010, 22:14   #7177  |  Link
soneca
You talk to overwrite files that already exist in the folder? ...
Because it seems that all the required files were already there.
Old 17th March 2010, 01:21   #7178  |  Link
Achilleus
Yes, the DTS Decoder that comes with Arcsoft TMT will help you to achieve what you are trying to do.
Is there a downside to this; ie a reason not installed by default?
Thanks
Achilleus is offline   Reply With Quote
Old 17th March 2010, 01:38   #7179  |  Link
nekrosoft13
because it not broken in my case
Old 17th March 2010, 02:01   #7180  |  Link
Balthazar2k4
Thanks
There is no downside as I have seen. The only reason I believe this is not installed by default is that Atak cannot freely distribute the Arcsoft decoder as it is apart of Total Media Theater. Therefore, you must install TMT and copy the files as directed by the TXT file.
