15th September 2011, 15:57 | #12921 | Link | |
Hi JDobbs,
Kudos on this new feature set in 39.01. BDRB just gets better and better. Some initial observations; minor stuff (do you want this f/b here, in the "bugs" thread, or should this maybe in the "features" thread?). 1. When I manually blank an item there is sometimes no visual indication that anything has changed until I move off that item and can then see the new, grey background. Not a problem when there are sibling playlist items nearby, because they "grey-out" right away and I can see immediately that something has changed. Perhaps you could change the blanked item's "film" icon to a red X, which would be consistent with what you do when you de-select audio and subtitle items. 2. When I expand (double-click) a blanked video item the associated audio and subtitle content is not greyed out. Perhaps they should be greyed-out too, to reinforce the fact that this content will also also blanked. 3. I like seeing the "this clip is set to be blanked" subtitle when previewing a blanked item -- neat. But there is no indication in the preview window of which item is currently being viewed, and the hi-light in the BDRB window disappears when the preview window takes focus; I have to click on the BDRB window again to remind myself which clip is playing. Can BDRB retain its hi-light when it looses focus, or is there a Windows limitation here? 4. How about allowing resizing of the app window -- especially vertically. It would be nice to see more of the list of streams, now that we will be playing around with these items more often. 5. In your description of how the new features work you state: Quote:
6. Entering "edit" mode by double-clicking the title felt a little non-intuitive at first. I wonder if there really needs to be an "edit mode" at all. Maybe you could allow stream blanking at all times, and just have a "Show blanked streams" checkbox at the top of the "Stream" tab. I dunno. Anyway, thanks again, and keep up the good work. |
15th September 2011, 17:09 | #12922 | Link | ||||||
15th September 2011, 19:13 | #12923 | Link |
Thank you for the update and new features.
I'm trying to blank some angles, there is 10 of them and are 500mb ish. "Blank this item" is greyed out. I have enabled test. I have output set to bd25, and full backup. Is it because it is angle? and not possible? |
15th September 2011, 19:43 | #12924 | Link |
Are you in "Edit Mode"? You can blank an angle -- but unfortunately since it is typically linked to other playback items which have a common playlist, they must all be blanked. If you are in "Edit Mode" and it is still disabled, it may be connected to a menu and isn't really an "angle". Sometimes there are short video sequences that appear to be angles -- but they are actually transition videos for selection actions from a menu.
15th September 2011, 19:48 | #12926 | Link | |
You cannot enter "edit" when "Movie-Only" is selected. |
15th September 2011, 20:34 | #12928 | Link |
@jdobbs
Thanks for the Edit feature I normally do my backups on BD5@720, movie only, or perhaps from now on possibly movie + menu. I notice that menus are not resized to 720. I use crf prediction mode, and some of the menu clips get a crf of say 35 and turn out to be blocky (reminds me on the mpeg2 days...). I wonder whether the blockyness would be less if menus would also be resized to 720 (i.e. same as feature)? Is there a good reason why menus are not getting resized? |
15th September 2011, 21:28 | #12929 | Link | |
i'll get back to the bournes soon., dont know if makes any diffrence but fast five was avc were as Bourne was vc1
k-c-ksum |
15th September 2011, 21:35 | #12931 | Link | |
15th September 2011, 21:40 | #12933 | Link | |
I'm running version v0.38.09 (beta), windows 7 home premium 64 bit, with everything "Ok" when running inspect. I created a batch for 6 blurays and I got exactly the same error message in every one of them: Quote:
#Created by BD Rebuilder - v0.38.09 (beta) LoadPlugin("C:\BD-RBV03809\BD_Rebuilder\tools\nicaudio.dll") audio=NicAC3Source("00009.track_4352.ac3").Amplify(1.2) ConvertAudioTo16bit(ResampleAudio(audio, 48000)) It seems that Aften doesn't like the "DTS-HD XLL" reported tracks. Any clue ? And the million dollar question... is there an easy way to take advantage of the already compressed video and not have to re-compress again? I guess that playing with tsmuxer and bdedit I could get somewhere... but if there is an easier way, I'd love to hear. Thanks. Last edited by acki; 16th September 2011 at 00:13. |
15th September 2011, 21:48 | #12934 | Link | |
Anyway, 2-pass encoding solved the problem as these critical menu files got more bitrate allocated compared to the crf prediction mode. |
15th September 2011, 23:02 | #12935 | Link |
worked great on a bd50 to bd9 backup non java bluray! jdobbs, if there is an asterik (*) beside the stream number, ie.. IVD_00388* does that mean those are dependent of another playlist? Is it ok to blank these out, or will it mess with the bluray structure? The reason why I want to blank them is for unecessary ads and logos of a bluray.
15th September 2011, 23:21 | #12937 | Link | |
So when you decide to blank something -- the decision has to ripple through every sibling in that playlist, and any other linked playlists. In other words, if you decide to blank an angle for a main feature -- you are also deciding to blank the entire main feature, and therefore angles aren't really "ripe" for blanking. Last edited by jdobbs; 15th September 2011 at 23:23. |
15th September 2011, 23:27 | #12938 | Link |
ok, thank you for the explanation.
Would "quicker encode for extras" be good to enable in this case? The main feature film is 33 GB and all the extras, angle parts are around 500mb. Would BD-RB see those 500mb parts as extras? and does this do anything to aid the main features video quality? |
16th September 2011, 00:32 | #12940 | Link | |
500MB isn't going to get you much. In a case like that you're probably better to do a just full backup and possibly blank any annoying trailors, warnings or other items that happen automatically at startup. Last edited by jdobbs; 16th September 2011 at 00:35. |
