Old 21st June 2014, 04:31   #1001  |  Link
nandaku2
Originally Posted by LigH View Post
Yes. I compile the same sources with MinGW GCC 4.8.2 with different options, and after stripping, e.g. the following executable sizes in byte are reported:
x265.exe for Win32:
2270208 B (-DWINXP_SUPPORT=1)
2107392 B (-DWINXP_SUPPORT=1 -DHIGH_BIT_DEPTH=1)
x265.exe for Win64:
2816512 B (-DCMAKE_TOOLCHAIN_FILE=toolchain-x86_64-w64-mingw32.cmake)
2748928 B (-DCMAKE_TOOLCHAIN_FILE=toolchain-x86_64-w64-mingw32.cmake -DHIGH_BIT_DEPTH=1)
There is probably some more elaborate code in some routines for low bit depths only.
This is likely because we have lesser asm functions at HIGH_BIT_DEPTH. Some of the larger intra asm functions were developed for 8bpp, but were deemed infeasible for 16bpp.
nandaku2 is offline   Reply With Quote
Old 21st June 2014, 04:56   #1002  |  Link
nandaku2
Originally Posted by a5180007 View Post
Hi Tom, I sure will do when you say psy-rd is ready for testing. But the source is so grainy I'm not convinced psy-rd will bring any benefit at such compression. At least in x264 it does not : it removes a lot of details to put back grain noise. And before testing psy-rd, I wanted to make sure standard SAD rdo was as good as x264 in grain and detail retention.
Are the algorithms for placing I-frames so different in x264 and x265? Why would x265 put one third less I-frames with both scenecuts at 40%? This biases comparison.
EDIT : and it makes single frame comparison with x264 even more pointless.
EDIT 2 : Got it. x264 and x265 --bframes 3 --b-adapt 1 return the same amount of I-frames. Placement and numbers of P and B frames are still totally different though.
The lookahead cost function in x265 is different than x264. x265 evaluates more intra modes and some changes in bidir modes (as compared to x264). This makes the slice decisions different. You could use --b-adapt 0 if you need all slice decisions same across x265 and x264.
Old 23rd June 2014, 09:21   #1003  |  Link
LigH
LigH's Avatar
The latest patch is supposed to reduce the RAM utilization. May be interesting to check v1.1+193 against an older build regarding encodability of 4K video even with a 32-bit build.
__
Stable at 1.6 GB with preset "slow", looks promising.
__
Preset "slower" requires about 1.9 GB RAM (Private Bytes: 2,040,092 KB / Working Set: 1,768,604 KB – at frame 30); the patch must have made it more dependent on the complexity, instead of assuming a maximum always.
I believe there may still be headroom with more efforts, but a further reduction will probably be harder to achieve (not without some deep reorganization and allocation "smartness"). For now, even on almost "obsolete" 32-bit OS, 4K encoding will be possible with preset "slow", maybe even "slower".
New German Gleitz board
Old 24th June 2014, 03:04   #1004  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Originally Posted by upyzl View Post
@benwaggoner & @foxyshadis
well, to be specific
1) now at same medium bitrate(medium bitrate means, e.g. x264 crf22), x264-10bit act much better than x264-8bit in prevent banding(especially in dark flat area because of gamma compression) if Source has no banding -- of course benefit from high interal bit depth, also have positive to prevent other artifacts -- and now x264-10bit optimize is good enough even at [same encoding time & bitrate], it could still act better quality than x264-8bit
2) x265 8bpp now also use 8bit internal, I should use x265 16bpp for high bit internal -- x265 works like x264 in this regard
3) until now, H.264/AVC 10bit-depth has low compatibility. e.g. we could not use Hardware acceleration for 10bit video; mobile device/PS3 like hardware device(diff from PC could use x86-CPU for generic software decode and almost ignore decode performance and power consumption) playing 10bit video is much difficulty and unfriendly; seems video editing fields is the same(e.g. Adobe Premiere is not support for H.264 10bit video). I'm very worry about HEVC/H.265 age will be the same...
4) and...for [8bit input] and high-bit internal, if use 8bit output rather than 10bit output, should be smaller size at same quality?(I'm Not expert on this)
so, I'm interest in 8bit in/output and high-bit internal, especially in encoding
seek for lowest bitrate for same high quality is eternal topic for video compression, and I am, but I also care about a degree of compatibility (and encoding time)...
It doesn't matter what you put in or take out, the compatibility revolves entirely around the internal bit-depth. Whether the future brings wider 10-bit compatibility is entirely unknown, we just have to hope that since it's included in the base spec, some hardware makers will take advantage of that. So far the major GPU makers (Intel, AMD, nVidia, PowerVR) are barely incorporating support for 8-bit HEVC.
Using 10-bit internal with 8-bit input doesn't seem to have the same advantage over plain 8-bit in x265 as with x264. (And even that is fairly small.) I'm not sure if that's the encoder, or the standard, but we'll have to see how it evolves. Maybe HEVC just doesn't cause as much banding as AVC in general at 8-bit?
With respect to size, it doesn't matter if what you output, it's still the same file (unless you're re-encoding) and internally every calculation is done at the internal bit-depth until the final output, when it can be left alone or downsampled. Even with 8-bit input, Main 10 with 16-bit output instead of 8-bit dithered might look better simply due to not rounding as early. (No decoder currently produces float output, although they could if they wanted.) I don't know if anyone's really tested that, and you'd need a decent monitor to tell the difference, and right now I don't have one. It's an interesting area to investigate.
It definitely will help if you're doing any shader processing on the output; MadVR will accept up to 16-bit and won't ever drop down until it outputs to the screen.
Old 24th June 2014, 08:15   #1005  |  Link
LigH
LigH's Avatar
Impressive results with the command line
--crf 30 --preset slower --aq-mode 2 --aq-strength 1.5 --psy-rd 0.3
Even the lawn in the background, which used to lose a lot of detail, is now satisfyingly persistent.
Old 24th June 2014, 10:19   #1006  |  Link
zerowalker
Thought of just asking, how is the Psy-rd getting a long?
I know it had issues and such a while back, is that still the case, or are you making progression?
zerowalker is offline   Reply With Quote
Old 24th June 2014, 10:59   #1007  |  Link
Procrastinating
Procrastinating's Avatar
They've been making plenty of progress, but as far as I know it's not complete to the extent that they want yet. It's good enough now that it's better than not having it in a number of cases though.
Procrastinating is offline   Reply With Quote
Old 24th June 2014, 11:01   #1008  |  Link
zerowalker
Ah that's nice to hear.
Has it improved the "Blur" x265 tends to give details?
Old 24th June 2014, 11:32   #1009  |  Link
LigH
LigH's Avatar
Carefully used, together with adaptive quantization, Psy-RDO has the potential to preserve more detail than in previous builds. Even though it is not yet completely correct.
They will tell us when they did it for certain...
In the meantime, enjoy another 4K encode demonstrating the efficiency (same options as above); x264 used to fail especially in the sky at similar bitrates (noticably worse behaviour at up to 3 times the bitrate of the x265 sample in an earlier 1080p test).
Old 24th June 2014, 13:52   #1010  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
May I ask what cpu do you have? My Xeon 8c / 16t 2.9Ghz has troubles to maintain smooth frame rate during playback in MPC-HC 1.7.5 (EVR mode) . Video chokes at the very beginning and at the very end while playing in loop mode. Cpu usage is at ~66%. With MadVR enabled it is even worse. Probably my R4850 512MB does not have enough memory for 4K.
Old 24th June 2014, 14:03   #1011  |  Link
LigH
LigH's Avatar
My equipment here is way below yours: An AMD Phenom-II X4 is too slow to play this 4K video in realtime, and madVR is no option anyway with a GeForce 9600.
At home I have a Phenom-II X6 and GTS 450 available, that won't be fast enough either, I believe.
Old 24th June 2014, 14:20   #1012  |  Link
zerowalker
Okay thank for the fast update info
As for the Video LigH posted, i can tell you that i have no way of playing it in realtime.
And i have a quite good PC (i5 760 @4Ghz), and it goes to 100% and it's nowhere near it's original speed.
Old 24th June 2014, 14:40   #1013  |  Link
EncodedMango
And I thought it didn't work because I tried it on a laptop.
EDIT: Just to clarify, this is x265 decoding speed/cost at present which is causing this, right?
EncodedMango is offline   Reply With Quote
Old 24th June 2014, 15:09   #1014  |  Link
LigH
LigH's Avatar
These clips are encoded with a rather high complexity, and they are to be played with 50 fps. I am not surprised that decoding them is too elaborate for realtime playback.
Realtime playback of less complex 25 fps 4K video would be possible with current hardware and decoders.
Old 24th June 2014, 15:35   #1015  |  Link
nevcairiel
Note when testing H.265 playback, you should most definitely use 64-bit versions of the player and decoder, as they are up to 50-100% faster, especially on 4K content (at least for anything FFmpeg based, like LAV/MPC-HC/etc.)
A lot of the decoder assembly is not compatible with 32-bit due to its complexity (and because the developers didn't want to spend time making it even more complex by allowing 32-bit support).
Old 24th June 2014, 16:00   #1016  |  Link
fumoffu
64bits doesn't help much in this case.
Tested on 4core i5 @4Ghz and 1GB video memory - nowhere near smooth playback. MPC-HC nightly 1.7.5.146 was using less then 300MB GPU memory and MPC-BE 1.4.2 almost 700MB (I have 1680x1050 monitors). I wonder if number of CPU threads have any effect on video memory required? It shoudn't right? Maybe I'll test it later. Also if you use MPC you can save like 50MB by changing the number of EVR Buffers from default 5 to 4.
fumoffu is offline   Reply With Quote
Old 24th June 2014, 17:24   #1017  |  Link
x265_Project
Work continues. Expect more updates this week.
x265_Project is offline   Reply With Quote
Old 24th June 2014, 22:20   #1018  |  Link
benwaggoner
We are seeing some TV players support internal 10-bit decode, like the latest Samsung UHD TVs. They can play back HEVC up to 2160p60 10-bit. But not H.264 High 10.
It's by spec; HEVC does 8-bit better than H.264 did, so there's no real reason to encode 8-bit sources in Main 10.
Ben Waggoner
My Compression Book
Old 25th June 2014, 12:47   #1019  |  Link
upyzl
zj262144
upyzl's Avatar
Maybe it's a little too early to talk about Hardware HEVC support now...
Good to hear.
hope HEVC(8&10bit) Hardware support could reach today's as AVC-8bit in 2~3 years
really I'm not familar with HEVC spec, I maybe choose testing to verify... but definitely I think it's not proper time to test whether x265-8bit could handle as good as x264-10bit currently(mainly in middle-high bitrate for quite high quality encoding, I know in low bitrate x265 win completely), I may test when x265 is good for that
maybe I should ignore it...even if it really could reduce/save size, there's few people could identify different(of course I've no decent monitor)... hope future somebody could solve that
Yes, in fact I just do.
last, thank you all for the patient replys
MPC-HC 1.7.8 / LAV Filters 0.64+ (tMod) / XySubFilter 3.1.0.705 / madVR 0.87.14
Direct264 Mod (src & win32 builds): code.google.com/p/direct264umod (maybe outdated)
upyzl is offline   Reply With Quote
Old 25th June 2014, 20:55   #1020  |  Link
kolak
New Sony 4K TVs also support 10bit HEVC.
