6th November 2017, 10:10 | #47061 | Link | |
native resolution is best
6th November 2017, 13:04 | #47063 | Link |
UTAVATU
Dear Friends
My system, Windows 10 and i5 4690K with GTX 1070. I have a strange issue with madVR. I have enabled 10bit (it's only happend with 10bit enabled) in Settings and in the NVIDIA Control Panel. I watch movies with Fullscreen Exclusive mode enabled. So after few minutes (it's mostly random) my screen goes black during playback, but I still hear audio and the movie continues, after 1-2 seconds my screen backs to normal and I can watch my movie. It only happens once per movie. I have tried lots of settings and it always happens. madVR 0.9.29 (the same problem was in earlier versions too), LAV Filters and MPC-HC the latest ones. File .mkv HEVC 10bit 3840x2160 HDR, but it happens with any .mkv file. Maybe someone had such problem and know how to resolve it? I would be glad for any help, clue and solution. Thank you in advance for your help. Sincerely Last edited by VAMET; 6th November 2017 at 13:08. |
6th November 2017, 14:06 | #47064 | Link | |
6th November 2017, 14:47 | #47065 | Link | |
UTAVATU
Dear Cinemancave
Maybe there is some options in madVR there should be enabled and I have them disabled, or disabled and I have them enabled. I don't know, why this black screen occurs for 1-2 seconds and then everything is OK. Yep, you are right, that sometimes it doesn't happen, not every movie, but most of them and it is random, but rather at the first minutes of movies. If you will find a solution, please share it here. Maybe someone had such problem? Anybody? Do you also have this problem, when 10bit in madVR and 12bit NVIDIA Control Panel is set? May you also make screenshot of every option set in Settings of madVR, I will compare to mine and maybe we will solve it once for all. Sincerely Last edited by VAMET; 6th November 2017 at 14:49. |
6th November 2017, 20:12 | #47066 | Link |
RCA medium plus NGU standard or sharp produces very pleasant visual effect when playing good 720p materials, which is amazing.
I used to avoid NGU standard or sharp, due to the unnatural overly sharped border effect. |
6th November 2017, 23:37 | #47067 | Link | |
Did you try simply lowering settings to see if it changes anything? For example, disable quadrupling just to see what the rendering times are. I know it's counterintuitive, but in my experience you can have empty rendering queue and dropped frames even if the reported rendering times are not close to the frame time, if your GPU is at 100% load and max boost.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
7th November 2017, 00:51 | #47068 | Link | |
7th November 2017, 02:57 | #47071 | Link |
I'm watching one of my noisiest Blu-ray movies, Red River. Render times got too high using both RCA and RRN at 3, and I didn't see very much effect anyway (rig is GTX 1080 driving a 4K monitor), so I disabled RCA and upped RRN to 6. The effect is amazing, almost all the noise is gone and the picture looks great (maybe a slight loss in detail, haven't played around with that yet).
Excellent work, madshi! It's not quite up to NLMeans denoising, but it's in real time! madVR just gets better and better. Congratulations on yet another great algorithm. EDIT: Applying Crispen Edges and Enhance Detail while doubling restored the detail. Last edited by jkauff; 7th November 2017 at 12:57. |
7th November 2017, 10:48 | #47072 | Link | |
7th November 2017, 10:51 | #47073 | Link | |
UTAVATU
Dear Razoola
Sincerely |
7th November 2017, 11:07 | #47074 | Link | |
My problem was a little worse given my TV is far away and I needed a long cable. Remember UHD with HDR (10bit) is not expected to work with a real long cables, it starts getting flaky at 7m plus. Got a new cable and everything is now fine, I'm using this at a 6M length, not sure it can handle UHD at 60fps but I have no issues with 24fps movies at 12 bit with Dolby Atmos 7.1 HD audio... https://www.amazon.de/gp/product/B00...?ie=UTF8&psc=1 Last edited by Razoola; 7th November 2017 at 11:18. |
7th November 2017, 11:14 | #47075 | Link | |
UTAVATU
Dear Razoola
Sincerely |
7th November 2017, 12:05 | #47076 | Link | |
Only other thing I can think is the picture is dropping as madVR goes from windowed to exclusive mode but really it should not. |
7th November 2017, 12:30 | #47077 | Link | |
UTAVATU
Dear Razoola
The only problem is 1-2 seconds black screen, which is random, it shows even on AVC 1920x1080 without HDR, 10bit, but 10bit is enabled in madVR and 12bit in NVIDIA Control Panel. As for Fullscreen Exclusive I have disabled 3 seconds delay automatic launch option, so it works from start directly, when I click to play the movie. Sincerely Last edited by VAMET; 7th November 2017 at 12:33. |
7th November 2017, 16:41 | #47078 | Link | |
I am on win 8.1 with latest AMD crimson drivers and yes mostly it is when I watch something in 2160p 10bit (HEVC or AVC), not so sure about 8 bit though... |
7th November 2017, 19:17 | #47079 | Link |
I'm going to say if its not the cable the next most likley thing is some kind of grounding issue around the house. For example, in my home (because its old) turning off the FL light in the bathroom can cause the audio to drop out but not the picture. On my old TV it would cause the picture and audio to drop for a couple of seconds. So if your cases if you know its not something else your turning off or on around the house then it might be something like the fridge or freezer. Try plugging your PC and TV into a different socket and see if it helps.
7th November 2017, 21:50 | #47080 | Link | |
