19th April 2015, 17:26 | #29063 | Link | ||||||||||||||||||||||||
Hmmmm... Good question. That one is written in Delphi, not sure how easy it will be to update it to x64. I'll put it on my to do list. Might take a while, though. Quote:
Personally, though, I haven't used Reclock in years. My HTPC has a 1:1 refresh rate / framerate match, so I need neither Reclock nor SM. Quote:
1) Try your best to achieve a 1:1 refresh rate / framerate match. E.g. play Blu-Ray movies at 23.976Hz. This should help a lot. 2) If you can't do 1), then you may want to disable the "present several frames in advance" option. But this only applies if 1) is not possible and for Optimus users in this specific situation. Other than that there's not much I can suggest... Quote:
The x64 version is pretty much identical to the x86 version. |
19th April 2015, 17:28 | #29064 | Link |
One polite request to all madVR users:
Please don't (re-)distribute any files from me that aren't available on my server, anymore, without asking me first. I may have had a good reason to remove them from my server. Thanks! (Obviously this doesn't apply to official madVR/eac3to builds, or anything else that is still available on my server.) |
19th April 2015, 18:24 | #29065 | Link |
MPC-HC Developer
@madshi: I found that RivaTuner Statistics Server prevents madTPG from running it doesn't even show its window, just leaves ghost process. It happens when "Custom D3D support" is enabled, even if madTPG.exe is on exclude list and/or statistics are disabled completely. I didn't know where to report this issue, but I figured it might be better if you contact RTSS developer with more information if you care about this issue. Or just fix/workaround the issue.
19th April 2015, 21:24 | #29069 | Link | |
I think it's was rendering in average stat. What are the difference between rendering and present? Quote:
My stats are good. Last edited by ikarad; 19th April 2015 at 21:27. |
19th April 2015, 22:18 | #29070 | Link | |
present is just presentation. there is no need to see high values here it's such a simple task for GPU. present times over 3 ms AVG are usually a problem with v-sync for example disabled aero -> disabled v-sync. |
20th April 2015, 00:52 | #29071 | Link | ||
I get artefacts (specifically, dotted black or sometimes colored lines which flash on the screen). This is my first post. I signed up & have waited for a week just to get posting permission. Now I can finally share. Hopefully I don't miss anything important... My system: Quote:
With the previous Nvidia driver, these artefacts actually had sort of neon or blue colors. With the latest Nvidia drivers, they are now black. (FWIW, the previous Nvidia drivers had vertical lines appear when Error Diffusion Option 1 was enabled. The latest Nvidia driver solved that particular problem & I can use the option now) I don't think this is the result of my system being stressed, because I get no frame drops...and these artefacts appear even when a single NNEDI3 setting with the lowest value is enabled. Some guy last week said the problem was solved with this Nvidia driver. He speaks for himself, because it's still a problem for me. Last edited by paulescobar; 20th April 2015 at 03:39. |
20th April 2015, 03:26 | #29073 | Link | |
NNEDI3 doesn't work for chroma upscaling either, by the way. Selecting it gives me a Chroma > Jinc3 AR in the overlay. The weird thing is that I've never used Jinc so the Anti-Ringing Filter checkbox wasn't even selected. Last edited by Schwartz; 20th April 2015 at 03:29. |
20th April 2015, 03:37 | #29074 | Link | |
And, no, I don't over-clock (not sure if you mean my CPU or GPU - but either way, I don't). However...my motherboard is an "MSI Z97 XPower AC". I read somewhere once (not even sure if it's true) that it has some mild over-clock enabled in factory defaults (and defaults are pretty much what I use, sans boot order stuff). Not sure why this would affect MadVR, but do you think it would have a big enough impact to warrant further research? Last edited by paulescobar; 20th April 2015 at 03:43. |
20th April 2015, 03:46 | #29075 | Link | |
Broadband Junkie
Though since you also have a GTX770 like I do, applying either of the following registry keys should work so you don't need to mess with any of that. http://www.mediafire.com?innbjl44crc6pbe |
20th April 2015, 04:01 | #29076 | Link |
I have monitors which darken (lower gamma) when the refresh rate is overclocked beyond 60Hz as written here: http://www.gamersnexus.net/guides/16...r-refresh-rate
@madshi I'm curious, does it make sense to allow for madVR to use different 3DLUT profiles that have been generated from calibrations at different refresh rates in conjunction with the refresh rate changer? If so, I'll be able to match refresh rate and frame rate on all files. Last edited by dansrfe; 20th April 2015 at 04:03. |
20th April 2015, 04:11 | #29077 | Link | |
Pic of proof in the link below. https://www.dropbox.com/s/p5tbwmx0e3mdzb7/nnedi%20x64%20madvr.jpg?dl=0
Core i7 4790K@4.6Ghz - Asus Maximus VII Formula - AMD R9 290X 4GB Crossfire - Windows 10 Pro x64 |
20th April 2015, 04:39 | #29078 | Link | |
Can I ask you a silly question? I'm kind of new to Windows 64. What is the correct method of installing this new 86/64 MadVR package? Should I place it in the x86 program files folder and then run "Install.bat"? Or should I place it in the normal x64 program files folder & then run "Install.bat"? |
20th April 2015, 04:56 | #29079 | Link | ||
Broadband Junkie
The NVIDIA PTX kernel in those registry keys I linked can only be used by Kepler sm_30 GPUs (i.e. GK104). Even more so, it will be regenerated/ignored if not using a GTX 770 with 350.12 driver because of the key name and values. If you imported my 'GeForce GTX 770' key on a AMD setup, it should just be yet another entry in the registry and ignored. madVR has always supported storing a cached OpenCL kernels for each GPU you've ever used with madVR, but this shouldn't have any overlapping side-effects. Either adding an NVIDIA OpenCL key on an AMD setup somehow breaks NNEDI3 and madVR fails to report it correctly, or madVR has a serious bug regarding those OpenCL registry keys. Check HKEY_CURRENT_USER\Software\madshi\madVR\OpenCL and see if there is a key with your GPU model which contains a Binary kernel. Quote:
If using one of GTX 770 OpenCL registry keys I posted, it doesn't mater if you are using madVR x86 or x64. The same key can be used with both. As for which key to use, just pick whichever one seems faster if there is a difference at all. That said, if you wanted to switch to madVR x64, it can only be used with a 64bit directshow filters and media player. You'd need to grab a player like MPC-HC x64 or MPC-BE x64 at bare minimum in order to use it. Last edited by cyberbeing; 20th April 2015 at 05:06. |
20th April 2015, 05:09 | #29080 | Link | |
