9th November 2009, 17:25 | #9522 | Link |
Both of them in a way. If you decode the TrueHD you get exactly what was in it. If you decode the AC-3 you might not get exactly what's in it (assuming they can be decoded to an arbitrary bitdepth), but 24 bit is close enough as in no audible difference from the source.
Of course if you encoded the AC-3 from the TrueHD there is a loss during the AC-3 encoding. |
9th November 2009, 17:33 | #9523 | Link |
If you're making a DTS-HD MA track, the you should ONLY go TrueHD -> WAVs -> DTS Encoder. Going TrueHD -> AC3-> WAVs-> DTS encoder is converting lossy to lossless whether you re-encode or take the TrueHD core, because either way you're discarding the lossless MLP data.
9th November 2009, 18:11 | #9524 | Link |
NY Frame of Mind
......which is the logic I was using from the start. Thanks.
However, what really puzzles me here are the substantially smaller wav files (and DTS-MA files- 2.5gb vs 3.8gb) when going from TrueHD -> WAVs -> DTS Encoder, then when going TrueHD -> AC3-> WAVs-> DTS encoder. Logically, I would think all the files would be larger in the first lossless option. Additionally, the first option results in 16 bit wavs, the second in 24 bit. I think you guys can appreciate my reasoning, even if it's way off base. From what you're saying, I should also use the first option if I want to just create a straight, non HD, DTS track @1536 ?
"Talk to me Goose" |
9th November 2009, 18:16 | #9525 | Link | |
24-bit PCM (16 bit + 8 bits padding) is generated by decoding AC3 to 24 bit, for no quality gain (and in this case, quality loss versus MLP to WAV). Decoding straight to WAVs nets you only the real 16-bit data.
9th November 2009, 18:19 | #9526 | Link | ||
About the filesize. IIRC wav filesize is simply bitdepth * sampling rate * duration, so with the same duration and sampling rate a 24 bit file is 50% larger than a 16 bit file. 0.8 GB *1.5 = 1.2 GB Quote:
9th November 2009, 20:13 | #9527 | Link |
as it seems eac3to cannot remove gaps from truehd tracks, but for example it can do so when I convert the original truehd track from a movie BD to flac. but when I demux the truehd track and then convert it to flac afterwards, then the gap message suddenly disappeares. does this mean that the gap remains undetected here and untreated?
9th November 2009, 22:12 | #9528 | Link | |
Posts: n/a
9th November 2009, 22:39 | #9529 | Link |
NY Frame of Mind
In case you all missed this last question in an earlier post today :
"Another question is, when encoding a DTS file should the rear channels (5.1) be attenuated to -3db or should that be left alone (unchecked) ? From what I've read movie theater tracks are boosted by 3db for the rears so theaters then attenuate them by the same. But BD tracks are not boosted, so should be left alone? Is that correct ?" Edit : Found this in the Surcde (which I don't use) manual : Code:
7.2 The Attenuate Rear Channels 3 dB Option The original standard for Surround Sound in movie theaters was to attenuate the rear channels by 3 dB. So, in mixing for theaters, studios have their rear channel monitors attenuated 3 dB. Home theaters, on the other hand, have the rear channels at unity gain. So, a mix that was made with the rear monitors attenuated 3 dB will have rear channel levels that are 3 dB too high for home theater. This option takes care of that difference. So, in general, you use this option if creating a DVD-Video using a Surround master that was originally mixed for movie theaters
"Talk to me Goose" Last edited by rapscallion; 9th November 2009 at 23:08. |
10th November 2009, 07:04 | #9530 | Link | |
eac3to incorrectly reports the resolution for one of the playlists on a Blu-ray of mine:
11th November 2009, 13:28 | #9538 | Link | |
Yes it is know, to avoid overflows, when convert from frequency domain to time domain, many decoders attenuate a little bit the output. You can use the -normalize parameter if you want. And, of course, the use of ArcSoft decoder is always recommended. Decoding ac3 sometimes eac3to detect overflows and make a second pass attenuating the signal.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 11th November 2009 at 13:30. |
11th November 2009, 17:33 | #9539 | Link | |
15th November 2009, 21:13 | #9540 | Link | |
Thank you! |
eac3to |
