26th February 2012, 10:03 | #12301 | Link | |||||
Thx. Quote:
Could you please double check whether this problem is new with v0.81 or whether it also occurs with v0.80 and v0.79? Thx. Sure. Quote:
"auto" is not really working well yet. It basically is supposed to switch to film mode if the display refresh rate is 25Hz or less, and to switch to video mode in all other cases. A true auto detection (based on analyzing the video frames) is planned for a future version, but don't expect it any time soon. |
26th February 2012, 10:33 | #12302 | Link | |
Thanks for this new feature, by the way!
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
26th February 2012, 11:25 | #12304 | Link | |
Although i'm unsure if i should really switch to YV24 as default YUV 4:4:4 mode right away (to avoid EVR issues with AYUV), people might not upgrade madVR for whatever reasons. I guess i'll let it "age" for a while.
26th February 2012, 11:45 | #12306 | Link | |
If I can get it to do it again I most certainly will. In trying to reproduce this I found I can crash MPC consistently by keeping the MadVR config window open (either initial or second window) when MPC loads the next file in the folder. |
26th February 2012, 12:23 | #12307 | Link |
MPC-HC Developer
I think message "deinterlacing off (settings)" in OSD should be shown only when playing interlaced video and if we play progressive video that message should be "deinterlacing off (says bitstream)" because it is off anyway. It will help to know if we force to turn off deinterlacing or video doesn't need to be deinterlaced. I wish you understand what I trying to say
26th February 2012, 12:24 | #12308 | Link |
The big problem here is that i have to decide this before i know what will be the renderer...
26th February 2012, 12:27 | #12309 | Link |
I just woke up, what a nice surprise on this sunday madshi.
Anyway, I already encountered some weird bug in the automatic switching of the display mode in 0.81 after testing some regular trailers and other files with a framerate of 23.976 with my display at 60Hz. 1) I checked "switch to matching display mode ... when media player goes fullscreen" and I´ve only listed 1080p24 in the list of display modes 2) I launch PotPlayer and open the movie 3) After I go fullscreen I can see that madVR switches the display to 1080p and 24Hz (23.977 to be exact), however: - the OSD still shows "display 59.95253Hz" and (see screenshot #1) - madVR doesn´t invoke exclusive mode (the OSD shows windowed in the upper left corner after the switch took place) and - the picture is not centered anymore as it should be, but shifted down by quite a bit (see screenshots #1) If I manually switch my display via NVIDIA´s custom resultion selection - 1920x1080 - 24Hz - and play the same movie, madVR perfectly switches to fullscreen and also shows "display 23.977" in the OSD (so everything as it should be). I was using PotPlayer for this test, as always. If I use MPC-HC, the picture is centered (that one is different from the PotPlayer behaviour), but the picture is lagging constantly and the other issues are the same as with PotPlayer. Here are some screenshots if you need them: |
26th February 2012, 12:34 | #12310 | Link |
iSunrise,
I think you should put 1080p23 in madVR's settings to get 23.976 refresh rate. Otherwise madVR tells Windows to switch to 1080p24 and if it doesn't have this mode it switches to a random one.
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V Win 10 64bit 1803 + Zoom Player v14 |
26th February 2012, 12:37 | #12311 | Link | |
This is how it looks in the NVIDIA resolution settings (I am using the custom resolution settings that were recommended in this thread to have almost perfect sync with 23.976 content and they work perfectly fine if I switch to them manually): Last edited by iSunrise; 26th February 2012 at 12:42. |
26th February 2012, 12:42 | #12312 | Link | |||||
This is probably a PotPlayer bug. At least it's PotPlayer's responsibility to position and size the madVR rendering window. |
26th February 2012, 12:46 | #12313 | Link | |
thank you very much for the new version - very nice new features and changes sadly I have to report that one problem is still not fixed: enabling "delay playback start..." is still resulting in "paused state" when I make excessive stream switching in ZoomPlayer (pressing and holding the Ctrl+B keyboard combo (switches subtitle streams)). I've also got one exception when going out of FSE mode and sent you the report ... btw very nice feature. I confirm that the frame step issue is fixed and that exclusive->window mode switch in Zoom Player do look better now.
26th February 2012, 12:46 | #12314 | Link | ||
EDIT: And here it is: http://www.mediafire.com/?ujm2dtcmnhevlv9 I´ve switched to fullscreen at approx. 5 seconds and let it run until 2:10 minutes and switched back to windowed. One other thing that is really odd is that the display refresh rate listed doesn´t update at all (like I mentioned), but all other stats DO STILL update perfectly fine. Last edited by iSunrise; 26th February 2012 at 12:56. |
26th February 2012, 13:05 | #12315 | Link |
madshi
Thank you for .81! Please have a look: The source is NTSC film in .mkv container (DVD). Mediainfo reports that video scan type: Progressive. Madvr is in film mode (settings). Display does not switch to 23, but switches to 59. If mediainfo reports that Scan type: Interlaced, everething is OK. |
26th February 2012, 13:10 | #12316 | Link | ||
Ok, I guess I have to totally restart rendering after a display mode change. To be honest, I was hoping that wouldn't be necessary. Anyway, I'll change that for the next build. That should fix the display refresh rate problem. But it won't change the FSE problem. That's a PotPlayer bug, as far as I can see. I'm wondering, though: Does this really not occur with older madVR builds? I don't see why PotPlayer should set v0.81 to 1920x1200 and older builds to 1920x1080!? |
26th February 2012, 13:11 | #12317 | Link | |
26th February 2012, 13:25 | #12318 | Link |
MPC generates a error saying it's stopped working, so I'm uncertain, I've created a log anyway if you're interested.
http://www.mediafire.com/?5a6o4g47fulerfs |
26th February 2012, 13:39 | #12319 | Link |
With new version new exclusive mode is working fine now, at least I've not seen any stuttering yet.
Will you fix the issue with FRAPS videos not playing with FRAPS decoder in a future version? It's still there with 81. |
26th February 2012, 13:51 | #12320 | Link | |||
Under "Full screen settings - Resolution" I´ve just changed my setting from "Current resolution (recommended)" to "1920x1080 (32bits, 60Hz)" and now I have THE SAME behaviour as under MPC-HC: - picture IS centered now, but - lagging picture (it´s constant, probably because the renderer wants to sync with 59.95xx (60Hz) but the actual refresh is 23.977, dropped frames are increasing very fast) - wrong display refresh rate in the OSD Quote:
I´m gonna wait for your fix and test again. |
