5th September 2011, 21:25 | #13962 | Link | |
MPc-HC sub rendere is dead since many years and no developpers works on sub renderer in mpc-hc. If ffdshow is dead (how do you know that it's dead?), there is not alternative. I doubt that lavfilters replace ffdshow because it's not the same thing. lav filters is just for decode audi oand video but there is no filters and no support of avisynth. |
5th September 2011, 21:28 | #13963 | Link |
Why?
is it too difficult? one year ago only, there were lots of progress with ffdshow (support of HD subs, support of dxva, support of HD audio, support of ffmepg-mt etc...) Even some developpers like albain speak about the fusion between mpc-hc and ffdshow Last edited by ikarad; 5th September 2011 at 21:31. |
6th September 2011, 13:26 | #13965 | Link |
Its not a matter of choice, there is just no-one capable and willing to work on it.
6th September 2011, 15:23 | #13966 | Link |
what about these directvobsub builds, arent they working rather well? http://xhmikosr.1f0.de/index.php?fol...BzL3ZzZmlsdGVy
anyone able to explain why ffdshow is going to be discontinued? are its features superfluous now or kind of included in other tools as well and people dont want to waste time for the same thing twice? if so which projects are going to replace (most of) the functions ffdshow ? LAVsplitter? mpc-hc?
Laptop Lenovo Legion 5 17IMH05: i5-10300H, 16 GB Ram, NVIDIA GTX 1650 Ti (+ Intel UHD 630), Windows 10 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64) (K-lite codec pack) Last edited by Thunderbolt8; 6th September 2011 at 15:28. |
6th September 2011, 18:21 | #13967 | Link |
_
Bah. Don't be that sad. One day, someone will feel a need for the same thing as you, and he will develop something. Think about Madshi, Nevcairiel; some time ago, nobody heard of those. Now you have good splitters, audio & video decoders, and a good renderer. In some time, someone will work on a good subtitle renderer (but maybe the best solution if it's developed by the one who works on renderer), and who knows, someone will rewrite post-processing stuff...
6th September 2011, 18:29 | #13968 | Link |
Yes, subtitles need some good solution. But it should work undepended on aplication.
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
6th September 2011, 18:39 | #13969 | Link | |
契約者
6th September 2011, 18:41 | #13970 | Link |
so which are the lastest available versions of ffdshow and which problems do they still have? 3972 can be found on xvidvideo.ru
6th September 2011, 20:24 | #13971 | Link |
ffdshow has not been discontinued. There simply won't be any significant changes for the foreseeable future. That will remain the case until new developers join the project.
Latest builds can be found on the SourceForge project page.
MPC-HC 2.2.1 |
6th September 2011, 20:42 | #13972 | Link | |
Unavailable
software d0t vladbazar d0t com :-/ Last edited by Midzuki; 6th September 2011 at 20:50. |
6th September 2011, 23:19 | #13973 | Link |
theres no ICL12 version though, arent these supposed to be faster for multithreading intel CPUs?
7th September 2011, 14:19 | #13975 | Link |
ICL12 does not have any real-life advantages. It only helps in very specific cases that do not apply to the majority of people.
Get the latest build from SourceForge and you will have a proper build with working deband. Builds you get elsewhere are possibly broken. SPP deblocking strength can be adjusted with the slider on the PP page. Move the slider to the left to lower CPU usage.
MPC-HC 2.2.1 |
7th September 2011, 14:24 | #13976 | Link |
well I use sharpening and sometimes deinterlacing. if it helps with those, then I'd need it
7th September 2011, 14:36 | #13977 | Link |
Probably little difference for those.
MPC-HC 2.2.1 |
7th September 2011, 15:49 | #13978 | Link |
little is better than nothing. no multithreading for VC-1, no DXVA with interlacing, no nothing. I need every bit I can get
7th September 2011, 16:25 | #13979 | Link |
Then go buy the compiler and built it yourself.
8th September 2011, 15:04 | #13980 | Link |
nöööö
