1st December 2022, 18:39 | #8841 | Link |
Pig on the wing
With grainy content, x265 tends to use plenty of B-frames compared to clean ones. I've always found this a bit odd, and I don't know the reason for the behaviour. Just encode any old crispy B/W movie and it's double digits for the 10 consecutive B-frames stat.
2nd December 2022, 05:57 | #8842 | Link |
Pig on the wing
Something I've noticed while testing --limit-refs and --limit-modes a bit: --no-limit-modes increases the effect of --amp quite a lot, based on what --csv-log-level 2 shows. I'd even say that without --no-limit-modes, it really makes no sense enabling --amp. I don't know if --limit-refs should affect the partition decisions at all, but --limit-refs 1 produced noticably bigger amounts of amp partitions compared to 3 and 0 in this one test of mine.
2nd December 2022, 12:54 | #8843 | Link | |
Pig on the wing
2nd December 2022, 13:59 | #8844 | Link |
Not realy, and for the very short glimpse i have made, it doesn't seem easy (or my glimpse was bad). And, unfortunately for you, as it's not a feature i'm interesting on, i'm not realy interesting in spending a lot of time for this...
My github. |
2nd December 2022, 16:23 | #8845 | Link |
Pig on the wing
Hmm.. I can affect what to write in the csv file, but I cannot figure out how to get the chosen variable value output there
7th December 2022, 19:51 | #8846 | Link | |
When trying to juggle a bunch of settings for optimal quality@perf, it's really a combination of things. I'd generally expect an --amp --rect --limit-modes --limit-refs to yield better net results in less time that just using --amp OR --rect with --no-limit-*. Similarly --tskip without --tskip-fast or --tu-inter- and -intra-depth 4 without --limit-tu 4 can slow things down to much. Better to get 75% of the value of the features in 25% of the time than none of the benefits at all. These all tend to be pretty content specific (high detail, low noise, sharp edges), so leaving them on by default without --limit* options can waste a whole lot of power & time without material benefit for the majority of GOPs. |
11th December 2022, 19:06 | #8849 | Link | |
It is related to "Scene Cut Aware QP", could not yet spot an explanation for the acronym though...
14th December 2022, 14:40 | #8853 | Link |
Hi Guys!
Does anyone know if i get better picture quality whith HEVC than HuffYUV? I think about from a video editor, both set at 100% (lowest compression). This is for max out before Youtube conversion sets in. Some say VP9 gives better dynamic and colors than AVC but is there something like this in above? Thank's for any advice! Last edited by James_b; 14th December 2022 at 14:57. |
14th December 2022, 16:48 | #8855 | Link | |
Lost my old account :(
14th December 2022, 19:08 | #8856 | Link | |
Choose UTVideo or MagicYUV, they're the best lossless codec i know, fast and efficient (doesn't mean it doesn't exist others lossless codec even better).
My github. |
14th December 2022, 21:16 | #8857 | Link |
Such tools, in general, are called "Bitrate Viewer". Not all of them support every source format, though. And please better learn what a GOP is and why the size of I, P, and B frames differs much more than the quality.
15th December 2022, 08:33 | #8859 | Link |
I need advice ... I have a shell script which is supposed to update my local copy of x265 when an update is available. This used to work flawlessly before. But now a vi opens, trying to create a text file explaining the reason for a merge. So I guess there is a flaw in my git command, and I do not understand the concept of git good enough to tell apart the meaning of many similar terms in the heap of options... How do I avoid asking back? I do not even want to commit anything on the git server, only update my local copy.
#!/bin/sh git -C /build/x265_git-git fetch -v --progress origin git -C /build/x265_git-git pull -v --no-rebase --progress origin "${1:-master}" _ PS: Maybe I should try to source /build/media-suite_helper.sh and then try to use do_vcs "https://bitbucket.org/multicoreware/x265_git.git"; but there is also a patch related to cmake library paths with L vs. l, maybe that one interfers. Last edited by LigH; 15th December 2022 at 14:21. |
15th December 2022, 14:13 | #8860 | Link |
New upload: x265 3.5+74-1ec26b9f6
[Windows][GCC 12.2.0][32/32XP/64 bit] 8bit+10bit+12bit News since v3.5+70: Code:
--scenecut-qp-config <file> File containing scenecut-aware-qp mode, window duration and offsets settings required for the masking. Works only with --pass 2 Last edited by LigH; 15th December 2022 at 14:16. |
