Old 22nd July 2009, 19:46   #4081  |  Link
LowDead
Elit Amans
@setarip_old
No warnings with Norton 360 v3.0..
//LD
LowDead is offline   Reply With Quote
Old 22nd July 2009, 19:56   #4082  |  Link
Furiousflea
Originally Posted by drmih View Post
I'll also try this later as I still have a stack of discs I have done to try and get around this.
**I'm not sure exactly what you have got working but I have 'old' discs which have the missing audio as well as one I did yesterday with the new options. I still get no audio. I assume that what you are changing is: Audio Settings->BD Audio Settings->Mix or Direct
That's correct. I even checked my original and that has no audio either (I didn't check before since I don't even watch "in movie experience" rubbish but still wanted it as an option for completeness).
However for "The Day The Earth Stood Still", that doesn't freeze on the original
Do you have a receiver that can decode TrueHD? Since with TrueHD it is still sending that through mixed with the AC3+ (when you have the setting set to "mix" in the menu you described).
To prove this quirk with the S550, you'll also notice you get no menu audio when it is set to "direct". Basically "direct" stops any "mixing" at all working. But has the benefit of outputting genuine DTSMA as opssosed to DTS. It seems that the S550 doesn't have the cpu power to decode DTSMA, mix in anything else then recode to DTSMA -> output, but it can for TrueHD.
Maybe a firmware update might fix your problem? There was a new one about a month ago.
Furiousflea is offline   Reply With Quote
Old 22nd July 2009, 20:06   #4083  |  Link
iSeries
I'm also getting the Artemis Trojan warning when trying to install latest version (using McAfee).
Something must have changed as I've never had this warning before when installing BD Rebuilder?
iSeries is offline   Reply With Quote
Old 22nd July 2009, 20:09   #4084  |  Link
Sharc
Originally Posted by setarip_old View Post
@jdobbs
Do you know what would be causing this?
I downloaded the zip of v.0.25.03 from Post #1 of this thread.
When unzipping, McAfee indicated that it was removing "Artemis" trojan.
Anyone else seeing this?
No alert here. I am also using McAfee.....
Old 22nd July 2009, 21:43   #4085  |  Link
jdobbs
And so am I.
Website: www.jdobbs.net
Old 22nd July 2009, 21:48   #4086  |  Link
jdobbs
Originally Posted by Furiousflea View Post
EDIT
Problem with freezing is still there with "The Day The Earth Stood Still"....
Also...I'm using the "keep interlaced" option and when I look at this material on my Sony S550...There are clear interlaced zig zagging present as if the player isn't even attempting to deinterlace? Is this a known bug? This is on "The Matrix" special features.
Does the freezing happen even if the same files are burned to a BD-RE? I know I tested "The Matrix" successfully, but I can't remember if I tested it on BD-9.
Old 22nd July 2009, 22:01   #4087  |  Link
setarip_old
setarip_old's Avatar
@Sharc
If you would be good enough to NOW download it again and manually scan with McAfee, does McAfee indicate anything unusual (Quarantining the .exe, etc.)?
setarip_old is offline   Reply With Quote
Old 22nd July 2009, 22:18   #4088  |  Link
Capsbackup
@jdobbs
Yes, I am using McAfee and I get this "Artemis" trojan also. I am unable to use BD-RB anymore since it gets quarrantined. I lso tried 2501, same thing. 2402 is ok though.
Capsbackup is offline   Reply With Quote
Old 22nd July 2009, 22:20   #4089  |  Link
Sharc
@Sharc
I re-downloaded it just for that purpose before I posted. I forced a scan on the downloaded .zip. No alert, no quarantining.
Old 22nd July 2009, 22:29   #4090  |  Link
Capsbackup
I just re-downloaded it also, and get the same "Artemis" trojan, and BD-RB gets quarantined. Something's up, and I am not having fun now!
EDIT:
BD-RBV02402 and BD-RBV02502 are ok, BD-RBV02501 and BD-RBV02503 are not.
Old 22nd July 2009, 22:39   #4091  |  Link
setarip_old
@Capsbackup
This is really getting weird. I just manually scanned the 25.01 zip and it is now also showing the "Artemis" trojan - despite the fact that this wasn't the case when I originally downloaded and unzipped it!
I'd been using 25.01 since the day it was issued (7/08?), without incident, until the release of 25.02.
Just as you've noted, 25.02 is OK, while 25.01 and 25.03 indicate the trojan.
I'm mystified!
I don't know if the OS has any bearing on this, but I'm seeing this anomalous behavior on a system running Vista 64 Home Edition SP2...
Old 22nd July 2009, 22:52   #4092  |  Link
Capsbackup
@setarip_old
I'm running XP Pro 32 bit with SP3.
My McAfee is the version that comes with ATT DSL.
Old 22nd July 2009, 22:52   #4093  |  Link
Sharc
Getting curious, I re-downloaded again on 2 PCs, one with McAfee enterprise and 1 with the standard version. I also forced an update of the McAfee: No alarm, nothing, all clean ....
Old 22nd July 2009, 22:57   #4094  |  Link
Bosco82
Avira is showing the TR/Crypt.XPACK.Gen - Trojan for .25.03 again so I have just disabled Avira so I can run it.
Bosco82 is offline   Reply With Quote
Old 22nd July 2009, 23:01   #4095  |  Link
jdobbs
The difference is that for that one version (I assume you mean 2502), I didn't use EXECryptor (my license ran out over that weekend). So for 2502 I used ASPROTECT. I renewed the EXECryptor license and went back to it. You need to notify McAfee -- it has to be a false positive. I've been using that package for a long time -- including all the BD Rebuilder versions.
Honestly, I know we need these virus packages because of the high number of a$$holes in the world -- but sometimes I wonder if they are more trouble than they are worth.
Old 22nd July 2009, 23:05   #4096  |  Link
Capsbackup
The difference is that for that one version 2402, I didn't use EXEncryptor (my license ran out over that weekend). I renewed the license and went back. You need to notify McAfee -- it has to be a false positive.
I can do this, but if you have ever tried to notify them before, and expect a speedy update, well.. I may as well watch my grass grow!!
Old 22nd July 2009, 23:06   #4097  |  Link
setarip_old
@jdobbs
From my previous experience with the folks at McAfee, such notification is comparable to resisting the Borg ;>}
More importantly, why would "Capsbackup" and I, both with the AT&T DSL version of McAfee be getting these presumed false positives, while you and "Sharc" are not?
Old 22nd July 2009, 23:12   #4098  |  Link
jdobbs
I can repost it with ASPROTECT instead. I'll reversion it to 0.25.4. The main reason I use these packages is because they do a checksum of the executable before they will run -- which specifically protects it from trojan attachments. With freeware, you have to do something, or some jerk will hack a virus into it's tail and post it for download somewhere.
Old 22nd July 2009, 23:16   #4099  |  Link
jdobbs
@jdobbs
Resistance is futile.
Old 22nd July 2009, 23:22   #4100  |  Link
setarip_old
@jdobbs
Please be good enough to post when you've accomplished this ;>}
