Old 13th July 2015, 13:28   #2001  |  Link
kopija
Intel is the only one doing a decent job with DXVA.
kopija is offline   Reply With Quote
Old 13th July 2015, 18:34   #2002  |  Link
amd is for sure not using bilinear in EVR. sorry this charts doesn't look correct.
Old 13th July 2015, 19:11   #2003  |  Link
dbcooper
That chart is from a forum post from 2013:
http://www.avsforum.com/forum/26-hom...ggestions.html
dbcooper is offline   Reply With Quote
Old 13th July 2015, 19:57   #2004  |  Link
nevcairiel
Its easy enough to confirm, and its not a secret that DXVA2 upscaling has nothing more than mediocre quality on most hardware.
Old 13th July 2015, 22:34   #2005  |  Link
Warner306
The DXVA portion of this chart is likely more accurate: http://forum.kodi.tv/showthread.php?...127#pid1970127.
Old 13th July 2015, 23:16   #2006  |  Link
yeah clearly not bilinear. i even did a test and i have bilinear in madVR and something way better with EVR but i'm on widnows 10 so no bug report for this right now.
Old 14th July 2015, 01:37   #2007  |  Link
kasper93
MPC-HC Developer
Native EVR scaling is something that we can make available. But is wasn't really reliable over the years. That's why it isn't available yet.
I have a request to you guys. We are receiving many crash reports related to logo/cover art handling. Unfortunately crashes occurs during clean up on MPC-HC exit. The crash reports doesn't point to the main problem and it is impossible for us to fix it without your help. Should you encounter crash during MPC-HC exiting (It is "Problem 134243") and you can reproduce the problem please tell me. Thanks.
kasper93 is offline   Reply With Quote
Old 14th July 2015, 03:26   #2008  |  Link
ndjamena
If I wanted to get MPC-HC to support iTunes m4v Final Cut Pro 608 captions would I ask THEM (MPC-HC) or one of the codec library developers?
[I got the VLC nightly to manage to pass the captions to the decoder, but now they're going to have to rewrite the decoder to get the timings right (and to prevent it from simply erasing some captions before they even get displayed).]
ndjamena is offline   Reply With Quote
Old 14th July 2015, 08:14   #2009  |  Link
madshi
And that's with the latest madVR build? A couple of months ago the way madVR did DXVA scaling, AMD drivers produced Bilinear scaling. But I changed something a couple of weeks/months ago, and I'm getting "proper" scaling now with AMD drivers. However, I'm still on Windows 8.1.
Old 14th July 2015, 10:28   #2010  |  Link
kopija
Perhaps DXVA scaling algorithm varies not by chart/software but by actual GPU (older/newer) being used?
Old 14th July 2015, 16:00   #2011  |  Link
mindbomb
I think this was introduced with their 14.12 driver. AMD had to have good scaling for their VSR feature, so they updated the video ones too.
mindbomb is offline   Reply With Quote
Old 14th July 2015, 17:25   #2012  |  Link
AMD scaling is something like lanczos3 AR i did a test and it's working in madVR too.
Old 15th July 2015, 04:12   #2013  |  Link
v0lt
Originally Posted by kopija View Post
On Nvidia no method Lanczos. Tested on sample 18x18 RGB24.
v0lt is offline   Reply With Quote
Old 15th July 2015, 08:49   #2014  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Confirm.
More testing DXVA2 scaling(MPC-BE + EVR Custom):
ATI 7750, catalyst 15.7:
Image upscaling = ~Bicubic A=-0.8
Image downscaling = Bilinear
Nvidia GTX 960, 353.30:
Image upscaling = Bilinear
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 15th July 2015, 09:16   #2015  |  Link
nevcairiel
RGB is not a good test, you need to test NV12 input for reliable results.
Old 15th July 2015, 09:24   #2016  |  Link
madshi
Exactly. Some GPU drivers switch to Bilinear (or at least to a simplified scaler) when being asked to scale RGB. E.g. I think AMD might still use something better than Bilinear, but it at least doesn't do anti-ringing, anymore, last time I checked. Testing should be done with NV12. If you want to test with RGB test images, use AviSynth's ConvertToYV12, or force LAV Video Decoder to convert the images to NV12/YV12.
Old 15th July 2015, 11:38   #2017  |  Link
Aleksoid1978
I test on NV12 output.
Old 15th July 2015, 11:59   #2018  |  Link
kasper93
MPC-HC Developer
Doesn't matter. I looked at your code, at DX9RenderingSurface level you are working on RGB surfaces. EVR Mixer does the conversion way before you apply scaling.
Old 15th July 2015, 14:08   #2019  |  Link
Aleksoid1978
Yes i know. Question - do you know how do transformation/scaling before EVR mixer.
Вut even so - it's work normal. On Intel it's give good result.
Old 15th July 2015, 16:39   #2020  |  Link
v0lt
NVIDIA Quadro 600 (v311.15)
madVR v0.88.10, DXVA2 scaling, 18x18 -> 444x444
NV12 - Bilinear
YV12 - Bilinear
YUY2 - Bilinear (green in the bottom)
AYUV - Bilinear (green in the bottom)
RGB32 - Bilinear
I changed the output type in the decoder and check the properties of the input pin of renderer. After each change the settings I restarted the player.
PS: When I increase the window for YUV formats, the madVR writes an error "-dxva processing failed".
dxva, media player classic, mpc, mpc-hc
