Old 30th November 2009, 22:40   #10661  |  Link
Polcius
Originally Posted by Snowknight26 View Post
They can, but by default they don't*.
Ok.
And do you know what deinterlacing methods both use? Or wich one gives a better quality?
Polcius is offline
Old 30th November 2009, 23:09   #10662  |  Link
kieranrk
Originally Posted by Polcius View Post
Ok.
Graphics card dependent. DXVA checker should show you which ones your card supports - Pixel Adaptive being the best.
kieranrk is offline
Old 1st December 2009, 00:50   #10663  |  Link
dleach
I noticed that MPC will save the last location of a movie played if you have the internal options set appropriately (I had to manually delete a saved location). What would be a great option is to allow saved locations AND a prompt to resume from that location or start from the beginning when you start playing a movie. If there is no previously saved location the player would just start from the beginning without a prompt.
I've integrated using this player with XBMC and see that the default player in XBMC can do this and wanted to figure out how to do this with MPC.
dleach is offline
Old 1st December 2009, 13:59   #10664  |  Link
seabro
Please Help me!!!
I can't play h264 files over MPC-HC.
I mean, any file or codec that require DXVA, I can't play.. it just wont start.
I have Radeon HD 3685 and last catalyst 9.11 (x64) installed.. on Win 7 (x64) with MPC-HC (x64)... no any codec pack, no ffdshow!
what am I doing wrong??
I know that my card support hardware decoding, but how come that it's stop working suddenly!
seabro is offline
Old 1st December 2009, 15:18   #10665  |  Link
Mercury_22
Originally Posted by seabro View Post
Please Help me!!!
Follow this steps then report back :
http://sourceforge.net/apps/trac/mpc...ing_guidelines
Intel UHD Graphics 750; Win 10 22H2
Mercury_22 is offline
Old 1st December 2009, 16:06   #10666  |  Link
littleD
littleD's Avatar
Back to 9.10. This version may be more reliable.
littleD is offline
Old 1st December 2009, 21:12   #10667  |  Link
snakemanson
how fix this problem ?
64>To compile qedit.h you must install the DirectX 9 SDK, to obtain the dxtrans.h header.
64>EVRAllocatorPresenter.cpp
64>EditListEditor.cpp
64>DX9AllocatorPresenter.cpp
64>.\DX9AllocatorPresenter.cpp(775) : error C2039: 'TryLock' : is not a member of 'CCritSec'
64>        c:\work\mpc-hc.vc9\src\filters\BaseClasses\wxutil.h(18) : see declaration of 'CCritSec'
64>.\DX9AllocatorPresenter.cpp(2175) : error C2039: 'TryLock' : is not a member of 'CCritSec'
BuildLog
snakemanson is offline
Old 1st December 2009, 21:23   #10668  |  Link
tetsuo55
MPC-HC Project Manager
hi, you need to install this:
http://www.microsoft.com/downloads/d...0-edb2df5abad4
See here for more information:
http://sourceforge.net/apps/trac/mpc...ompile_the_MPC
tetsuo55 is offline
Old 1st December 2009, 21:53   #10669  |  Link
snakemanson
DX SDK Aug09 already installed
by this guide /trunk/Compilation.txt
Old 1st December 2009, 22:11   #10670  |  Link
tetsuo55
use the wiki link, the documentation in the source is no longer accurate.
tetsuo55 is offline
Old 1st December 2009, 22:15   #10671  |  Link
snakemanson
thx, i add the new paths at the end and solved
but, i cant fix this error
Old 1st December 2009, 23:20   #10672  |  Link
tetsuo55
ok rewrote parts of the compilation guide, please try to follow each step and see what happens
tetsuo55 is offline
Old 2nd December 2009, 06:52   #10673  |  Link
Leo100
All builds, since 1312, consistently crash when opening video, complaining igdumd32.dll. This occurs in such device: Viliv S5, video - Intel GMA 500 (driver dated 14.10.2009 Driver Revision: 5.0.0.2015, version igdumd32.dll 8.14.10.2015), System - Windows 7, DirectX - the latest, in August 2009. Perhaps it has something to do with changes in 1312 Built by:
Fixed: Scanline and refresh rate detection algorithm changed
Fixed: Scanline detection and sync was incorrect on rotated displays
Fixed: D3D device interference from other threads minimized
Added: TryLock added to CCritSec
Discovered that crash in the derivation of EVR / EVR cust., VMR9 (renderless). Do not crash when the rest of the render, but dxva not work.
There is a noticeable tearing at all the options vsync in the ON position. If I disable Alternative VSync playback slows down.
Sorry for the language I used google translation.
Leo100 is offline
Old 2nd December 2009, 08:03   #10674  |  Link
tetsuo55
I think something is wrong with the GMA500 hardware/drivers.
Please report this problem to Intel.
tetsuo55 is offline
Old 2nd December 2009, 08:07   #10675  |  Link
73ChargerFan
73ChargerFan's Avatar
I'm still getting no DTS core over SPDIF, when playing mkv with DTS-MA track.
Win7 x64 RTM, MPC-HC-32 svn 1373, internal filters only (using Haali mkv doesn't work either.)
DS Audio filter shows buffer going up/down, but yet I hear nothing.
Does this explain why?
Filter : Default DirectSound Device - CLSID : {79376820-07D0-11CF-A24D-0020AFD79767}
- Connected to:
CLSID: {18C16B08-6497-420E-AD14-22D21C2CEAB7}
Filter: Audio Switcher
Pin: Out
- Connection media type:
Audio: 0x0092 48000Hz stereo 1536kbps
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71}
subtype: MEDIASUBTYPE_PCM {00000001-0000-0010-8000-00AA00389B71}
formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 4
cbFormat: 18
WAVEFORMATEX:
wFormatTag: 0x0092
nChannels: 2
nSamplesPerSec: 48000
nAvgBytesPerSec: 192000
nBlockAlign: 4
wBitsPerSample: 16
cbSize: 0 (extra bytes)
pbFormat:
0000: 92 00 02 00 80 bb 00 00 00 ee 02 00 04 00 10 00 ’...€»...î......
0010: 00 00                                           ..
- Enumerated media type 0:
Audio
AM_MEDIA_TYPE:
subtype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000}
formattype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000}
lSampleSize: 1
cbFormat: 0
tetsuo55: I can't find anyone who verifies this, next step for me is to re-install OS but that is soooo muuuuch work.
73ChargerFan is offline
Old 2nd December 2009, 08:14   #10676  |  Link
Leo100
I think the same way, but I doubt that Intel will draw attention to this problem. And, "Intel does not support this product via email." (from offsite)...
In addition, builds 1311 and earlier are working well. Maybe you can do anything from the player?
Leo100 is offline
Old 2nd December 2009, 08:17   #10677  |  Link
tetsuo55
- Connected to:
Pin: Out
AM_MEDIA_TYPE:
lSampleSize: 4
cbFormat: 18
WAVEFORMATEX:
wFormatTag: 0x0092
nChannels: 2
nBlockAlign: 4
wBitsPerSample: 16
pbFormat:
0010: 00 00                                           ..
Audio
AM_MEDIA_TYPE:
lSampleSize: 1
cbFormat: 0
please contact spec-chum about this
DXVA is very important for Intel, they will try to fix it.
tetsuo55 is offline
Old 2nd December 2009, 08:18   #10678  |  Link
73ChargerFan
Sounds like a regression in mpc-hc.
Old 2nd December 2009, 08:34   #10679  |  Link
Leo100
But DXVA works great, I now use MPC-HC build 1311 and MPCVideoDec.ax build 1356 (external), DXVA available.
Sorry, I do not propose to fall back, I suggest, if possible, to teach the player to work even on bad drivers from Intel.
Leo100 is offline
Old 2nd December 2009, 09:49   #10680  |  Link
snakemanson
new error
5>------ Rebuild All started: Project: libavcodec_gcc, Configuration: Release Win32 ------
5>Performing Makefile project actions
1>videoctl.cpp
5>Project : error PRJ0002 : Error result -1073741515 returned from 'C:\Windows\SysWow64\cmd.exe'.
5>Build log was saved at "file://c:\work\mpc-hc.vc9\src\filters\transform\mpcvideodec\ffmpeg\BuildLog.htm"
5>libavcodec_gcc - 1 error(s), 0 warning(s)
and new problem this YASM path ( is not recognized as an internal or external command)
my path:
MINGW32 — c:\mingw_msys\msys.450x64v2\mingw\
MSYS — c:\mingw_msys\msys.450x64v2\;c:\mingw_msys\msys.450x64v2\bin\
MINGW64 — c:\mingw_msys\msys.450x64v2\mingw\
..\..\..\..\lib;$(MINGW32)lib\gcc\mingw32\4.4.1;$(MINGW32)lib
this is correct ?
dxva, h264, home cinema, media player classic, mpc-hc
