23rd July 2009, 21:16 | #8701 | Link |
Using that build still shows corruption:
http://i27.tinypic.com/bfowbc.png Seems to happen after every I frame, but I can't say for sure. |
23rd July 2009, 21:22 | #8702 | Link | |
23rd July 2009, 21:27 | #8703 | Link | |
23rd July 2009, 22:09 | #8707 | Link |
I can confirm, that:
- i have wrong frame order and blockong on "mpc-hc.dxva.corruption.sample.mkv" sample - this sample have blocking problem even with Cyberlink PDVD8 PDVD8 h.264 decoder - i have wrong frame order but no blocking on "sample-001.mkv" sample - working fine with PDVD8 h.264 decoder I tryed "mplayerc_test.rar" but no change. Updated to cat. 9.7 - no change Casimir666, can i ask what GPU and OS do you have?
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin Last edited by hoborg; 23rd July 2009 at 22:26. |
23rd July 2009, 22:29 | #8708 | Link |
Might want to improve DTS Express detection, here an example: http://www.sendspace.com/file/keswl8
MPC-HC 1.2.1179 says its "Secondary DTS HD High Resolution Audio, 48.0kHz, 3chn, 576kbps" when it's actually "DTS Express, 2.0 channels, 16 bits, 192kbps, 48khz" (eac3to). DTS Express is a different format from DTS and DTS-HD. |
24th July 2009, 23:02 | #8710 | Link |
New builds
I don't have my own web space but I'm more than happy to build a normal version (I use a custom build for core2) and upload to a public site. IA32 and X64 builds are fine.
Sendspace seems OK, anyone know a better one (must be free). cheers |
24th July 2009, 23:06 | #8711 | Link |
Hardware Aspirin
mediafire, sendspace limits download speed.
Stream video on web in your quality |
24th July 2009, 23:10 | #8712 | Link |
mediafire it is then, just building 1182 now...
Having an issue with x64 builds, so will just be x86 for now. I'll fix it tomorrow... edit: OK fixed. Devs, you need to remove d2vsource from mplayerc Project Dependencies on x64 build... Links: x64 x86 Last edited by Spec-Chum; 25th July 2009 at 00:36. |
25th July 2009, 01:51 | #8713 | Link |
Audiophile
i did something to my computer and now EVR custom refuses to work. everytime i set it to EVR custom, MPC exits randomly...
regular EVR and all the other renderers work fine. I think MPC actually crashes since Haali's icon is still in the taskbar after MPC exits... using Windows XP btw. edit: tested with builds 1179 and 1180. not sure when it started since i use Haali mostly. edit2: uninstalled and reinstalled the framework. same result. Last edited by Mangix; 25th July 2009 at 02:20. |
25th July 2009, 03:27 | #8714 | Link |
Hardware Aspirin
so are these builds any different from those on xvidvid.ru ?
25th July 2009, 04:08 | #8715 | Link | |
Beyond the Corn Border
I like what you can do with the shaders, you can have two different presets using combine, and have two keyboard shorcuts to toggle them, the last state is remembered after closing. Would be nice to have the option to setup custom keyboard shortcuts for Pan&Scan individual presets, and have the last state remembered, too. And speaking of remembering the last state, how about making that After Playback defaults to Exit? Would help alot as the current Do Nothing option prevents stand-by most of the time (Always On Top does not matter). Really like the minimalistic looks, but it needs some improvement, from those nine buttons (and two sliders), three of them are unused most of the time or generating issues (Decrease speed, Increase speed, Step). How about having some Pan&Scan, Shaders, Stream Switcher etc.? Well, I guess the option to have user skins is not a priority right now. Do the shaders work in latest x64 version now? |
25th July 2009, 06:02 | #8716 | Link |
Is it just me or are iPhone 3GS videos not working well with MPC-HC?
Build 1179, Win7, Latest Nvidia drivers. I'm seeing problems with every renderer, even with Quicktime installed. 1) System Default, VMR9, and Haali all play the video 90 degrees counterclockwise and with an incorrect 4:3 ratio. 2) EVR CP doesn't play AT ALL and says at the bottom that DXVA is running. Here's a sample video from a friend's iPhone. Please confirm my findings. http://www.mediafire.com/?djogghzjv1z |
25th July 2009, 07:52 | #8717 | Link |
Hi, love the progress on MPC-HC!
Have a short question though about the current state of DXVA support with MPH-HC i.c.w. differerent GPU's - ATI: support for H264 (not e.g. L5.1 though or too many ref frames) + VC1 - NVidia: support for H264 (also L5.1 and 16 ref frames), no VC1 - Intel: ? (if I'm corrent it is supported now, but i have no idea to what extend) Note: for Nvidia I mean the newer onces (i know that since somewhere around the new version of the 8800 GTS their cards support VC1, but it does not i.c.w. MPC-HC)? Is this list correct? And what about Intel? |
25th July 2009, 07:54 | #8718 | Link |
Nope, well apart from I use GCC 4.3.3 and not 4.4.1 (although I'd be very surprised if that made a difference. I use a custom build myself (nothing major, just built specificly for Core2 arch) but these are built with all defaults.
Hope this helps Spec |
25th July 2009, 08:41 | #8719 | Link |
MPC-HC Project Manager
Anyone with compiling capabilities,
Does MPC-HC still function(or even fully compile) if you compile with these settings: x86: "/SAFESEH /O2 /GS /arch:SSE2 /EHa" x64 AMD: "/favor:AMD64 /O2 /GS /EHa" x64 INTEL: "/favor:INTEL64 /O2 /GS /EHa" x64 universal(SLOW): "/favor:blend /O2 /GS /EHa"
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
25th July 2009, 11:36 | #8720 | Link |
@hoborg, @Jong
Your problem happen only with ATI board, and I find the issue for corruption at least. Hoborg I still have little trouble with your file, some of the frame are not display in correct order. @Snowknight26 Your file didn't play on ATI board (test with Cyberlink + Microsoft Win7 decoder). No problem on my nVidia, maybe a problem with ATI driver? @Trahald Custom MMCO is now supported, and you file play fine @The1n Could you try again with new test build (if not ok would you post your screenshot on imageshark or something your previous attachement is still waiting validation)? New test build with all this changes available from here : http://www.zshare.net/download/6313488079dc9738/ To all : I'm looking for H264 samples with long reference frames inside, ans if possible MMCO commands
Tired of tearing? Try this Media Player Classic mod : http://mpc-hc.sourceforge.net Last edited by Casimir666; 25th July 2009 at 11:39. |
