14th March 2012, 21:27 | #9882 | Link |
That file must've been somehow especially broken, i have quite a bunch of other H264 files where the AR change works just fine (in all decoders).
In this file, CUVID only picks it up when i seek (for some odd reason), and QuickSync never picks it up.
14th March 2012, 22:33 | #9883 | Link | |
At all times (even while not playing a file) LAV Video says that QuickSync is not available. While playing a file it keeps showing that, and Active Decoder is set to avcodec. Dell XPS L502x, Nvidia Geforce GT 525M, Intel HD 3000 (Core i7-2630QM). Nvidia driver: Just upgraded to Verde 296.10 before. Was using 285.62 before, with the same results. Intel driver: 8.15.10.2342. Dell still hasn't upgraded to a later driver (2509 is the latest). Splitter: I get the same results with both Haali Media Splitter and LAV Splitter 0.49. OS: Windows 7 Home Premium x64 |
14th March 2012, 22:39 | #9884 | Link | |
I really had to seek a lot before it picked it up. Does it always change AR for you on the first seek ? |
14th March 2012, 22:39 | #9885 | Link |
you can already visually see that it is somehow exactly @ the switch point Cyberlink and Arcsoft get the AR change CoreAVC seems also to miss it
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 14th March 2012 at 23:11. |
14th March 2012, 22:53 | #9886 | Link | |
Life's clearer in 4K UHD
14th March 2012, 23:05 | #9887 | Link |
@Nev
this seems to be a ffmpeg issue ffplay = fail avplay = ok vlc 2.1 git = ok mirillis Hard/soft = ok CoreAVC 3.0.1 = fail Cyberlink = ok Arcsoft = ok Potplayer DXVA = ok Potplayer FFMpeg Decoder Type 2 = fail Lav Video = fail Lav Video Quicksync = fail Lav Video DXVA2 Native = ok
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 14th March 2012 at 23:27. |
14th March 2012, 23:42 | #9888 | Link |
MPC-HC Developer
It was recorded from DVB-T broadcast from Polish and I noticed earlier that there is something strange about it. For example I was trying to cut stream with Video ReDo and didn't work as it should.. Anyway there is a official forum about that DVB-T broadcast and no one complain on any technical issue.
15th March 2012, 02:53 | #9889 | Link |
what is dxva copyback performance based on?
hardware video decoder version? cause on further expection, I don't think uvd 2.0 is fast enough for this for 1080p video. Testing with a radeon 4870. The present queue in madvr is struggling to keep above 0. Last edited by mindbomb; 15th March 2012 at 06:27. |
15th March 2012, 07:31 | #9890 | Link |
Of course it was, but i already fixed it. Read what i write.
Its mostly memory copy performance. From what i've seen and heard so far, it seems fine for 24p/25p/50i/60i material on 4000 series and above cards. Some cards seem to also be able to handle 50p and 60p. Starting with the 7000 series, the speed has increased again and 50p and 60p are fine across the board. You can easily test this by running a benchmark, if your card behaves anything like the others, it should be around 50 fps. This may also be highly driver dependent, and maybe some other factors that are not known yet. PS: The present queue being 0 means your GPU is bottle-necked somewhere. If the decoder queue remains full, the decoder is running fast enough. It may be possible that the combination of the memory copys and madVRs GPU shaders is too much.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 15th March 2012 at 11:24. |
15th March 2012, 08:42 | #9891 | Link |
I have a Question and Wonder if somebody can help me
I use LAVFilters for codecs and also I use EVR I have converted some file in to MP4 format using MediaCoder. This is what Media Info Shows when about the files Code:
General Complete name : C:\Encoded\Three Kingdoms 2010\Written\Three Kingdoms ep 62 ~ Xu Chu duels Ma Chao.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 273 MiB Duration : 46mn 32s Overall bit rate mode : Variable Overall bit rate : 819 Kbps Encoded date : UTC 2012-03-02 23:14:04 Tagged date : UTC 2012-03-02 23:14:04 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 12 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 46mn 32s Bit rate : 756 Kbps Maximum bit rate : 3 256 Kbps Width : 720 pixels Height : 400 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.088 Stream size : 252 MiB (92%) Writing library : x264 core 120 r2120 0c7dab9 Encoding settings : cabac=1 / ref=12 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=756 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=2:1.00 Encoded date : UTC 2012-03-02 23:14:04 Tagged date : UTC 2012-03-02 23:14:37 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : HE-AACv2 / HE-AAC / LC Codec ID : 40 Duration : 46mn 32s Bit rate mode : Variable Bit rate : 56.0 Kbps Maximum bit rate : 64.0 Kbps Channel(s) : 2 channels / 1 channel / 1 channel Channel positions : Front: L R / Front: C / Front: C Sampling rate : 48.0 KHz / 48.0 KHz / 24.0 KHz Compression mode : Lossy Stream size : 18.6 MiB (7%) Encoded date : UTC 2012-03-02 23:14:37 Tagged date : UTC 2012-03-02 23:14:37 HomeCinema when I config Lav Video to use Intel QuickSync or CPU but when I use DXVA2-native or DXVA2 - Copy Back I get these Artifact I wonder If anybody can help me and tell which of the setting I used while encoding medias may caused such Artifacts Click Image to Enlarge Free Image Hosting thanks |
15th March 2012, 15:36 | #9894 | Link |
Hello,
Got myself a new HTPC with the following config: i3 2105 ATI 6450 Asrock H67M-ITX I got primary VGA over BIOS set to PCIE BUT MultiMonitor option set to "Enable", this way on windows 7 my main vga is ATI and the Intel HD VGA is preset over device manager. So far good, now to the point If i plug the DVI cable over the intel vga LAV Video reports that QuickSync is "Available" and i am able to use it. The issue arise when i plug the cable over the ATI vga then the QuickSync option turns into "Not Available" so i am unable to use it What i would like to know is if it is possible to use QuickSync while my main vga is ATI and the Intel HD vga is present over device manager. My idea was to use QuickSync for the video decoding and ATI for the Deinterlacing/EVR part since ATI is able to provide me with a nice 23.976. Thanx in advance. |
15th March 2012, 16:33 | #9895 | Link | |
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
15th March 2012, 16:57 | #9896 | Link |
I did install the latest version but QuickSync still is not available if my main VGA is ATI, only becomes available if Intel is the main one although Virtu reports that it is running.
Any ideas? I know we are completely offtopic here, sorry Nev. |
15th March 2012, 17:22 | #9898 | Link |
Nev,
About changing AR in middle of the stream (like the file posted) : - it works now with software mt decoding (good job btw ) - CUVID mode still fails : is there anything that you could do to make this work ? Because CUVID in CoreAVC is working, I suppose the problem lies not in behind the CUVID API, but in missing and/or wrong data send to the API. |
15th March 2012, 17:42 | #9899 | Link | |
Thanks that did the trick Currently LAV Video reports that QuickSync is "Available" and "Active" during a video playback and EVR reports that Render Device is ATI Radeon 6450!!! Am i right when i assume that Deinterlacing is done by ATI atm? Now that i got this working, may i ask if this is generaly a suggested way of watching 1080p or at least is it any better than DXVA CB? I need DXVA CB cause i am gonna apply postprocessing. |
15th March 2012, 17:48 | #9900 | Link | |
Anyway, i send the full bitstream to the CUVID decoder, there is nothing else i could send, so there is nothing "missing". CoreAVC most likely use their own bitstream parsing instead of using NVIDIAs full CUVID parser for that. Its possible to add that kind of parsing as well, of course, but for now it has a veeeeeeeeeeeeery low priority.
