13th March 2012, 21:17 | #9861 | Link |
Here is a new version with yet improved YADIF multi-threading.
In addition to multi-threading YADIF itself, i moved it onto a worker thread, so decoding and deinterlacing can run in parallel. http://files.1f0.de/lavf/LAVFilters-0.49-yadifmt2.zip Because its quite some effort to make the decoders output buffers thread-safe, i only did this for the WMV9 decoder for this version. So when testing, keep in mind that this is only effective for VC-1 interlaced samples. I do plan to do this at least for the avcodec software decoder and the DXVA2-CB decoder as well, and maybe the CUVID decoder. QuickSync is not possible right now because i cannot modify its buffer allocation, but its also not required because the decoder runs extremely fast. Performance on the sample by jmonier is now 110 fps for me with YADIF 50/60p output. Up from originally 70 with 0.49 release.
13th March 2012, 22:22 | #9864 | Link | ||
Here's my original post for you to read: Quote:
14th March 2012, 07:40 | #9866 | Link |
There is always dithering when converting YUV to RGB.
14th March 2012, 09:48 | #9867 | Link | |
QuickSync Decoder author
Does it happen for all files or just specific ones? Do you have a discrete GPU in your laptop? What driver, OS, splitter and player are you using?
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. Last edited by egur; 14th March 2012 at 13:15. |
14th March 2012, 13:31 | #9869 | Link |
I think there is no actual dependence on container.
You can try some samples from my previous post, both are in mkv container, on 295.73 whql I was able to playback one of them with CUVID acceleration, on 285.62 whql both of them play fine. That's why I asked if somebody had already tested mpeg-4 acceleration on 296.10 whql. |
14th March 2012, 17:15 | #9870 | Link | |
The first one, which did play for you with all NVIDIA drivers, did play from start to end, the second one did not; just got a black screen. After pushing the stop button on my remote i got back into the MePo GUI. So thats that. |
14th March 2012, 17:37 | #9872 | Link | |
Life's clearer in 4K UHD
14th March 2012, 17:54 | #9873 | Link |
MPC-HC Developer
@nevcairiel
Is it difficult to make detection of changes in stream aspect ratio? For example this one http://dl.dropbox.com/u/16282309/LAV/AR.2.ts at beginning it is 4:3 and than it's 16:9. When I play it with LAV video freeze on AR change, but If I load file at time where is 4:3 it play fine. It fail to change AR automatically on playback. Is it possible to make? Thanks in advance. EDIT: I have changed sample to shorter one. Last edited by kasper93; 14th March 2012 at 18:03. |
14th March 2012, 18:20 | #9874 | Link | |
14th March 2012, 19:11 | #9875 | Link | ||
14th March 2012, 19:26 | #9876 | Link | ||
Unavailable
even when I used AV Splitter instead of LAV's Last edited by Midzuki; 14th March 2012 at 19:28. Reason: clarification, add more smilies :-) |
14th March 2012, 19:42 | #9877 | Link |
MPC-HC Developer
Check if you are using LAV Video Decoder. It has nothing to do with splitter. For now it works fine with Microsoft DTV-DVD Video Decoder. FFDshow crash whole player on AR change point Anyway it's fixed in LAV and thanks for that |
14th March 2012, 20:09 | #9879 | Link |
Its only a problem if you use multi-threaded decoding and the software decoder.
14th March 2012, 20:48 | #9880 | Link |
@Midzuki
It doesn't change the AR like it should with the panorama scene, the decoder freezes @ that point Hmm Nev couldn't you by default enable to read the AR from the stream when parsing .ts streams and ignoring the actual Lav Video setting ? also with Quicksync the AR change seems to be ignored but works for DXVA2 Native.
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 14th March 2012 at 21:12. |
