10th July 2012, 08:23 | #321 | Link |
What would the syntax look like if I simply want to convert a clip with PC range luma to TV range? Would it be as simple as:
ffvideosource("file.avi") Smoothlevels(preset="pc2tv") I'm still quite a noob at Avisynth, so please excuse me for such novice questions. |
13th August 2012, 14:53 | #323 | Link | |
LaTo INV.
I will release a new version soon (I hope) with a new plugin. The code is almost finished, just need motivation to end it. The ultimate release will be after this one, when avisynth 2.6 final will come out. So it might not be before a long time. |
14th August 2012, 22:05 | #325 | Link | |
From avspmod Options -> Avisynth Function Definition Choose function, plugin or script from the tabs, define sliders, fill in the values. If you copy paste this into a text file and use the import settings from file option under Avisynth Function Definition, then open a script with some smoothadjust functions in it you should see the sliders for the functions defined below, it's a start anyway, just smoothcurve missing but 16bit versions are there. [PLUGINS] SmoothAdjust_SmoothCurve16( clip, string Ycurve="0-0;65536-65536" (""), string Ucurve="0-0;65536-65536" (""), string Vcurve="0-0;65536-65536" (""), int interp=100 (0 to 100 by 1), bool limiter=False, int TVrange=0 (0 to 2 by 1), int smooth=100 (0 to 200 by 1), int dither=50 (-1 to 100 by 1), int useMT=-1 (-1 to 16 by 1), int useOPT=-1 (-1 to 2 by 1), bool show=False, int screenW=-1 (-1 to 1 by 1), int screenH=-1 (-1 to 1 by 1), bool scale=False ) SmoothAdjust_SmoothCustom16( clip, string Yexpr="0-0;65535-65535" (""), string Uexpr="0-0;65535-65535" (""), string Vexpr="0-0;65535-65535" (""), bool limiter=False, int TVrange=0 (0 to 2 by 1), int smooth=100 (0 to 200 by 1), int dither=50 (-1 to 100 by 1), int useMT=-1 (-1 to 16 by 1), int useOPT=-1 (-1 to 2 by 1), bool show=False, int screenW=-1 (-1 to 1 by 1), int screenH=-1 (-1 to 1 by 1), bool scale=False ) SmoothAdjust_SmoothLevels( clip, int input_low=0 (0 to 255 by 1), float gamma=1.0 (0.0 to 5.0 by 0.1), int input_high=255 (0 to 255 by 1), int output_low=0 (0 to 255 by 1), int output_high=255 (0 to 255 by 1), int chroma=100 (0 to 200 by 1), int limiter=0 (0 to 2 by 1), bool TVrange=False, string preset="Default" ("fullrange"/ "pc2tv"/ "tv2pc"), int Lmode=0 (0 to 3 by 1), int darkSTR=100 (0 to 500 by 1), int brightSTR=100 (0 to 500 by 1), int Ecurve=0 (0 to 1 by 1), int Ecenter=128 (0 to 255 by 1), int protect=-1 (-1 to 255 by 1), int smooth=100 (0 to 200 by 1), int dither=-1 (-1 to 100 by 1), int useMT=-1 (-1 to 16 by 1), int useOPT=-1 (-1 to 2 by 1), bool show=False, int screenW=-1 (-1 to 1 by 1), int screenH=-1 (-1 to 1 by 1), bool scale=True ) SmoothAdjust_SmoothLevels16( clip, int input_low=0 (0 to 65535 by 1), float gamma=1.0 (0.0 to 10.0 by 0.01), int input_high=65535 (0 to 65535 by 1), int output_low=0 (0 to 65535 by 1), int output_high=65535 (1 to 65535 by 1), int chroma=100 (0 to 200 by 1), int limiter=0 (0 to 2 by 1), bool TVrange=False, string preset="fullrange" ("fullrange"/ "pc2tv"/ "tv2pc"), int Lmode=0 (0 to 3 by 1), int darkSTR=100 (0 to 200 by 1), int brightSTR=100 (0 to 200 by 1), int Ecurve=0 (0 to 1 by 1), int Ecenter=32768 (0 to 65535 by 1), int protect=-1 (-1 to 65535 by 1), int smooth=100 (0 to 200 by 1), int dither=50 (-1 to 100 by 1), int useMT=-1 (-1 to 16 by 1), int useOPT=-1 (-1 to 2 by 1), bool show=False, int screenW=-1 (-1 to 1 by 1), int screenH=-1 (-1 to 1 by 1), bool scale=False ) SmoothAdjust_SmoothTweak( clip, int brightness=0 (-255 to 255 by 1), float contrast=1.0 (0.0 to 10.0 by 1), float saturation=1.0 (0.0 to 10.0 by 1), int hue1=0 (-255 to 255 by 1), int hue2=0 (-255 to 255 by 1), bool limiter=False, bool TVrange=False, int smooth=100 (0 to 200 by 1), int dither=50 (-1 to 100 by 1), int useMT=-1 (-1 to 16 by 1), int useOPT=-1 (-1 to 2 by 1), bool show=False, int screenW=-1 (-1 to 1 by 1), int screenH=-1 (-1 to 1 by 1), bool scale=False ) SmoothAdjust_SmoothTweak16( clip, int brightness=0 (0 to 65535 by 1), float contrast=0.0 (0.0 to 10.0 by 0.1), float saturation=1.0 (0.0 to 10.0 by 0.1), int hue1=0 (-65535 to 65535 by 1), int hue2=0 (-65535 to 65535 by 1), bool limiter=False, bool TVrange=False, int smooth=100 (0 to 200 by 1), int dither=50 (-1 to 100 by 1), int useMT=-1 (-1 to 16 by 1), int useOPT=-1 (-1 to 2 by 1), bool show=False, int screenW=-1 (-1 to 1 by 1), int screenH=-1 (-1 to 1 by 1), bool scale=False ) Last edited by Yellow_; 14th August 2012 at 22:25. |
15th August 2012, 00:22 | #326 | Link |
Thanks Yellow,
I knew that is was possible to do it manually. But I just wasnt too sure the parameter for this plugin. Thank you very mutch. Is there a ( Database ) on the internet where people create the script for all kind of mods in avsp ? It would be useful. |
15th August 2012, 00:44 | #327 | Link | |
Kid for Today
A new version would be full of win, |
17th November 2012, 17:18 | #329 | Link | |
LaTo INV.
(check your MPs) |
3rd March 2013, 19:49 | #331 | Link |
One thing that would be nice to have: Autolevels, with max.change limiting, and taking the input min/max from a separate analysis clip. Current Autolevels in Coloryuv is too crude / too simple, and not (not always) temporally stable.
AutoLevels(clip, analyse_clip, darklimit, brightlimit) analyse_clip would be an (optional) user-provided preprocessed clip to take the frame's present min & max values from. - possibly: spatial smoothing to eliminate stray pixels that are very dark / very bright, but are not relevant. - possibly: temporal smoothing to make operation temporally stable, i.e. avoiding jumping-around of black level. -- but that's up to the user. darklimit & brightlimit are clamping the maximum change. I.e. if darklimit=16,brightlimit=20, then a frame covering [20,230] would be spread to [16,235], but a frame covering [50,200] would be spread to only [50-16,200+20). TV_range switch to specify wether to spread to [16,235] or to [0,255]. Just a rough outline, all points are open for discussion. What do you think about that? Feasable? Too much work / too little time?
5th March 2013, 10:57 | #332 | Link | |
It would be interesting to have cross-reference between Y, U and U in SMOOTHCUSTOM. I mean the possibility to use any of three plans (Y, U, V) in any three expressions (Yexpr, Uexpr, Vexpr). Lets say, Uexpr=U+5*(Y/255). Now it's not possible. |
5th March 2013, 14:27 | #333 | Link | |
Detail Level Adjustments ie: image frame separated into say 5 detail levels, Coarse to Fine ability to apply SmoothAdjust adjustments individually to each level to tweak contrast? Generate contrast, luma and saturation masks, apply SmoothAdjust Curve and Tweak through them. http://goodlight.us/writing/tutorials.html Last edited by Yellow_; 6th March 2013 at 22:35. |
10th March 2013, 12:03 | #335 | Link | |||
LaTo INV.
It introduced a lot of work: need to build a robust scene change detector, temporal stabilizing and put aside the not relevant values with spatial smoothing (as you said). In the end, too much work compared to my free time. Using an external clip simplifies things a lot. In a first time, why not make a standalone filter that can be integrated later into SmoothAdjust if it is convincing. But this introduces an incompatibility with SmoothTools (in version 2.50) and it bothers me a little. Quote:
I was planning a QT-Gui but too much work for now. Quote:
I don't really understand, can you elaborate please? |
10th March 2013, 19:23 | #336 | Link | |
LaTo INV.
Update 2013/03/11
So this version should be considered as beta because some bugs may occurs. Just one more thing, the v2.00 final release have been downloaded nearly 6000 times in 18 months. That's a lot but I have received only 4 donations, it's less than 0.001%... Seriously I was expecting a bit more generosity, anyways thanks to donators! So I don't know if I will still get involved much in this project, because it does not seem to interest many people in the end. That is, I stop complaining Don't hesitate to report bugs if you find some and enjoy this release! |
11th March 2013, 09:57 | #337 | Link |
You write down a function, for example "1" or "x" or "-x*(x-1)". It will then create a curve that, as closely as possible, makes the new histogram the same shape as the desired function between 0 and 1.
I realize you can't make it exact with discrete values, peaks can only be moved and added but never split up. However, this is compensated with a gap with a width proportional to the peak's height, and dithering should partly combat this (plus the result will look about correct anyway). I also realize there might be functions that mess up everything, but it's the user's fault if he uses one. |
11th March 2013, 22:22 | #338 | Link | |
LaTo INV.
14th March 2013, 16:45 | #339 | Link |
Hi!
Im using these Ylevels settings: YLevelsg(1,0.65,255,1,255) YLevelsc(1,0.5,255,1,255) but I want to remove the banding can I get same result with smoothlevels? What smoothlevels settings are the equivalent for: Ylevelsg Ylevelsc I ask because Im testing but I cannt get same results.. maybe Im missing some parameter. Last edited by travolter; 14th March 2013 at 16:52. |
14th March 2013, 17:10 | #340 | Link |
With version 2.50, my typical use of SmoothCurve always triggers an "Access violation" error.
SmoothCurve(YCurve="0-0;16-16;128-126;255-235") Code:
Avisynth: access violation at 0x0001E4D5 in C:\Program Files (x86)\AviSynth 2.5\plugins\SmoothAdjust.dll, attempting to read from 0x00000000 I tried both ICL and MSVC builds of SmoothAdjust.dll (x86 only). Enabling or disabling MT mode (with SetMTMode) doesn't change anything. With SmoothAdjust-2.0, SmoothCurve is working fine. |
