Old 21st March 2004, 21:27   #1  |  Link
bocinko
@jdobbs:
I tried DVD-RB with ReJig for short time result.
Program looks fine, final DVD worked good but nero
said - Realocation Failed. I never burn any DVD
if nero gives me that message.
If i Used IfoUpdate [excelent tool] and then IfoEdit again
after encoding with DVD2DVD-R
or DoItFast4U it takes much longer, but nero
didn't gives me that message.
I know that DVD will works if realocation is wrong
[maybe wrong is wrong word in this case] but i use some
DVD's later for another [later] processing so i need it 100%
[as originals].
[by the way - I use DVDshrink for test. If SHRING read
reencoded DVD with no problems i'm sure it will work with
any reauthoring software]
After using DVD-RB - fails Nero's realocation and also DVDshrink's analyze. [i tried to find realocation word in this forum but no results found]
Where's the problem ???
And One request ...
is possible to replace one of AC3 with external one in your DVD-RB ?
If isn't, may be ? ... in future.
I want to do some DVD's dubbed with my 3rd world language
and until today i did them over 20, but it takes me ages and ages to do that.
thanx
sorry for my english [that's what i want my lang dubbed DVD's]
keep your great work alive.
thanx
...B
bocinko is offline   Reply With Quote
