10th December 2008, 00:45 | #7303 | Link |
Is there/will there be a way to remove pulldown from already made remuxes? I just checked a bunch old HD DVD remuxes in tsmuxer and it detects the video as 29.97fps with pulldown. I tried to output as a Blu-ray disc, but it failed to work. It couldn't remove the pulldown or fix the framerate. Using tsmuxer on a recently remuxed HD DVD, it detects the video as 23.976 and outputs perfect Blu-ray disc structure, perfect for burning. So anyway to fix those old HD DVD remuxes? Unfortunately I sold most of them...
10th December 2008, 01:23 | #7304 | Link |
FLAC encoder callback errors
I have been ripping with eac3to for some time and I have never really had any major issues, but now all of a sudden when I rip, I get the following error regardless of what title I try to rip:
"One of the FLAC encoder's callbacks returned a fatal error" I was on version 2.78 and just upgraded to 2.80, but the issue remains. I rebooted the machine as well to no avail. Other than installing the latest Intel graphics/HDMI driver (I have a G45 based motherboard), I have not changed anything recently in my Vista 32-bit environment. Here are some examples of the error: The Untouchables: The Hunt for Red October: Eac3to errors out after a few minutes of processing, something like 4 "-"s or so, so it's not instant. I can rip these titles just fine to hd using AnyDVD HD, and then run eac3to on the files on the hd, but why would I be getting this error all of a sudden when pointing eac3to directly to the BD disc in the drive? Any ideas? Thanks! Last edited by crazydane; 10th December 2008 at 05:23. |
10th December 2008, 01:43 | #7305 | Link | |
l, r, c, lfe, BackL, BackR, SideL, SideR Code:
sox -M FL.wav FR.wav FC.wav LF.wav BL.wav BR.wav SL.wav SR.wav multichannel.wav
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 10th December 2008 at 01:49. |
10th December 2008, 02:07 | #7306 | Link | |
However, some enlightenment would be appreciated about how this all works. When I used EVOdemux to create the H264 stream I got this: Code:
Complete name :E:\FEATURE_1_MERGED.H.264.stream.0.mpv Format : AVC Format/Info : Advanced Video Codec File size : 22.3 GiB Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16/9 Frame rate : 29.970 fps Standard : Component Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive When I muxed this into an mkv (no audio) I got this: Code:
Complete name : E:\ToNMT\Babel.mkv Format : Matroska File size : 22.3 GiB Duration : 2h 23mn Overall bit rate : 22.2 Mbps Encoded date : UTC 2008-12-09 00:33:12 Writing application : eac3to Writing library : Haali DirectShow Matroska Muxer 1.8.122.18 Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Muxing mode : Container profile=Unknown@0.0 Codec ID : V_MPEG4/ISO/AVC Duration : 2h 23mn Bit rate : 21.4 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16/9 Frame rate : 23.976 fps Standard : Component Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Code:
eac3to v2.80 command line: "E:\eac3to275\eac3to.exe" "D:\Babel\BABEL\HVDVD_TS\FEATURE_1.EVO"+"D:\Babel\BABEL\HVDVD_TS\FEATURE_2.EVO" 3: "E:\ToNMT\Babel.mkv" ------------------------------------------------------------------------------ EVO, 1 video track, 2 audio tracks, 6 subtitle tracks, 2:23:29 "Main Movie" 1: Joined EVO file 2: Chapters, 24 chapters with names 3: h264/AVC, 1080p24 /1.001 (16:9) with pulldown flags 4: E-AC3, English, 5.1 channels, 1536kbps, 48khz, dialnorm: -27dB, 1918ms 5: E-AC3, French, 5.1 channels, 1536kbps, 48khz, dialnorm: -27dB, 1918ms 6: Subtitle, English 7: Subtitle, English, "SDH" 8: Subtitle, French 9: Subtitle, Spanish 10: Subtitle, English, "Forced" 11: Subtitle, French, "Forced" [v03] Extracting video track number 3... [v03] Removing h264 pulldown... [v03] Muxing video to Matroska... Added fps value to MKV header. Video track 3 contains 206438 frames. eac3to processing took 19 minutes, 56 seconds. Done. Last edited by jimz06; 10th December 2008 at 02:41. |
10th December 2008, 02:43 | #7307 | Link | |
10th December 2008, 10:14 | #7309 | Link | |||
tebasuna51 is usually right. Just as in this case. |
10th December 2008, 20:34 | #7311 | Link |
FLAC encoding is hardcoded to max compression level and I don't plan on changing that because I think the compression speed is good enough. So IMHO there's no need to make things more complicated by adding further options just to save a tiny bit of time.
10th December 2008, 23:35 | #7312 | Link |
Location: The Great North (the better half of North America)
Just curious...
As to why when a DTS track is encoded using Surcode it is 1536kb/s, then when the Zero Padding is removed it is reported as 1510kb/s? MediaInfo and tsMuxeR both report as 1536kb/s.
Another question... whenever I convert a THD track to PCM it always starts as ....24bit.pcm until the actual bit depth is revealed later in the conversion where it reports a constant bit depth of 16 bits. I'm assuming the PCM output will actually be 16 bits... correct? Thanks for the time. Code:
eac3to v2.78 command line: e3\eac3to f: 1) 2: c:\videos\tdk\tdk.vc1 4: c:\videos\tdk\tdk.thd+ac3 4: c:\videos\tdk\tdk.pcm 4: c:\videos\tdk\tdk.dts 8: c:\videos\tdk\subs1.sup ------------------------------------------------------------------------------ M2TS, 1 video track, 5 audio tracks, 5 subtitle tracks, 2:32:13 1: Chapters, 40 chapters 2: VC-1, 1080p24 /1.001 (16:9) 3: AC3, English, 5.1 channels, 640kbps, 48khz 4: TrueHD/AC3, English, 5.1 channels, 48khz (embedded: AC3, 5.1 channels, 640kbps, 48khz) 5: AC3 Surround, English, 2.0 channels, 192kbps, 48khz 6: AC3, French, 5.1 channels, 640kbps, 48khz 7: AC3, Spanish, 5.1 channels, 640kbps, 48khz 8: Subtitle (PGS), English 9: Subtitle (PGS), French 10: Subtitle (PGS), Spanish 11: Subtitle (PGS), French 12: Subtitle (PGS), Spanish [v02] Extracting video track number 2... [a04] Extracting audio track number 4... [a04] Extracting audio track number 4... [a04] Extracting audio track number 4... [s08] Extracting subtitle track number 8... [a04] Extracting TrueHD stream... [a04] Extracting TrueHD stream... [a04] Decoding with libav/ffmpeg... [a04] Decoding with libav/ffmpeg... [a04] Swapping endian... [a04] Writing WAVs... [a04] Remapping channels... [a04] Creating file "c:\videos\tdk\tdk.24bit.pcm"... [v02] Creating file "c:\videos\tdk\tdk.vc1"... [a04] Creating file "c:\videos\tdk\tdk.thd+ac3"... [a04] Creating file "c:\videos\tdk\tdk.L.wav"... [a04] Creating file "c:\videos\tdk\tdk.R.wav"... [a04] Creating file "c:\videos\tdk\tdk.C.wav"... [a04] Creating file "c:\videos\tdk\tdk.SR.wav"... [a04] Creating file "c:\videos\tdk\tdk.LFE.wav"... [a04] Creating file "c:\videos\tdk\tdk.SL.wav"... [s08] Creating file "c:\videos\tdk\subs1.sup"... [a04] The original audio track has a constant bit depth of 16 bits. [a04] The zero bytes were successfully removed. [a04] The original audio track has a constant bit depth of 16 bits. Encoding DTS <1536kbps> with Surcode...Found Surcode DTS Encoder version 1.0.21.0. Surcode encoding successfully started. Please wait... Closing Surcode... Video track 2 contains 218979 frames. eac3to processing took 49 minutes, 32 seconds. Surcode encoding took 27 minutes, 18 seconds. Done. eac3to v2.78 command line: e3\eac3to c:\videos\tdk\tdk.dts c:\videos\tdk\tdk_fixed.dts ------------------------------------------------------------------------------ DTS, 5.1 channels, 2:32:13, 24 bits, 1510kbps, 48khz Removing DTS zero padding... Creating file "c:\videos\tdk\tdk_fixed.dts"... eac3to processing took 2 minutes, 52 seconds. Done. |
11th December 2008, 05:58 | #7314 | Link |
Got a question.
For streaming, the PS3 sadly supports only DD. 2.0 for VC-1 in a WMV container. So, I go to thinking the following: what if you were to 'matrix-encode' five disccrete channels of audio, ala the Dolby ProLogic II scheme, onto a 640kbps DD 2.0 stream in such a way that a Dolby ProLogic II decoder could split those matrixed channels back to the original five channels, would that work? I mean, to take an existing DD 5.1 stream, and turn it into a 2.0 stream that Dolby ProLogic II could then extract more-or-less the same original channels from. Would be a nice trick to get near DD 5.1 sound (whilst it really is just DD 2.0 surround). Question, of course, is: can eac3to do it? Can it convert a DD 5.1 track to a Dolby ProLogic II 'splittable' 2.0 track? I mean, the -down convert would have to follow the exact Dolby ProLogic II scheme, as if it were a Dolby ProLogic II encoder, as it were. It's kinda early here (near 6 AM, and I've yet to turn in, LOL), so I may be missing somehing; but with a 640kbps 2.0 stream, I don't see how you couldn't at least get a half-way decent Dolby ProLogic II 5.1 result from it (and thus be able to bypass the need to reencode VC-1 content when streaming). Feel free to enlighten me (or desillusion me, whichever the case may be).
Gorgeous, delicious, deculture! |
11th December 2008, 08:17 | #7315 | Link | ||||
Agreed. Quote:
Half-way decent sounds about right. |
11th December 2008, 11:45 | #7317 | Link | |
You can always acces to all command line parameters for a encoder using the pipe option: Code:
eac3to.exe <input> stdout.wav <eac3to_parameters> | <encoder> <full_encoder_parameters> <-> <output> Example: eac3to.exe input.ac3 stdout.wav | neroaacenc -ignorelength -q 0.23 -lc -if - -of output.m4a
11th December 2008, 19:19 | #7319 | Link |
got a problem with a TrueHD track here:
50mb sample: http://www.sendspace.com/file/y2diub Code:
eac3to v2.80 command line: eac3to X:\movie 1) 2: G:\movie.mkv 3: G:\movie.flac 3: G:\movie.thd 5: G:\moviecomment1.ac3 6: G:\moviecomment2.ac3 9: G:\movie.sup ------------------------------------------------------------------------------ M2TS, 1 video track, 4 audio tracks, 5 subtitle tracks, 2:04:01 1: Chapters, 29 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: TrueHD/AC3, English, 5.1 channels, 48khz, dialnorm: -27dB (embedded: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB), -13ms 4: TrueHD/AC3, Japanese, 5.1 channels, 48khz, dialnorm: -27dB (embedded: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB), -13ms 5: AC3, English, 2.0 channels, 256kbps, 48khz, dialnorm: -27dB, -13ms 6: AC3, English, 2.0 channels, 256kbps, 48khz, dialnorm: -27dB, -13ms 7: Subtitle (PGS), Japanese 8: Subtitle (PGS), Japanese 9: Subtitle (PGS), English 10: Subtitle (PGS), Japanese 11: Subtitle (PGS), Japanese [a03] Extracting audio track number 3... [v02] Extracting video track number 2... [a03] Extracting audio track number 3... [a06] Extracting audio track number 6... [a05] Extracting audio track number 5... [s09] Extracting subtitle track number 9... [a03] This track is not clean. [a03] This track is not clean. [a03] Extracting TrueHD stream... [v02] Muxing video to Matroska... [a03] Extracting TrueHD stream... [a03] Removing TrueHD dialog normalization... [a03] Decoding with libav/ffmpeg... [libav] Stream parameters not seen; skipping frame [a03] The libav decoder output an unexpected bitdepth (1). Aborted at file position 49152. Code:
G:\eac3to>eac3to X:\movie 1) 2: G:\movie.mkv 3: G:\movie.flac -nero 3: G:\movie.thd 5: G:\moviecomment1.ac3 6: G:\moviecomment2.ac3 9: G:\movie.sup M2TS, 1 video track, 4 audio tracks, 5 subtitle tracks, 2:04:01 1: Chapters, 29 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: TrueHD/AC3, English, 5.1 channels, 48khz, dialnorm: -27dB (embedded: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB), -13ms 4: TrueHD/AC3, Japanese, 5.1 channels, 48khz, dialnorm: -27dB (embedded: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB), -13ms 5: AC3, English, 2.0 channels, 256kbps, 48khz, dialnorm: -27dB, -13ms 6: AC3, English, 2.0 channels, 256kbps, 48khz, dialnorm: -27dB, -13ms 7: Subtitle (PGS), Japanese 8: Subtitle (PGS), Japanese 9: Subtitle (PGS), English 10: Subtitle (PGS), Japanese 11: Subtitle (PGS), Japanese [a03] Extracting audio track number 3... [v02] Extracting video track number 2... [a03] Extracting audio track number 3... [a06] Extracting audio track number 6... [a05] Extracting audio track number 5... [s09] Extracting subtitle track number 9... [a03] This track is not clean. [a03] This track is not clean. [v02] Muxing video to Matroska... [a03] Extracting TrueHD stream... [a03] Extracting TrueHD stream... [a03] Removing TrueHD dialog normalization... [a03] Decoding with DirectShow (Nero Audio Decoder 2)... [a03] Removing TrueHD dialog normalization... [a05] Removing AC3 dialog normalization... [a06] Removing AC3 dialog normalization... [a03] DirectShow reports 5.1 channels, 24 bits, 48khz [a03] Applying RAW/PCM delay... [a03] This audio track contains more than 16 bits of information. [a03] Encoding FLAC with libFlac... [a03] Creating file "G:\movie.thd"... [a03] Creating file "G:\movie.24bit.flac"... [a06] Creating file "G:\moviecomment2.ac3"... [a05] Creating file "G:\moviecomment1.ac3"... [s09] Creating file "G:\movie.sup"... [a03] Original audio track, L+R+C+LFE: constant bit depth of 16 bits. [a03] Original audio track, BL+BR: constant bit depth of 24 bits. [a03] Processed audio track, L+R+C+LFE: constant bit depth of 16 bits. [a03] Processed audio track, SL+SR: constant bit depth of 24 bits. [a03] Audio has a gap of 8ms at playtime 0:00:00. [a03] The audio file was demuxed without making use of the gap/overlap information. [a03] Please rerun the same eac3to command line. That will correct the gaps/overlaps. [a03] Audio has a gap of 8ms at playtime 0:00:00. [a03] The audio gaps/overlaps technically can't be removed from the TrueHD bitstream. [a03] In order to remove them you'll have to transcode the audio to another format. Added fps value to MKV header. Video track 2 contains 178415 frames. eac3to processing took 59 minutes, 53 seconds. Done. Code:
eac3to v2.80 command line: eac3to X:\movie 1) 2: G:\movie.mkv 3: G:\movie.flac -nero 3: G:\movie.thd 5: G:\moviecomment1.ac3 6: G:\moviecomment2.ac3 9: G:\movie.sup ------------------------------------------------------------------------------ M2TS, 1 video track, 4 audio tracks, 5 subtitle tracks, 2:04:01 1: Chapters, 29 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: TrueHD/AC3, English, 5.1 channels, 48khz, dialnorm: -27dB (embedded: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB), -13ms 4: TrueHD/AC3, Japanese, 5.1 channels, 48khz, dialnorm: -27dB (embedded: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB), -13ms 5: AC3, English, 2.0 channels, 256kbps, 48khz, dialnorm: -27dB, -13ms 6: AC3, English, 2.0 channels, 256kbps, 48khz, dialnorm: -27dB, -13ms 7: Subtitle (PGS), Japanese 8: Subtitle (PGS), Japanese 9: Subtitle (PGS), English 10: Subtitle (PGS), Japanese 11: Subtitle (PGS), Japanese Audio gap description file detected, will be used for processing... Audio gap description file detected, can't be used for TrueHD/MLP, though. [a06] Extracting audio track number 6... [v02] Extracting video track number 2... [a03] Extracting audio track number 3... [a03] Extracting audio track number 3... [s09] Extracting subtitle track number 9... [a05] Extracting audio track number 5... [a03] This track is not clean. [a03] This track is not clean. [v02] Muxing to Matroska... [a03] Extracting TrueHD stream... [a03] Extracting TrueHD stream... [a03] Decoding with DirectShow (Nero Audio Decoder 2)... [a03] Removing TrueHD dialog normalization... [a03] Removing TrueHD dialog normalization... [a05] Removing AC3 dialog normalization... [a06] Removing AC3 dialog normalization... [a03] DirectShow reports 5.1 channels, 24 bits, 48khz [a03] Applying RAW/PCM delay... [a03] This audio track contains more than 16 bits of information. [a03] Encoding FLAC with libFlac... [a03] Creating file "G:\movie.thd"... [a03] Creating file "G:\movie.24bit.flac"... [a05] Creating file "G:\moviecomment1.ac3"... [a06] Creating file "G:\moviecomment2.ac3"... [s09] Creating file "G:\movie.sup"... [a03] Original audio track, L+R+C+LFE: constant bit depth of 16 bits. [a03] Original audio track, BL+BR: constant bit depth of 24 bits. [a03] Processed audio track, L+R+C+SL+SR: max 24 bits, average 19 bits. [a03] Processed audio track, LFE: max 23 bits, average 16 bits. [a03] Audio has a gap of 8ms at playtime 0:00:00. [a03] The audio gaps/overlaps technically can't be removed from the TrueHD bitstream. [a03] In order to remove them you'll have to transcode the audio to another format. Added fps value to MKV header. Video track 2 contains 178415 frames. eac3to processing took 1 hour, 1 minute. Done. and when gaps are detected, is there a way to find out if the delay needed is positive or negative? then it would be possible to add that delay to the demuxed truehd track at a later point. Last edited by Thunderbolt8; 11th December 2008 at 21:19. |
11th December 2008, 21:47 | #7320 | Link |
Report on Mask BD, Extra stream 00024.m2ts using eac3to v2.78
This is the first time I've encountered this, so I thought I'd post it here. Code:
eac3to v2.78 command line: eac3to 2) 2: extra.mkv ------------------------------------------------------------------------------ M2TS, 1 video track, 5 audio tracks, 2 subtitle tracks, 0:27:17 1: Chapters, 2 chapters 2: VC-1, 480p24 /1.001 (3:2) with pulldown flags 3: AC3 Surround, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 4: AC3 Surround, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 5: AC3 Surround, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 6: AC3 Surround, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 7: AC3 Surround, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 8: Subtitle (PGS), English 9: Subtitle (PGS), German [v02] Extracting video track number 2... [v02] Removing VC-1 pulldown... [v02] Muxing video to Matroska... [v02] Video overlaps for 1 frames at playtime 0:00:00. [v02] Video overlaps for 1 frames at playtime 0:00:00. . . [v02] Video overlaps for 1 frames at playtime 0:34:01. [v02] The MKV file was created without making use of the gap/overlap information. [v02] Please check whether audio is in sync. If it is in sync everything is fine. [v02] Otherwise you can ask eac3to to repeat the muxing. It will then automatically [v02] make use of the detailed gap/overlap information. Added fps value to MKV header. Video track 2 contains 49058 frames. and a playtime of 0:34:06, which is precisely 30/24 times the correct playtime 0:27:17. Running the command second time used the gaps file and the new mkv file has the correct video length. The playtime of the first mkv file was checked using mpc-hc 918 and MediaInfo 0.7.7.4. --------------------------------------------- This number of video overlaps in a file necessitates a second run. fyi --------------------------------------------- edit: This didn't work as I thought. The video jitters and jutters every few seconds. Last edited by 73ChargerFan; 12th December 2008 at 01:41. Reason: changed mind |
eac3to |
