#3081 | Link |
Lovely, tanx P
#3083 | Link |
Big Bit Savings Now !
Woohoo ! Donation on the way.
https://forum.doom9.org/showthread.p...28#post2014728 Still via this ? https://buymeacoffee.com/pinterf Or if paypal, PM me.
#3084 | Link | |
#3085 | Link | |
See My Avisynth Stuff |
#3088 | Link | |
Do I have to install the runtimes ? Is the Intel build better (faster) on an Intel CPU ?
Live and let live Last edited by gispos; 15th February 2025 at 17:15. |
#3089 | Link | |
Acid fr0g
![]() I am using ICX build with AvsPmod with no problems here.
@turment on Telegram |
#3091 | Link |
Runtimes are probably needed, but I cannot check since I already have them on my machine because of the tests. The Intel build should be quicker. In this case, the XP builds are using the Visual Studio 2017 compiler, so they probably lack all the 2019 and 2022 Microsoft compiler optimizations. Even if the Intel build were equal to an MSVC 2022 build, the XP builds using 2017 technology are probably slower. However, this may be an urban legend. I guess, the actual speed gain is negligible unless you do synthetic tests using only internal Avisynth functions without using external scripts.
#3092 | Link | |
Why XP builds ? What build should I use for Ryzen CPU's, using W11 Pro ? |
#3093 | Link | |
Broadcast Encoder
![]() As a bit of history, Avisynth has been supporting Windows 98SE and Windows 2000 since its inception on May 19th, 2000. The last Avisynth version, 2.6.1, from 2016, still supported them. When Avisynth+ arrived it brought plenty new things like high bit depth planar support (before we only had stacked and interleaved) and it was a major upgrade from the classic codebase. Support for Windows 98SE and Windows 2000 was dropped and the minimum requirement was bumped up to Windows XP which is still the case right now. ![]() Last edited by FranceBB; 16th February 2025 at 13:42. |
#3094 | Link | |
#3095 | Link | |
Broadcast Encoder
![]() Full disclosure: I've been an AMD fanboy since birth, I owned plenty of CPUs the likes of AMD Athlon 1600, AMD Athlon 3200, AMD Athlon 3800, those were great monocore CPUs. Unfortunately, when multi core were introduced, I had one heartbreak after another, starting with the AMD Athlon 64 X2 but the one that made me draw the line was when my AMD Phoenom II X6 1100T, a 6c/6th at 3.3GHz (with boost to 3.7GHz) was being beaten by 4c/8th Intel i7 and was struggling even against 4c/4th Intel i5 of the time. Three years later, in 2013, I moved to Intel and I've never looked back. |
#3096 | Link | |
The optimizations applied in our builds are generic "optimize for speed" settings, making them suitable for any processor architecture. It's a one-size-fits-all approach. Even Intel processor generations vary, so if someone wants a finely tuned version for their specific processor type, they would need to do it themselves. Most of the internal optimizations in Avisynth are handcrafted for SSE2, SSSE3, SSE4.1, AVX2, etc. While not all are implemented, SSE2 and AVX2 are generally covered. Only a few areas have versions written solely in C. Compilers can further optimize our already SIMD-optimized versions, which is where different compilers like Intel C++ Compiler, LLVM, GCC, and MSVC can excel or fall short. In general, they all do excellent jobs. |
#3097 | Link | |
I have a majority of Ryzen's, but I do have a 13900KF, which is only a little "slower" than my 7950X. I recently built a 32C Thread Ripper system, but haven't really done anything with it yet. Last edited by TR-7970X; 16th February 2025 at 14:32. |
#3098 | Link | |
#3099 | Link |
21 years and counting...
I just updated AVS+ from an older build, 4066 IIRC, to the latest version.
Now I get an error in of my scripts saying "There is no function named 'ConvertToDoubleWidth' ". Would appreciate some help on how to fix this. |
