24th April 2008, 01:05 | #4421 | Link | |
If you rename the file to testDTS.dts you can decode, resample and split in monowavs with BeHappy. You can also convert the dtswav to dts with: BeSplit -core( -input testDTS.wav -prefix xxx_ -type dtswav -fix ) The xxx_01.dstwav obtained work now with eac3to. |
24th April 2008, 01:43 | #4424 | Link | |
D:\Video\eac3to>eac3to y:\HVDVD_TS\feature_district_13.evo 2: f:\b13\b13-vid.mkv 3: f:\b13\b13-aud.ac3 -640 -libav EVO, 1 video track, 3 audio tracks, 2 subtitle tracks, 1:24:32 "feature" 1: Chapters, 16 chapters without names 2: VC-1, 1080p24 /1.001 (16:9) 3: E-AC3, English, 5.1 channels, 640kbit/s, 48khz, dialnorm: -27dB, -9ms 4: TrueHD, English, 5.1 channels, 48khz, dialnorm: -27dB, 12ms 5: E-AC3, French, 5.1 channels, 640kbit/s, 48khz, dialnorm: -27dB, -9ms 6: Subtitle, English, "SDH" 7: Subtitle, Spanish Extracting primary video track... Muxing video to Matroska... Extracting audio track number 3... Removing dialog normalization... Applying (E-)AC3 delay... Remapping channels... Loading white noise (needed for dithering)... Encoding AC3... Creating file "f:\b13\b13-aud.ac3"... Added fps value to MKV header. eac3to processing took 25 minutes, 40 seconds. Done. Code:
D:\Video\eac3to>eac3to y:\HVDVD_TS\feature_district_13.evo EVO, 1 video track, 3 audio tracks, 2 subtitle tracks, 1:24:32 "feature" 1: Chapters, 16 chapters without names 2: VC-1, 1080p24 /1.001 (16:9) 3: E-AC3, English, 5.1 channels, 640kbit/s, 48khz, dialnorm: -27dB, -9ms 4: TrueHD, English, 5.1 channels, 48khz, dialnorm: -27dB, 12ms 5: E-AC3, French, 5.1 channels, 640kbit/s, 48khz, dialnorm: -27dB, -9ms 6: Subtitle, English, "SDH" 7: Subtitle, Spanish Code:
D:\Video\eac3to>eac3to x:\BDMV\STREAM\00002.m2ts 1: f:\wonder\wonder-vid.mkv 2: f:\wonder\wonder-aud.ac3 -640 -libav M2TS, 1 video track, 3 audio tracks, 1:34:17 1: h264/AVC, 1080p24 /1.001 (16:9) 2: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz, -6ms 3: AC3, English, 5.1 channels, 448kbit/s, 48khz, dialnorm: -27dB, -27ms 4: AC3, French, 5.1 channels, 448kbit/s, 48khz, dialnorm: -27dB, -27ms The libav DTS decoder doesn't decode the full DTS-HD information. Extracting primary video track... Extracting audio track number 2... Extracting DTS core... Applying DTS delay... Muxing video to Matroska... Remapping channels... Loading white noise (needed for dithering)... Encoding AC3... Creating file "f:\wonder\wonder-aud.ac3"... Added fps value to MKV header. eac3to processing took 42 minutes, 6 seconds. Done. D:\Video\eac3to>eac3to eac3to v2.41, freeware by madshi.net P.S. On the M2TS the video was a bit hashed during the credits. The rest of the movie appears fine but I need to umm watch it all the way through to be sure. Do not think this is from eac3to but thought I'd mention it, only noticed it when checking the X264 compressed version, not yet checked original. The BD went from 29Gig to 7.5Gig and I thought surely there was a problem since I transcode at VERY high quality. Odd.... <shrug> Last edited by BLKMGK; 24th April 2008 at 01:46. |
24th April 2008, 02:18 | #4425 | Link |
I am sorry to confirm the frame count problem:
eac3to v2.41 command line: eac3to "H:\Testosteron HD DVD 1080p VC-1 DD+ 5.1" 1) 1: c:\tes\tes.txt 2: c:\tes\tes.mkv 3: c:\tes\tes.ac3 4: c:\tes\tes.dtshd 5: c:\tes\tes.sup ------------------------------------------------------------------------------ EVO, 1 video track, 2 audio tracks, 1 subtitle track, 1:56:31 "MainMovie" 1: Chapters, 18 chapters with names 2: VC-1, 1080p30 /1.001 (16:9) 3: E-AC3, English, 5.1 channels, 768kbit/s, 48khz, dialnorm: -27dB 4: DTS Hi-Res, English, 5.1 channels, 16 bits, 2082kbit/s, 48khz, dialnorm: -4dB 5: Subtitle, English Creating file "c:\tes\tes.txt"... Extracting primary video track... Extracting audio track number 4... Muxing video to Matroska... Extracting audio track number 3... Removing dialog normalization... Removing dialog normalization... Patching bitdepth to 24 bits... Decoding with DirectShow (Nero Audio Decoder 2)... Disabling DRC for Nero (E-)AC3 decoding... DirectShow reports 5.1 channels, 24 bits, 48khz Encoding AC3... Extracting subtitle track number 5... Creating file "c:\tes\tes.dtshd"... Creating file "c:\tes\tes.ac3"... Creating file "c:\tes\tes.sup"... Added fps value to MKV header. eac3to processing took 14 minutes, 48 seconds. Done. |
24th April 2008, 05:16 | #4426 | Link | |||||||||
when tried to decode the TrueHD track from Resident Evil Extinction Blu-ray that is demuxed with xport 1.01, eac3to 2.41 says: Quote:
24th April 2008, 07:59 | #4427 | Link |
eac3to v2.42 released
http://madshi.net/eac3to.zip Code:
* added support for 16bit DTSWAV files * fixed: Blu-Ray TrueHD support was broken |
24th April 2008, 15:50 | #4432 | Link |
got a problem with a 1280x1024 mpeg2 29.97 fps .ts file regarding audio sync. the video is being mistaken by eac3to as 24p and there are as well audio gaps (basically for half of all seconds of the movie/sample duration). the problem is that even when using the gaps file at the 2nd run and even when forcing -60i the audio is still a little out of sync.
made a little sample (unfortunately you most likely wont be able to test sync with that as theres not much dialogue in the movie): http://www.sendspace.com/file/azbq4w Last edited by Thunderbolt8; 24th April 2008 at 16:35. |
25th April 2008, 00:45 | #4434 | Link |
I've just found the weirdest thing I've ever come across. I ripped my copy of the HD-DVD Ocean's Thirteen a while back. Everything was fine and then I discovered there are supposed to be forced subtitles so, recently I ripped it again as eac3to can now grab the subtitles and chapters. I went through the process of converting the audio to flac, muxing the flac, chapters and subtitles to a new mkv file and playing it back. After a little messing around I was able to get the subs working just fine.....and then I noticed that I couldn't really hear any dialogue!
I checked my center speaker and it was definitely working. When there's music playing the center channel seems to be working OK, but any time there's dialogue you can hardly hear it. I tried other movies and they are working fine. It's like the center channel has been seriously attenuated, or perhaps it's something to do with dialnorm not being removed? I don't really know - I'm just throwing ideas around. The graph I create in graphedit is the same as every other movie with VC1 video & flac audio. The only difference is the inclusion of the VS filter for the subs. However, I tried the graph without the VS filter and it made no difference to the center channel problem. I did the recent rip using eac3to v2.40. I've just upgraded to v2.42 so I'm going to go through the whole rip & remux process again to see if it makes a difference, but if anyone has any ideas in the meantime, or has experienced something similar, I'd be glad to hear from you. |
25th April 2008, 17:40 | #4437 | Link | |
run them through TSRemux first. I got a successful method figured out which works reliable (for me). http://forum.doom9.org/showthread.php?t=137113 mike Last edited by mikeathome; 25th April 2008 at 17:45. |
25th April 2008, 22:32 | #4438 | Link |
Im having a problem with a truehd file its from Spider-man 2 it comes up with libav Lossless check failed- expected 5a, calculated 2f and it goes on from there with other check failed.
So what might be the problem here? I have tried this with a buddys copy of Spider-man 2 and get the same results. Plus this is the only movie i have ever had a problem with. ------------------------------------------------------------------------------ M2TS, 1 video track, 2 audio tracks 1: h264/AVC, 1080p24 /1.001 (16:9) 2: TrueHD/AC3, English, 5.1 channels, 48khz 3: TrueHD/AC3, English, 5.1 channels, 48khz Track 2 is used for destination file ".dts". Extracting audio track number 2... Extracting TrueHD stream... Writing WAVs... Creating file ".L.wav"... Creating file ".R.wav"... Creating file ".SL.wav"... Creating file ".SR.wav"... Creating file ".C.wav"... Creating file ".LFE.wav"... [libav] Lossless check failed - expected 5a, calculated 2f [libav] Lossless check failed - expected 4b, calculated c4 [libav] Lossless check failed - expected cf, calculated c5 [libav] Lossless check failed - expected 5d, calculated da [libav] Lossless check failed - expected d, calculated 47 [libav] Lossless check failed - expected 25, calculated c9 [libav] Lossless check failed - expected fc, calculated c5 [libav] Lossless check failed - expected 12, calculated dd [libav] Lossless check failed - expected 27, calculated cf [libav] Lossless check failed - expected 2a, calculated ef Found Surcode DTS Encoder version 1.0.23.0. Surcode encoding successfully started. Please wait... Closing Surcode... eac3to processing took 29 minutes, 9 seconds. Surcode encoding took 25 minutes, 34 seconds. Done. Last edited by DoomBot; 26th April 2008 at 16:58. |
26th April 2008, 20:46 | #4439 | Link |
Thanks a lot Madshi for the great tool! So far all non-branching BD .m2ts files I've run through have been flawless and totally straightforward. Good work!
I know Madshi said he plans to add a merge feature for branching titles. In the meantime, does anyone have a recommendation for how to do seamless branching titles? I tried merging the files with tssplitter but that resulted in an .m2ts file with an error in it (the player won't seek past the merge point and eac3to reports a corrupt file). I was wondering whether using eac3to on the separate files, then copy /b the video.mkv files together (same for audio) before merging with mkvmerge, would work? Other approaches? Thanks! |
26th April 2008, 22:22 | #4440 | Link | |
http://forum.doom9.org/showthread.php?t=134104 |
eac3to |
