3rd February 2014, 20:35 | #1221 | Link | |
--[no-]force-start .............. Next job will [not] be started immediately --[no-]force-enqueue ............ Next job will [not] be appended to queue Last edited by johnchoi; 3rd February 2014 at 20:44. |
7th February 2014, 14:05 | #1222 | Link |
Software Developer
Simple x264 Launcher v2.31 has been released.
9th February 2014, 20:24 | #1224 | Link |
Software Developer
No, the download link was okay. Just the wrong name for the correct file. Should be fixed now
20th February 2014, 07:22 | #1226 | Link |
Hi, today when I was trying to encode a dvd, the process ended with an error after three hours. Here the error message from the log.
av2y [info]: xyz.avs: 720x550, 60000/1001 fps, 523236 frames av2y [info]: error: Unknown ResampleHQ internal error. occurred while reading frame 139815 WARNING: Input process exited with error (code: 1), your encode might be *incomplete* !!! |
20th February 2014, 11:44 | #1227 | Link | |
Software Developer
Seems pretty obvious where the problem occurred:
BTW: You are using "stable" Avisynth or Avisynth-MT or Avisynth+ ???
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 20th February 2014 at 21:25. |
20th February 2014, 21:25 | #1229 | Link |
Software Developer
Try stable Avisynth 2.5 with one of the built-in resize filters. You can still try the "fancy" stuff once you have a working baseline.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 20th February 2014 at 22:47. |
22nd February 2014, 04:17 | #1230 | Link | |
And for this program, can you add a confirm pop up if the user click abort job, just in case any misclick. Also, can you add a button or context menu option to open the output folder for the selected job? |
22nd February 2014, 05:02 | #1231 | Link | |
Software Developer
Right-click -> "Explore job" should do exactly this
22nd February 2014, 06:11 | #1232 | Link | |
Good to know that , didn't understand what it meant before. |
26th February 2014, 18:58 | #1233 | Link |
Software Developer
x265 support has arrived
Here is a new experimental build with rudimentary x265 encoding support:
http://sourceforge.net/projects/muld...6.exe/download
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 27th February 2014 at 23:01. |
28th February 2014, 15:29 | #1234 | Link |
I've been using simple x264 for a while now with no troubles, I updated to the latest and greatest and I get this error
your revision of x264 is too old. I've tried updating to the latest x264 and I get the same error. I've been replacing the x264 .exes in here C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2\toolset is that right? I'm running a 64 bi win 8 machine |
28th February 2014, 18:45 | #1235 | Link | |
Software Developer
Of course the x264 binaries that ship with Simple x264 Launcher will be at least that revision, to make sure that everything works out-of-the-box. Why not simply stick with the provided binaries?
28th February 2014, 19:30 | #1236 | Link |
Detection of AVS properties does not work for my simple script.
Simple x264 Launcher (Build #808), built 2014-02-26 Job started at 2014-02-28, 19:23:10. Source file : C:\temp\RipBot264temp\job1\job1.avs Output file : C:\Users\Dave\Desktop\job1.mkv --- SYSTEMINFO --- Binary Path : C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2 Avisynth : Yes VapourSynth : N/A --- SETTINGS --- Encoder : x265 (H.265/HEVC), x64, 8-Bit Source : Avisynth (avs) RC Mode : CRF Preset : Medium Tuning : None Profile : Auto Custom : (None) --- CHECK VERSION --- Detect video encoder version: Creating process: "C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2\toolset\x64\x265_8bit_x64.exe" --version x265 [info]: HEVC encoder version 0.7+232-fec3cab870437c10 x265 [info]: build info [Windows][GCC 4.8.2][64 bit] 8bpp x265 [info]: using cpu capabilities: MMX2 SSE SSE2Fast SSSE3 SSE4.2 AVX Detect video source version: Creating process: "C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2\toolset\x86\avs2yuv_x86.exe" Avs2YUV 0.24bm2 > x265 version: 0.7+232 > Avs2YUV version: 0.24.2 --- GET SOURCE INFO --- Creating process: "C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2\toolset\x86\avs2yuv_x86.exe" -frames 1 C:\temp\RIPBOT~1\job1\job1.avs NUL FAILED TO DETERMINE AVS PROPERTIES !!! Code:
DirectShowSource("C:\Users\Dave\Desktop\112.MTS",audio=false)
28th February 2014, 19:39 | #1237 | Link | |
Software Developer
"C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2\toolset\x64\x265_8bit_x64.exe" -frames 1 C:\temp\RIPBOT~1\job1\job1.avs NUL
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 28th February 2014 at 19:42. |
28th February 2014, 19:52 | #1238 | Link |
It works in console but not in gui
28th February 2014, 20:09 | #1239 | Link |
Software Developer
That doesn't make much sense to me. Does it only happen with DirectShowSource() or with other scripts too?
28th February 2014, 20:32 | #1240 | Link | |
LoadPlugin("..\RawSource.dll") video1=RawSource("E:\_Video_Samples\y4m\crowd_run_1080p50.y4m") video2=RawSource("E:\_Video_Samples\y4m\park_joy_1080p50.y4m") video3=RawSource("E:\_Video_Samples\y4m\ducks_take_off_1080p50.y4m") video4=RawSource("E:\_Video_Samples\y4m\in_to_tree_1080p50.y4m") video5=RawSource("E:\_Video_Samples\y4m\old_town_cross_1080p50.y4m") return video1+video2+video3+video4+video5 Code:
LoadPlugin("\DGDecode.dll") video=MPEG2Source("C:\Temp\RipBot264temp\job3\job3.d2v") Check this video https://mega.co.nz/#!pE0E2QyQ!vn7Gqy...ZkOekzORgbj7XA
