Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 10th January 2019, 12:09   #141  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ChangeLog for ffhevc 3.6.6
* Support Dolby Vision HDR
Old 11th January 2019, 14:14   #142  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.6.7
* Check if tonemap is used and if so, disable Dolby Vision questions
Old 12th January 2019, 12:03   #143  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.6.8
* Set Open GOP to 0 and repeat headers to 1 when Dolby Vision is used
Old 2nd March 2019, 08:07   #144  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.6.9
* Add HDR_SUPPORT option to config file for making HDR support optional
Old 13th June 2019, 03:35   #145  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.7.0 and ffx264 3.7.1
* Added support for the bm3d denoise filter
Old 12th July 2019, 15:00   #146  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.7.1
* Updated the default encoding params. Added the new hme (hierarchical motion search) and hme-search options. Also lowered rd to 4 and increased subme to 4. To use hme, the latest x265 from git is required
Old 23rd July 2019, 12:23   #147  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.7.2 and ffx264 3.7.2
* Added support for crop preview using MPlayer when autocrop is enabled in the config file. This was ported over from my h264enc script
Old 1st August 2019, 18:21   #148  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffx264 3.7.3
* Switch to using -x264-params instead of -x264opts. The latter will be eventually removed from FFmpeg
Old 3rd August 2019, 11:48   #149  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.7.3
* Update default encoding options
Old 5th August 2019, 15:14   #150  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.7.4
* Update default encoding options v2
Old 21st August 2019, 15:37   #151  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.7.5
* Add audio sample rate to the audio metadata
* Fixed a bug in the audio resample code where sample rate wasn't detected due to wrong value used (bit_rate instead of sample_rate)
ChangeLog for ffx264 3.7.4
Old 29th August 2019, 08:57   #152  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.7.6 and ffx264 3.7.5
* Use a comma instead of a dash for the audio sample rate metadata
Old 5th September 2019, 04:32   #153  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.7.7 and ffx264 3.7.6
* Code optimization in the audio sample rate metadata
Old 13th September 2019, 15:14   #154  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.7.8 and ffx264 3.7.7
* Add audio channel metadata when using audio copy
Old 18th September 2019, 09:00   #155  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.7.9 and ffx264 3.7.8
* Improvements to the audio copy metadata
Old 19th September 2019, 05:01   #156  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.8.0 and ffx264 3.7.9
* Support encoding to WMAv1 and WMAv2 audio
* Update high bit depth pixel formats options
* Add WMAv1 and WMAv2 audio detection metadata when doing audio copy
Old 21st September 2019, 06:33   #157  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.8.1 and ffx264 3.8.0
* Add side channel info to the audio metadata
Old 22nd September 2019, 05:55   #158  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.8.2 and ffx264 3.8.1
* For audio stream copy, in case ffprobe reports channels layout as unknown, try to guess the amount of channels based on channel detection and use that as metadata
* Set Mobisu transform as default for HDR to SDR
* Updated the man page
Old 25th September 2019, 07:27   #159  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.8.3
* Use the audindex[i] variable for audio metadata during audio copy
* Updated default encoding options. Requires latest x265 from git
* Updated default audio bitrates for some codecs
ChangeLog for ffx264 3.8.2
Old 25th September 2019, 11:10   #160  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 3.8.4 and ffx264 3.8.3
* Revert using audindex[i] var for audio metadata detection
