1st May 2011, 17:41 | #2222 | Link |
DD+ is just broken in ffdshow, there is no hardware limitation.
Does DTS itself work, from the same stream?
1st May 2011, 17:43 | #2223 | Link | ||
1st May 2011, 17:46 | #2224 | Link |
TrueHD works fine. DTS core works, as well from the same file that wasn't working with DTS-HD MA. So it's just DTS-HD MA that has the problem.
1st May 2011, 18:05 | #2226 | Link |
DTS-HD MA works fine for me. Does it no work on any disc?
I tried, for example, on the m2ts version of this: http://www.avsforum.com/avs-vb/showthread.php?t=1330124
1st May 2011, 18:07 | #2227 | Link |
Also, as before, attach debugger on a debug build.
1st May 2011, 18:12 | #2229 | Link |
Awesome Nev
Here are my findings, with Direct Sound renderer MKV, DTS/DTSHD: Only work with AVI<->AC3/DTS between LAV Splitter and Audio MKV, DTS-ES Matrix: 1st time I see this on AVR Bluray (Eagle Eye), TrueHD,: Cant connect to audio renderer M2TS (Sample posted earlier), TrueHD: Works fine MKV,DD: Working fine. MPEG-TS,DD: Most crash on start when bitstreaming, normal decoding ok. If you need me to test anything let me know
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) |
1st May 2011, 18:12 | #2230 | Link | |
So, i guess, yes. For 100% perfect audio and video, with bitstreaming, it needs to be a exact multiple of the fps. That doesn't make any sense, the connection between LAV Splitter and LAV Audio should always work - unless you turned one of the formats off in the config.
1st May 2011, 18:13 | #2231 | Link |
Gonna build it now. It works for nVidia, not AMD. Need to try something first to see if makes any difference. Nope...I took ReClock out of the mix. Same deal. Ok, building a debug version.
1st May 2011, 18:16 | #2232 | Link | |
XForm In Code:
Filter : AVI<->AC3/DTS - CLSID : {93230DD0-7B3C-4EFB-AFBB-DC380FEC9E6B} - Connected to: CLSID: {171252A0-8820-4AFE-9DF8-5C92B2D66B04} Filter: LAV Splitter Pin: Audio - Connection media type: Audio: DTS 48000Hz 6ch 1536kbps AM_MEDIA_TYPE: majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_DTS {E06D8033-DB46-11CF-B4D1-00805F6CBBEA} formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 256000 cbFormat: 18 WAVEFORMATEX: wFormatTag: 0x0008 nChannels: 6 nSamplesPerSec: 48000 nAvgBytesPerSec: 192000 nBlockAlign: 12 wBitsPerSample: 16 cbSize: 0 (extra bytes) pbFormat: 0000: 08 00 06 00 80 bb 00 00 00 ee 02 00 0c 00 10 00 ....€»...î...... 0010: 00 00 .. Code:
Filter : AVI<->AC3/DTS - CLSID : {93230DD0-7B3C-4EFB-AFBB-DC380FEC9E6B} - Connected to: CLSID: {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491} Filter: LAV Audio Decoder Pin: XForm In - Connection media type: Audio: DTS 48000Hz stereo 1536kbps AM_MEDIA_TYPE: majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71} subtype: Unknown GUID Name {00002001-0000-0010-8000-00AA00389B71} formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 18 WAVEFORMATEX: wFormatTag: 0x2001 nChannels: 2 nSamplesPerSec: 48000 nAvgBytesPerSec: 192000 nBlockAlign: 1 wBitsPerSample: 16 cbSize: 18 (extra bytes) pbFormat: 0000: 01 20 02 00 80 bb 00 00 00 ee 02 00 01 00 10 00 . ..€»...î...... 0010: 12 00 .. - Enumerated media type 0: Set as the current media type
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) Last edited by VipZ; 1st May 2011 at 18:19. |
1st May 2011, 18:21 | #2233 | Link |
@nevcairiel:
Any chance to add support in LAVF audio decoder to be able to connect with MS DVD navigator ?
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
1st May 2011, 18:27 | #2235 | Link | |
The only thing that would make it break would be a sample rate of 0 in the media type. Especially the only when bitstreaming .. that doesn't make any sense. I also cannot reproduce it here.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 1st May 2011 at 18:31. |
1st May 2011, 18:31 | #2236 | Link |
Uhhhhh, Nev? This seems bad man. So, I fully removed ReClock from the chain this time (forgot I had it set to always load...sigh). On my AMD equipment, LAV Audio is no longer used for DTS at ALL unless I uncheck the DTS-HD MA bitstreaming checkbox. Then it'll do DTS bitstreaming. If I leave DTS-HD MA checked, it falls back to other decoders. Hell, I uninstalled ffdshow completely, unregistered the ArcSoft audio decoder, and it fell back to the microsoft decoder for DTS! So, something's wrong.
1st May 2011, 18:32 | #2237 | Link |
It doesn't even work anymore if you disable bitstreaming at all?
Also, please post the output media type of ffdshow while bitstreaming DTS-HD MA.
1st May 2011, 18:35 | #2238 | Link |
Oh sure now that I uninstalled ffdshow. Give me a few minutes as I just got the debug version built and installed. I'm saying that if I uncheck the DTS-HD MA bitstream option, then LAV Audio accepts the connection, however. Even if I leave the core DTS bitstream option checked. I'm saying that if I have the DTS-HD MA bitstream option checked, LAV Audio refuses the connection and it goes to another decoder instead. How whacked is that?
1st May 2011, 18:36 | #2239 | Link |
This is exactly my issue, the AVI<->AC3/DTS filter doesn't appear if I deselect DTS-HD decoding. So I assume yours isn't working because AVI<->AC3/DTS isn't getting loaded.
1st May 2011, 18:37 | #2240 | Link |
May be stupid, but can be this caused by registry prefered decoder selection under Win7?
