5th February 2009, 04:20 | #3941 | Link | |
Change ; CheckRequiredSoftware=1 to CheckRequiredSoftware=0 And software will work.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
5th February 2009, 04:30 | #3942 | Link |
Sometimes the COPY STREAM option for Audio is unavailable to me. I'll select the video element, and BLU-RAY DISC for output, then my .ac3 track which is usually the disc original e.g. 640Mbps 6 channel, but despite that I've selected Blu-ray as the output option RipBot won't give me COPY STREAM as an option--I'll get instead 2ch Aften in a few bitrates e.g. 192 and 256 etc. I have this problem too - No audio file is seen in the audio box - but you can browse to it and then Xcopy will appear. Also many saved preferences ( saved in RipBot264.ini ) do not show - such as profile, desired bitrate and output path. This is using XP pro SP3. Seems like this version has many incomptiblities with Xp - will stick with 1.12.0 until fixed). |
5th February 2009, 05:31 | #3943 | Link |
Thanks for v1.13.0, Atak. I made a few changes in the .ini to suit my needs better, but I've been wondering if there's a way I can add a few other output file sizes to the file size list, simply for convenience purposes?
5th February 2009, 08:09 | #3944 | Link |
@survivant001
does this key exists? HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\GNU\ffdshow Revision value must exists and must be higher than 2633
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 5th February 2009 at 08:13. |
5th February 2009, 12:12 | #3947 | Link |
FishmanMod Android Dev
After shutting off the ver Check to get passed the Haali Media Splitter issue... got a font install for Vista and Windows 7 with a reboot. I'm running Win XP
Now after choosing the file to encode, I get this error. LINK
"Cinderella story, out of nowhere, former greenskeeper, now about to become the Masters champion. It looks like a mirac- it's in the hole!" Last edited by Fishman0919; 5th February 2009 at 12:47. |
5th February 2009, 14:36 | #3949 | Link | |
http://www.free-codecs.com/download/...a_Splitter.htm then it told me it had it installed, even though the details on version was exactly the same. |
5th February 2009, 15:40 | #3951 | Link |
Aging Video Hobbyist
I changed the ini file and that seemed to work for me.
I've wondered though if the issue is as simple as "different versions of Windows in different countries & time zones result in a different creation date for Haali". Maybe if you alter the date with Attribute Changer or something then RipBot will stop complaining... |
5th February 2009, 16:04 | #3952 | Link | |
EDIT: I've now tried 1.12.0 and 1.11.5 and even re-installed old Haali and still no good. Wonder if RipBot264 depends on anything else in my setup that might be amiss. Using XP Pro x64 here (and am now going to try my old P4 machine). Last edited by laserfan; 5th February 2009 at 19:25. |
5th February 2009, 17:04 | #3953 | Link |
I tried using v1.13.0 last night and am having some problems. I bypassed the check (i have the latest of the 3 required) and tried encoding The Bourne Supremacy (BD). I loaded up the .ts (contained only the video) and the .dts track, cropped the black bars and set the output as an mkv. When I hit start, couple seconds passed and 'All Jobs Finished' came up. Not exactly sure why this happened since I encoded the same movie with v1.12.0 and it worked just fine.
Now if I'm not mistaken, with v1.13.0 the CUT function is always on? If that's the case, it doesn't reflect it in the menu for v1.13.0. If the video was slightly longer than the audio in v1.12.0 and you switched between CUT and OFF, you could clearly see the difference. With v1.13.0, it doesn't show that anymore. |
5th February 2009, 22:18 | #3956 | Link | ||
Using StoreTempFilesin=D:\ for now Quote:
5th February 2009, 23:01 | #3957 | Link | ||
@survivant001 Report this small revision problem to that guy. Quote:
5th February 2009, 23:25 | #3958 | Link |
I dont care so should you
Once a patched build is available a New Installer will be as well.
My Installer's || |
