20th December 2013, 22:31 | #1982 | Link |
ok, I`ve got the other vs filter in there now...
Microsoft Windows [Version 6.2.9200] (c) 2012 Microsoft Corporation. All rights reserved. C:\Windows\System32> C:\Windows\System32>"C:\PROGRA~1\Hybrid\mencoder.exe" -lavdopts threads=8 -of ra wvideo -o NUL -ovc raw -vf scale,format=i420 -forcedsubsonly -nosub -nosound "E: \ENCODES\Hybrid\temp folder\encodingTempAvisynthSkript_21_06_55_9710.avs" MEncoder Redxii-SVN-r36557-4.6.3 (i686) (C) 2000-2013 MPlayer Team Compiled against FFmpeg version N-59209-gf5d0398 Build date: Thu Dec 19 00:31:55 EST 2013 success: format: 0 data: 0x0 - 0x24a libavformat version 55.22.100 (internal) AVS file format detected. VIDEO: [YV12] 1280x720 12bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s) [V] filefmt:38 fourcc:0x32315659 size:1280x720 fps:23.976 ftime:=0.0417 Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 Opening video filter: [format fmt=i420] Opening video filter: [scale] ========================================================================== Opening video decoder: [raw] RAW Uncompressed Video Movie-Aspect is undefined - no prescaling applied. [swscaler @ 015f96e0]using unscaled yuv420p -> yuv420p special converter Selected video codec: [rawyv12] vfm: raw (RAW YV12) ========================================================================== C:\Windows\System32> |
20th December 2013, 22:52 | #1984 | Link |
ok, used installer to get the basic stuff back..
with original vsfilter (the avisynth plugin pack u sent me the other day) Code:
Microsoft Windows [Version 6.2.9200] (c) 2012 Microsoft Corporation. All rights reserved. C:\Windows\System32>"C:\PROGRA~1\Hybrid\mencoder.exe" -lavdopts threads=8 -of ra wvideo -o NUL -ovc raw -vf scale,format=i420 -forcedsubsonly -nosub -nosound "E: \ENCODES\Hybrid\temp folder\encodingTempAvisynthSkript_21_06_55_9710.avs" MEncoder Redxii-SVN-r36533-4.6.3 (C) 2000-2013 MPlayer Team Compiled against FFmpeg version N-58748-gbe99054 Build date: Thu Dec 5 02:04:38 EST 2013 success: format: 0 data: 0x0 - 0x24a libavformat version 55.22.100 (internal) AVS file format detected. VIDEO: [YV12] 1280x720 12bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s) [V] filefmt:38 fourcc:0x32315659 size:1280x720 fps:23.976 ftime:=0.0417 Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 Opening video filter: [format fmt=i420] Opening video filter: [scale] ========================================================================== Opening video decoder: [raw] RAW Uncompressed Video Movie-Aspect is undefined - no prescaling applied. [swscaler @ 0217c220]using unscaled yuv420p -> yuv420p special converter Selected video codec: [rawyv12] vfm: raw (RAW YV12) ========================================================================== C:\Windows\System32> Code:
Microsoft Windows [Version 6.2.9200] (c) 2012 Microsoft Corporation. All rights reserved. C:\Windows\System32> C:\Windows\System32>"C:\PROGRA~1\Hybrid\mencoder.exe" -lavdopts threads=8 -of ra wvideo -o NUL -ovc raw -vf scale,format=i420 -forcedsubsonly -nosub -nosound "E: \ENCODES\Hybrid\temp folder\encodingTempAvisynthSkript_21_06_55_9710.avs" MEncoder Redxii-SVN-r36533-4.6.3 (C) 2000-2013 MPlayer Team Compiled against FFmpeg version N-58748-gbe99054 Build date: Thu Dec 5 02:04:38 EST 2013 success: format: 0 data: 0x0 - 0x24a libavformat version 55.22.100 (internal) AVS file format detected. VIDEO: [YV12] 1280x720 12bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s) [V] filefmt:38 fourcc:0x32315659 size:1280x720 fps:23.976 ftime:=0.0417 Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 Opening video filter: [format fmt=i420] Opening video filter: [scale] ========================================================================== Opening video decoder: [raw] RAW Uncompressed Video Movie-Aspect is undefined - no prescaling applied. [swscaler @ 0217c220]using unscaled yuv420p -> yuv420p special converter Selected video codec: [rawyv12] vfm: raw (RAW YV12) ========================================================================== C:\Windows\System32> |
21st December 2013, 10:01 | #1988 | Link |
Argh, problem is that I can't really pin down the source of the problem.
Using LWLibavVideoSource on different places during 25%, 36%, 61%, but always during 1st pass so far, for FFmpegSource it sometimes crashes on the frist sometimes on the second path, also always on different positions. With DGDecNV as decoder, the encoding ran through without a problem so far. -> doing further testing update: now I got a crash with DGDecNV too Last edited by Selur; 21st December 2013 at 10:30. |
6th January 2014, 02:57 | #1991 | Link |
First I would like to thank the programmer for this suberb tool.
Second, I would like to suggest that the program load the last used settings the next time it is used. I still have to set the resize each encode, and the default output folder. Very small inconveniences though. Otherwise running beautifully. |
6th January 2014, 05:57 | #1992 | Link |
Hybrid has multiple options to save settings, see: [Info] About profiles and saving settings,....
-> if users really want/need it I can add an 'auto save defaults' on close without a problem. Regarding remembering the resolution, you might also want to check if you want to enable "Crop/Resize->Misc->Keep resize for new source" and if you really want to always have the same output resolution, you probably would either have to enable 'Letterbox' or disable 'Picture Resize->Auto adjust'. Cu Selur |
13th January 2014, 22:48 | #1993 | Link |
hi, After processing a few files i noticed the file sizes where smaller than expected,..... and turns out that I`ve got no video being muxed into the .m2ts.
process: No global profile used PATH dirs adjusted subs = passthru (Automation) output container + .m2ts `file mode` as input audio `custom` video `x264` (hybryd default...1 pass) + resize (for speed.) changed output to `.m2ts ` selected .mkv as input file (happens with other source inputs too).. set x264 hybrid default and set a small reizse resolution. I never get any errors in Hybrid, But i only get audio in the output file. If I set another container as the output, all is fine (only .m2ts that the issue.) If I use the old Hybrid binary (the one thats in the current Installer), the .m2ts are created properly, including the video track. thanks. |
15th January 2014, 21:27 | #1996 | Link |
hi, that first test i did with the test version u sent me worked fine, however...I have a `m2ts file / creating structure- error code 0` on a new mkv source file.
same job as before but a different source .mkv debug: https://www.dropbox.com/s/9631zpz144dupfe/HybridDebugOutput.txt cheers. PS: gonna try n quickly do same job with a different source to see if its the source file... |
15th January 2014, 21:34 | #1997 | Link |
Muxing options seem to be fine:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr --vbv-len=500 V_MPEG4/ISO/AVC, "E:\ENCODES\Hybrid\temp folder\Rocky.1976.1080p.INTERNAL.MULTI.BluRay.x264_17_38_25_0110_06.264", fps=23.976, ar=1:1 (Square), lang=eng A_AC3, "E:\ENCODES\Hybrid\temp folder\iId_2_aid_0_lang_fr_17_38_25_0110_01.ac3" A_AC3, "E:\ENCODES\Hybrid\temp folder\iId_1_aid_0_lang_fr_17_38_25_0110_03.ac3" S_TEXT/UTF8, "E:\ENCODES\Hybrid\Rocky.1976.1080p.INTERNAL.MULTI.BluRay.x264_id_3_lang_fr.srt",font-name=Arial,font-size=60,font-color=0x00FFFFFF,font-charset=1,bottom-offset=16,font-border=1,text-align=center,video-width=1920,video-height=1040,fps=23.976, lang=fre S_TEXT/UTF8, "E:\ENCODES\Hybrid\Rocky.1976.1080p.INTERNAL.MULTI.BluRay.x264_id_4_lang_en.srt",font-name=Arial,font-size=60,font-color=0x00FFFFFF,font-charset=1,bottom-offset=16,font-border=1,text-align=center,video-width=1920,video-height=1040,fps=23.976, lang=eng Code:
"C:\PROGRA~1\Hybrid\tsMuxeR.exe" "E:\ENCODES\Hybrid\temp folder\Rocky.1976.1080p.INTERNAL.MULTI.BluRay.x264_17_38_25_0110__09.meta" "E:\ENCODES\Hybrid\Rocky.1976.1080p.INTERNAL.MULTI.BluRay.x264.m2ts" (using a different tsMuxeR version might also help,..) |
15th January 2014, 21:39 | #1998 | Link |
all i get is thsis:
Microsoft Windows [Version 6.2.9200] (c) 2012 Microsoft Corporation. All rights reserved. C:\Windows\System32> C:\Windows\System32> C:\Windows\System32>"C:\PROGRA~1\Hybrid\tsMuxeR.exe" "E:\ENCODES\Hybrid\temp fol der\Rocky.1976.1080p.INTERNAL.MULTI.BluRay.x264_17_38_25_0110__09.meta" "E:\ENCO DES\Hybrid\Rocky.1976.1080p.INTERNAL.MULTI.BluRay.x264.m2ts" Network Optix tsMuxeR. Version 2.4.1(b). www.networkoptix.com Decoding H264 stream (track 1): Profile: High@4.1 Resolution: 1920:1040p Frame rate: 23.976 0.0% complete H264 bitstream changed: insert nal unit delimiters Decoding AC3 stream (track 2): Bitrate: 448Kbps Sample Rate: 48KHz Channels: 5.1 Decoding AC3 stream (track 3): Bitrate: 320Kbps Sample Rate: 48KHz Channels: 5.1 Decoding PGS stream (track 4): Resolution: 1920:1080 Frame rate: 23.976 Decoding PGS stream (track 5): Resolution: 1920:1080 Frame rate: 23.976 B-pyramid level 1 detected. Shift DTS to 2 frames Invalid SRT format. "003D93E0" is invalid timing info C:\Windows\System32> |
21st January 2014, 11:21 | #2000 | Link |
Hybrid rev 2014.01.21.1:
*changed*
Cu Selur |
