Old 8th June 2009, 11:56   #1  |  Link
gowthamhk
Any opensource MPEG-2 decoder with DXVA
I did some search to come up for nothing on any open source MPEG-2 decoder with DXVA support as well. I was wondering MPC supports DXVA for H264 but not for MPEG2.
If anybody knows any open source MPEG-2 decoder with DXVA support, Please reply.
Thanks
gowthamhk is offline   Reply With Quote
Old 8th June 2009, 18:34   #2  |  Link
tetsuo55
MPC-HC Project Manager
Mpeg2 is so relatively easy to decode in software that no-one has done this yet.
only a small sampling of videocards actually have hardware mpeg2 decoding.(most of it is assisted decoding which no open source application supports)
tetsuo55 is offline   Reply With Quote
Old 8th June 2009, 21:38   #3  |  Link
Mangix
Audiophile
the Microsoft decoder that comes with Vista and Windows 7 uses DXVA. but hardware acceleration is a bit useless for MPEG2...
Mangix is offline   Reply With Quote
Old 8th June 2009, 21:40   #4  |  Link
tetsuo55
It's not open source though
Old 9th June 2009, 05:43   #5  |  Link
gowthamhk
Hi tetsuo55 and Mangix, Thanks for your info
Even though its a relatively simple decoder, I wanted to use it to take off the load from CPU as much as possible. For that I thought of referring one if available.
Old 11th June 2009, 07:51   #6  |  Link
gowthamhk
ModeMPEG2_VLD support GPU
DXVA1.0 spec talks about Slice Control Buffers for off-host VLD processing. But I use nVidia Quadro FX 540 which does not support MPEG2_VLD (as from DXVA checker).
That means, I can't pass Slice Control Buffers to process VLD on my machine right?
Anybody has idea regarding which card supports MPEG2_VLD mode?
Regards,
Gowtham
Old 17th October 2012, 11:15   #7  |  Link
fashionman
I want to study it, have you the document about DXVA for MPEG2?
Thanks
Fashionman
fashionman is offline   Reply With Quote
Old 17th October 2012, 12:05   #8  |  Link
pandy
ATI (at least in past) have full MPEG-2 HW decoding, and for all that ask why HW decoding for MPEG-2 i will say - jitter is much lower than for software solutions and yes, this is visible.
pandy is offline   Reply With Quote
Old 18th October 2012, 08:09   #9  |  Link
wanezhiling
About AMD/ATI, only UVD3.0 cards(HD6000/7000) support full MPEG-2 HW decoding.
dxva, mpeg-2, mpeg2, open source
