24th April 2012, 17:08 | #10621 | Link | |||
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 24th April 2012 at 17:50. |
24th April 2012, 17:13 | #10623 | Link |
So, it's fine for you?
Btw: Are you using LAV splitter? It reports 59.94 fps but maybe your video has exactly 60 fps. This is fixed in the nightlies. If it's not related to FSE switch or normal issues in the beginning, it could be a glitch in the video itself. I have such a sample with lots of glitches. |
24th April 2012, 17:21 | #10624 | Link | |
The 720p file is 59.94, it's an ATSC TV recording. |
24th April 2012, 21:23 | #10625 | Link | |
My 720p60 testclip was this: http://www.tomguilmette.com/wp/download/8/ [ downloaded from http://www.tomguilmette.com/wp/my-blog/archives/2500 ]. Can you check that with your configuration? So, if I understand right, you are saying on the whole that you have had better luck with using madVR on i7-3770K compared to Hendrik and me... |
24th April 2012, 21:43 | #10626 | Link |
And I can't play yet with my chosen madVR settings since I'm still waiting for my favorite shops to get the 3770k in stock. sigh.
24th April 2012, 22:21 | #10628 | Link |
The difference seems to be the decoder used. Using QuickSync, the GPU is overloaded with 720p60, because it puts some extra strain on the GPU. With software decoding, the situation improves.
Still leaves the problem with my black levels The desktop looks stupid with limited range.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 24th April 2012 at 22:23. |
24th April 2012, 22:40 | #10629 | Link | ||
On a separate note, do you guys observe any difference when the amount of DRAM devoted to the iGPU is varied in the BIOS? |
24th April 2012, 22:49 | #10630 | Link | |
However, a 3770 can process a 1080p or 720p file very easily. Also need to check the performance state of the CPU, in QS mode my 2600k will stay in its lowest clock state, while SW decoding actually causes it to go to max speed. Didn't check IVB. Anyway, more tests when i have the time.
24th April 2012, 22:54 | #10631 | Link | |
25th April 2012, 10:04 | #10632 | Link | |
Or take a laptop with hd4000 iGPU and with a 1280*720 display (or other non FullHD display with the desktop machine): how well a 1080p24fps and a 1080p30fps will be played? (I even don't write down the last option in this row ... )
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
25th April 2012, 15:56 | #10633 | Link |
that should be even harder to do.
i'd like to see more how ram and gpu core overclocking play into this. also, you can always lower chroma to bilinear, that isn't that big of a deal imo, and that should provide a big performance boost. |
25th April 2012, 16:14 | #10634 | Link |
Its been a while, but i have a fresh test build:
x86: http://files.1f0.de/lavf/LAVFilters-...0-ga4c4634.zip x64: http://files.1f0.de/lavf/LAVFilters-...4c4634-x64.zip Not really anything big and note-worthy, its just been so long since the last release and so much has changed in ffmpeg that i feel like its better to post it here before tagging a release. So, if you want, test away, and report any "new" problems! Especially MKV has changed a bit, to avoid some issues i had to re-structure how the code is integrated. Hopefully, no visible changes at all (or well, maybe a crash less in some crazy circumstances!)
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 25th April 2012 at 16:30. |
25th April 2012, 16:30 | #10635 | Link | |
25th April 2012, 16:32 | #10636 | Link |
technically its one before that, but the commit has no real influence.
25th April 2012, 17:19 | #10637 | Link |
Hendrik,
Does the new release remove the max. 1080p limitation for DXVA2 / QS decode in LAV Video Decoder ? (the one that Andrew fixed locally to test out 4K acceleration in his review at Missing Remote) Thanks! |
25th April 2012, 17:21 | #10638 | Link | |
Like i explained numerous times before, the auto-detection of 4k hardware support is not working properly (yet), so i blacklisted it. However, i only did so for DXVA2 Native. QS has no such artificial limitation. If 4K decoding does not work (it doesn't for me), its most likely your driver being bad (or go blame egur)
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 25th April 2012 at 17:53. |
25th April 2012, 18:03 | #10640 | Link | |
0.50.1-50-ga4c4634.zip 0.50.1 is the last release 50 is the number of commits since then. a4c4634 is the hash of the commit. Dunno why they put a "g" before the hash, i just use "git describe" to name the files.
