30th October 2013, 09:54 | #641 | Link |
ffx264/ffhevc author
ChangeLog for version 9.7.1
* Enabled multi-channel support for Opus audio * Moved the MKV audio filters metadata after the audio codec/language metadata * Fixed copy and pcm audio encoding * If user chooses PCM for subsequent audio tracks, don't error out but just skip the track * Some minor clean-ups |
31st October 2013, 13:06 | #642 | Link |
ChangeLog for version 9.7.2
* Fixed exporting of the NERORMAUD variable to the batch file * Implemented support for virtually an infinite amount of subtitles. This introduces a new variable, MAX_AMOUNT_SUBS, to the config file where the user can set the amount of subtitles he/she wants h264enc to support * Added output name to the message of the mail notification feature * Fixed the nosound audio option * renamed the rmtemp() function to exit_func() * Return proper exit codes. 0 on success, 1 on error and 2 on user interrupt |
1st November 2013, 07:30 | #643 | Link |
ChangeLog for version 9.7.3
* Merged the file and dvd audio detection/selection code * Merged the audio code for the first and subsequent tracks * Set a default audio ID based on input (ie, 0 for file and 128 for DVD) * Use -demuxer lavf for file and dir input * Small improvements to the subtitles code * Renamed the -help switch to -h * Improved the way audio tracks information is presented to the user * Make destination dir if it doesn't exist for saving to the batchfile * Updated the man page |
2nd November 2013, 19:36 | #644 | Link |
ChangeLog for version 9.7.4
* Fixed copying of E-AC-3 audio * Set default value for 3D frame packing to 3 (side by side) * Moved some audio selection code into the new set_audio_codec_func() function. Reduces some code duplication and removes the default_audio_codec_func() function |
8th November 2013, 15:02 | #645 | Link |
ChangeLog for version 9.7.5
* Added support for importing a chapters file for MKV/MP4/OGM when input is file * Added support for setting the audio language code for MKV/MP4/OGM/TS when input is file * Added support for setting the subtitle language code when importing subs into MKV/MP4/OGM |
18th January 2014, 19:59 | #648 | Link |
ChangeLog for version 9.7.8
* New variable in the config file, DELETE_AVI_AFTER_REMUX, to automatically delete the AVI file after remuxing. This updates the config file version to 27 * Renamed the 480 and 576 params of the colorprim_func() function to ntsc and pal |
2nd February 2014, 21:18 | #649 | Link |
ChangeLog for version 9.7.9
* Added support for hardcoding embedded subtitles in files * Use -nosub for hadrcoding an external subtitle to prevent auto-loading of any embedded subtitles in the input * Use -ao null instead of -nosound |
4th February 2014, 19:43 | #650 | Link | |
"-ao null" = should dump the audio output to null, but still do audio processing (scanning for audio streams) "-nosound" = disable all audio processing since '-ao null' is an mplayer only option, don't you also use mencoder? Last edited by Selur; 4th February 2014 at 19:55. |
4th February 2014, 20:06 | #651 | Link | |
-ao null is only used in the mplayer code, not mencoder |
5th February 2014, 04:51 | #652 | Link | |
Yeah, latest mplayer is broken in a lot of place, see: https://trac.mplayerhq.hu/ticket/2172#comment:5 (seems like trac.mplayerhq.hu is down atm.)
28th February 2014, 21:35 | #654 | Link | |
Stumbled over https://sourceforge.net/p/opencore-amr/mailman/message/31945744/ (I'm also interested to include aac-enc into Hybrid on MacOSX and would also require pipe support) and read:
28th February 2014, 21:59 | #655 | Link | |
1st March 2014, 09:22 | #656 | Link |
Did it work for you?
I just tested: 1. created fifo: Code:
mkfifo -m 777 /Users/selur/Desktop/temp/HybridTempPipe_08_04_53_9610_02_audio.wav Code:
"/Users/selur/aac-enc" -r 128000 -t 2 "/Users/selur/TempPipe_08_04_53_9610_02_audio.wav" "/Users/selur/Desktop/temp/iId_1_aid_0_DELAY_-43ms_08_04_53_9610_02.aac" Code:
"/Users/selur/ ffmpeg" -y -threads 2 -v -10 -i "/Users/selur/Desktop/temp/iId_1_aid_0_DELAY_-43ms_08_04_53_9610_01.aac" -ac 2 -ar 44100 -f sox - | "/Users/selur/sox" --multi-threaded --ignore-length --temp "/Users/selur/Desktop/temp" --buffer 524288 -S -t sox - -b 16 -t wav "/Users/selur/Desktop/temp/TempPipe_08_04_53_9610_02_audio.wav" rate 48k (the sox part is used to make sure the output is 16 bit wav) My guess is that something like 'ignore length' might be needed. (since the header of the wave sox will output, will have a wrong length) If I don't use the named pipe but simply use intermediate files everything works, so seems to me that the pipe support isn't working. Cu Selur Ps.: open an issue in the bug tracker Last edited by Selur; 1st March 2014 at 09:33. |
1st March 2014, 19:03 | #658 | Link |
Got some feedback to the issue in the bug tracker and sox seems to use slightly other wav headers than ffmpeg -> I'll have to wait for sox wave header support
Update: -> sox problem got fixed by using normal and not named pipes But now I found a new problem, aac-enc doesn't like wav files with more than 2 channels. Last edited by Selur; 6th March 2014 at 16:07. Reason: udpate |
12th March 2014, 17:12 | #659 | Link |
Martin told me to pull the latest from this branch https://github.com/mstorsjo/fdk-aac/commits/read-streamed-wav
So I did and compiled it. It now works when encoding from a named pipe mkfifo audio.wav /usr/local/bin/aac-enc -r 96000 -t 2 -a 1 audio.wav output.aac & mplayer Sample720p60.ts -vo null -vc dummy -af format=s16le -ao pcm:fast:file=audio.wav This produces a file that can be played by both mplayer and vlc (didn't test others) So when these changes land in the stable branch, I'll add support for this encoder in h264enc |
h264enc, ipod, mencoder, ps3, xbox360 |
