21st March 2008, 01:11 | #361 | Link |
Very good - thanks!
It is very understandable why it crashes then. I will cut away the beginning as well. Perhaps it was cut right at the transition between a commercial and normal content. Yes, other streams works just fine. There should be no need to write special cases for this. Btw, I could have probably figured it out with dgindex source code myself. I will try to complete the compilation, but I am having some trouble with the one asm file requiring ml.exe. I will edit this post once I gain access on my build system, which is out of reach right now, or edit the source code so perhaps this code is not needed. Thanks! Karl.
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. Last edited by karl_lillevold; 21st March 2008 at 01:14. |
21st March 2008, 17:10 | #363 | Link |
Yes, the problem is not availability of ml.exe, but which version to use. I get various errors in idctmmx.asm, and have not found an ml.exe version that works.
My latest attempt was with "Microsoft (R) Macro Assembler Version 6.14.8444". Code:
1> Assembling: idctmmx.asm 1>idctmmx.asm(1120) : error A2008: syntax error : xmm 1> DCT_8_INV_ROW_1_s2(2): Macro Called From 1> idctmmx.asm(1120): Main Line Code Code:
1> Assembling: idctmmx.asm 1>idctmmx.asm(52) : error A2008: syntax error : TEXTEQU 1>idctmmx.asm(1120) : error A2070: invalid instruction operands 1> DCT_8_INV_ROW_1_s2(5): Macro Called From 1> idctmmx.asm(1120): Main Line Code Code:
1> Assembling: idctmmx.asm 1>idctmmx.asm(795) : error A2070: invalid instruction operands 1> movq(5): Macro Called From 1> DCT_8_INV_ROW_1(2): Macro Called From 1> idctmmx.asm(795): Main Line Code I would appreciate if you could point me in the direction of the right ml version. Thanks, Karl.
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. |
22nd March 2008, 14:45 | #366 | Link |
You need version 6.15 (mine is 6.15.8803). Most people get it from the VC processor pack. You can find it on the web. Let me know if you have any problems finding it. I tested it with VS 2005 Pro and it works fine for assembling idctmmx.asm.
22nd March 2008, 14:49 | #367 | Link |
Thanks, Don! I believe I have the VC proc pack somewhere on one of my older systems, too. I just did not think to try that version.
27th March 2008, 04:08 | #369 | Link |
Please give me your exact CLI line. The syntax is more stringently checked, especially the = signs must all be present,especially with -IF=[...]. I'll test it in the meantime.
EDIT: Yup, it works fine and it fails as you say if I leave the = sign out for -IF=[...] Last edited by Guest; 27th March 2008 at 04:14. |
27th March 2008, 04:33 | #370 | Link | |
ASXGui Developer
28th March 2008, 04:55 | #372 | Link |
neuron now here's a mystery for you too solve - gl
neuron2 ok, did some more testing regarding the previous colormatrix/colorimetry issues (no hints) that I had. dgindex v.1.48 does parse it correctly and the proper values are being reported (hence why I said it used too work as its an old version).
v.1.48: Colorimetry: ITU-R BT.709 v.1.49b4 Colorimetry: ITU-R BT.709 v.1.49b14 Colorimetry: ITU-R BT.709 v.1.49b17 Colorimetry: Unknown v.1.49: Colorimetry: Unknown v.1.50b2: Colorimetry: Unknown So hopefully that can help you narrow it down, its quite obvious that something changed between 1.49b14 - 1.49b17 that affects recognising the correct colorimetry within the mpeg2 stream as the stream does have colorimetry, and I can pretty much assume that whatever changed is affecting all dvb channels within Australia (as I haven't seen colorimetry since 1.49b14 when processing). here's the sample (3.8mb) so you can draw your own conclusions... http://rapidshare.com/files/10293796...TV.AU.m2v.html I really hope you can solve this problem. (sorry I took so long, just had other things going on...) |
30th March 2008, 02:08 | #375 | Link |
Is it possible to add an option to produce a type-1 timecode file for mkvmerge for variable frame rate input files? DGIndex is already tracking transitions between "film" and "video" modes so I imagine this can be done pretty easily and accurately.
The type-1 format generally starts with: Code:
# timecode format v1 Assume 29.970030 The remaining lines in the file specify frame ranges and the actual frame rate, such as Code:
0,571,23.976024 Code:
2435,2435,30.0 Thanks Last edited by opieant; 30th March 2008 at 02:49. Reason: corrections |
30th March 2008, 05:14 | #377 | Link |
Don: I already started looking into this possibility but ran into a problem. The D2V file doesn't contain the frame rate info from the sequence headers, just one frame rate at the beginning, so this can't be done based on the D2V file alone unless I'm missing something major.
It may be possible to calculate the picture durations accurately from the flag data, in which case I can generate a type-2 mkv timecode file (specifying every picture's presentation time). I'll look into this further. At a glance it seems like one necessary flag is missing, but I haven't picked apart this type of data in ages so I'll review the standard tomorrow. FYI, I already tried to use the "timestamps" logging feature in DGIndex to get the PTS values but I discovered that not all pictures and GOPs are showing up in that log file. I can provide a sample input if you're interested in looking into this issue. Thanks for your help |
31st March 2008, 21:48 | #378 | Link |
A hollow voice says
A minor usability request:
Video menu has "HD Display" mode. (Thanks) However when using the cropping filter, I can't switch mode. So I have to (for example) switch to 'Top Left', invoke the cropping filter, set top and left, exit the filter, switch mode to 'Bottom Right', re-invoke the filter, set bottom and right. It gets the job done, but is cumbersome. |
31st March 2008, 21:51 | #379 | Link | |
Is that is normal behavior? ( The length of the fixed d2v had 1 more frame than the non fixed and the audio was 41ms shorter than video. The NON fixed one was the exact same length for video and audio ) This week I'm gonna cap some 480i stuff just for you in search of an out of sync one so I can send you a good sample. thanks |
31st March 2008, 21:57 | #380 | Link |
Oh almost forgot. In that same 480i there appears to be a dimension change and DGindex content would change size during preview and what was there before the change stays on the very right side while the new content previews (the DGindex window stays the same size. only the content area changes. looks like it goes from 704 x 480 to 512 x 480)
I never saw that happen before. I would send it but I deleted it by mistake and it was not recoverable. This is another reason why I'm gonna find you some samples this week instead of waiting for a random cap to have problems. Thanks Last edited by Zep; 31st March 2008 at 22:03. |
