Old 17th April 2009, 01:01   #1  |  Link
Inspector.Gadget
Doubled image problem with MPEG-2 and DXVA
Hey everyone,
I'm currently puzzling through a rather annoying problem. Whenever* I play back a DVD-compliant MPEG-2 stream - in Matroska, VOB, or DVD structure - I will get two half-height pictures stacked on top of one another. *This only happens when I enable DXVA in the decoder, but happens with both the Microsoft MPEG-2 Decoder and the one bundled with PowerDVD 9. I seem to remember it also happening with the Arcsoft video decoder. It happens with both VMR-9 (mixer mode has no effect) and any EVR setup. I've updated/rolled back my graphics card driver to several different versions to no avail.
Here are my system specs:
Windows Vista SP2 x64
4GB Ram
Nvidia 9650M GT
Intel C2D T9400 @ 2.53gHz
Using MPC-HC rev 1.2.1043.0 as a front-end and using ffdshow tryouts SVN latest to decode AC3 or DTS audio. No subtitle or other filters between decoder and renderer.
Anyone else have this problem or a similar one? Here's how it looks, by the way:
Inspector.Gadget is offline   Reply With Quote
Old 17th April 2009, 01:08   #2  |  Link
MPC-HC settings:
Playback \ Output - VMR9 Renderless (check VMR9 Mixer mode)
Internal Filters \ Source filters - uncheck "matroska"
External Filters - add the following filters :
* Microsoft MPEG-2 Video Decoder (PREFER)
* WMVideo Decoder DMO (PREFER)
* MPEG-2 Demultiplexer (BLOCK)
The main thing is block MPEG-2 Demultiplexer so as to use MPEG-2 Splitter.
Old 17th April 2009, 01:30   #3  |  Link
Inspector.Gadget
That didn't seem to fix it. I'm using Haali for Matroska files and the internal MPC-HC MPEG-PS splitter already, and so far as I know the MPEG-2 Demultiplexer never gets called at all. I did try unchecking the internal MPEG-PS splitter with the MPEG-2 Demultiplexer blocked, which made MPC-HC use the external MPEG-2 Splitter, but this made the video both split as above and unseekable.
9650mgt, dxva, evr, mpeg-2, vrm9
