Old 30th January 2010, 16:38   #6801  |  Link
dr01dy
I searched around the forums for this setting but was unable to find it.
I am looking to do a test encode with ripbot246 but I can't find the setting. All of my encodes are not cropping out the black screens even when I set it for each encode.
Jeff
dr01dy is offline   Reply With Quote
Old 30th January 2010, 17:50   #6802  |  Link
tormento
Acid fr0g
tormento's Avatar
Could somebody tell me why the CheckRequiredSoftware=0 parameter does not work anymore?
I am progressively abandon haali splitter since it gives me more problems than ever. How should I fake it is installed?
@turment on Telegram
Old 30th January 2010, 18:09   #6803  |  Link
stumped
Originally Posted by iSeries View Post
Yes I've read the first post. All it says in the first post is the latest Haali will not work with VC1 .m2ts files. However the source file is already remuxed into MKV, and the video codec is AVC not VC1. So therefore I assumed this advice was not applicable here.
i had the same issue you're having. turns out, you have to downgrade to the haali that is posted on the first page of this thread (i know, go figure?).
stumped is offline   Reply With Quote
Old 30th January 2010, 18:41   #6804  |  Link
tormento
Acid fr0g
tormento's Avatar
I tried every haali I found. Don't think I need it anymore. I use MPC HC to play video, DGToolsNV to demux BD & DVD audio+video, eac3to to demux chapters and subs. What should I use Haali Splitter to?
Need a way to fake it for RipBot
Old 31st January 2010, 16:27   #6805  |  Link
joae
How do I force a temp directory? I have two temp folders, one on C and another on F (don't know how that happened). Now I can't recover my job queue.
joae is offline   Reply With Quote
Old 31st January 2010, 19:16   #6806  |  Link
8ternity
8ternity's Avatar
Hi atak,
After changing one hard drive and put into my server computer, ripbot264 has freezing to "Gathering Informations". I make some look up in the C:\Temp\ to check what's wrong.
- .264 file is not in temp folder, all subtitles and audio tracks are in job1. only 2 avs file (job1.avs and getinfo.avs). If i cancell the gathering information, the C:\Temp has been deleted.
I went to Windows Vista SP2 to make some test, and samething.
Could you help me with this case?
It's start from when i takeout 1 hard discs and modify ripbot.ini to change drive letter and output drive.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating.
8ternity is offline   Reply With Quote
Old 31st January 2010, 22:22   #6807  |  Link
pacaveli211
suggestion for a couple features (if possible)
a Pause! (maybe at least after pass1 if it can't be done during encoding?)
an option to drop the framerate for the audio
pacaveli211 is offline   Reply With Quote
Old 31st January 2010, 23:15   #6808  |  Link
8ternity
8ternity's Avatar
in Ripbot264 folder, go in Ripbot264.ini with notpad.exe;
Temporary system and Output Path. The first one has for jobs working files, and the other for done project.
Old 1st February 2010, 07:56   #6809  |  Link
hoju3508
In your RipBot264.ini file, change AUTO to desired drive.
[settings]
// TEMP=uses System temp ; AUTO = selects the biggest partition ; C , D ... uses specific partition
StoreTempFilesin=C
hoju3508 is offline   Reply With Quote
Old 1st February 2010, 17:12   #6810  |  Link
slayers
PURE INTERLACED Encoding mode?
Any Chance of a Future update to ALLOW Interlaced Encoding? So far I have noticed just a Bunch of De interlacing options, but nothing for just to encode it to interlaced. Top and Bottom Field.
slayers is offline   Reply With Quote
Old 1st February 2010, 23:13   #6811  |  Link
juGGaKNot
juGGaKNot's Avatar
I get a "line 2 from getinfo.avs wont talk to me" when i open mp4 files, what can cause this ?
Originally Posted by Dark Shikari View Post
If they can beat x264 in visual quality on ordinary test clips without postprocessing, I'll eat my hat.
juGGaKNot is offline   Reply With Quote
Old 2nd February 2010, 04:25   #6812  |  Link
TeflonFong
avchd instead of blu ray
how come I am getting AVCHD and not Blu-Ray disc where it says save as? On all the screenshots I see online in the tutorials/guide there is an option for blu-ray disc...I want to shrink BD50s on a BD25 but I cannot find the option!
TeflonFong is offline   Reply With Quote
Old 2nd February 2010, 05:33   #6813  |  Link
xaero
same here.. i reinstalled ripbot, avisynth, ffdshow and turned off my firewall and still get this error:
DirectShowSource: RenderFile, the filter graph manager won't talk to me
(C:\temp\RipBot264temp\job1\getinfo.avs, line 2)
any suggestions?
xaero is offline   Reply With Quote
Old 2nd February 2010, 07:26   #6814  |  Link
pacaveli211
not sure what guides you saw with this, I've never seen the button (maybe it was there on early versions?). possibly you've see the bluray button on TSMuxer though. just reencode your files to MKV and then mux to bluray structure with TSMuxer. keep in mind the file will be larger after muxing. for example: I reencode files to 7620MB to fit as AVCHD on dvd9 (a dvd9 is about 8150MB).
alternately you could encode to avchd and then just remux the m2ts into bluray structure.....or maybe just even leave it, your player might play AVCHD on bd25 (mine won't play bluray on dvd9)
I've been unable to determine the significant difference between AVCHD and Bluray structure (a couple index files are different sizes)
Old 2nd February 2010, 10:24   #6815  |  Link
tulip001
any suggestions?
What Hali version do you use?
Is the source a VC-1 encoded video? Then use the Hali Splitter version shown in the 1st post.
tulip001 is offline   Reply With Quote
Old 2nd February 2010, 15:48   #6816  |  Link
juGGaKNot
juGGaKNot's Avatar
Haali "logo" keeps going in and out in the right lower corner ( taskbar ? ), i have the haali from the first page.
Old 2nd February 2010, 16:38   #6817  |  Link
xaero
hey thanks! mine seems to be working fine now..
i launched media splitter settings | under compatibility i set autoload vsfilter to yes.
Old 2nd February 2010, 17:27   #6818  |  Link
juGGaKNot
juGGaKNot's Avatar
Reinstalled haali and avisynth, updated to ffdshow 3251, java was not reinstalled, works now :
Wish me luck on a sempron.
BTW : open multiple files would help.
Old 2nd February 2010, 18:17   #6819  |  Link
xaero
Does not work for me, h.264 files, works for wmv and xvid.
~edit
thanks for the info
Old 2nd February 2010, 20:28   #6820  |  Link
laoping
Two Questions... and sorry if they have ever been covered before, but we are on page 340 here About subtitles.
1. Does Ripbot264 OCR subtitles before you burn them in? Or do you build in the image of subtitles from the bluray?
2. Would SupTitle work better for subtitles http://www.zachsaw.co.cc/?pg=suptitl...visynth_plugin? It looks like it uses the SUP file directly to burn in subtitles.
laoping is offline   Reply With Quote
