27th June 2009, 23:06 | #9043 | Link | |
NY Frame of Mind
"Talk to me Goose" |
29th June 2009, 04:57 | #9047 | Link | |
No, I have no problem with TrueHD tracks if they are decoded to PCM, those work perfectly. Also have never had any problem with any flavor of DTS (DTS, DTS-HD, DTS-MA). There are some TrueHD tracks that seem to work, but most give distorted audio. The distortion varies, and there are portions of the audio where you probably can't tell at first listen, and then there are sections where there is obviously something wrong. I use the Iron Man BD to test this. The very first scene is majorly affected - the dialogue/discussion in the jeep at the very start of the film is barely audible under the eac3to.exe demux/TSMuxer remux scenario. However, I have indeed finally solved this problem. It is indeed eac3to.exe's issue, and the root of the problem is the removal of dialogue normalization. Eac3to removes dialogue normalization by default. When it does that, the sound is distorted when played through my Pioneer receiver. Adding "-keepdialnorm" on the eac3to.exe command line has completely fixed the problem. I've tried my particularly problematic TrueHD track (Iron Man) which was very obviously distorted when played back after a demux with eac3to.exe and a remux with TSMuxer. The TrueHD track now plays perfectly and identically to the original when the -keepdialnorm option is used during the eac3to.exe demux. This must be something particular to Pioneer receivers, evidently they pay very close attention to the dialogue normalization metadata and get confused if the values are incorrect, missing, etc.
- SomeJoe |
29th June 2009, 13:30 | #9048 | Link | |
EDIT: Nevermind I found "-keepFullRange" Last edited by rack04; 29th June 2009 at 13:49. |
1st July 2009, 18:14 | #9049 | Link |
21 years and counting...
When I use eac3to to demux evo-Containers with the -demux switch, eac3to demuxes not all the streams (especially subtitles with ID: 28 and up).
Is there a way to fix this or can I demux multiple streams at once WITHOUT converting them? |
1st July 2009, 19:47 | #9050 | Link |
DTS 7.1 to LPCM
After ready through some of the posts on talking about TMT 2 and 3 to use for converting DTS 7.1 to LPCM 7.1 it sounds like if I don't have TMT 2 I cannot use TMT 3 to do the convertion? If that is the case does anyone know where I can get a copy (buy) of TMT 2? Thank you
1st July 2009, 20:55 | #9051 | Link |
Hey madshi and folks,
Is there a way to split an MLP file with eac3to if you have a cue sheet or somehow just typing in where (in time/samples etc) to split the audio file? Thanks very much...Haven't used eac3to in a while - I can only imagine all the excellent new features since the last time I updated it! |
2nd July 2009, 00:21 | #9052 | Link |
One of the FLAC encoder's callbacks returned a fatal error.
Anyone have any ideas on what might be wrong here.
eac3to v3.16 command line: "C:\VID2EVA\tools\eac3to\eac3to.exe" "F:\BDMV\STREAM" 1) "Z:\VIDEOS\Vid2eva.mkv" -seekToIFrames -stripPulldown -lowPriority ------------------------------------------------------------------------------ M2TS, 1 video track, 5 audio tracks, 5 subtitle tracks, 1:44:05, 24p /1.001 1: Chapters, 24 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: DTS Master Audio, English, 6.1 channels, 24 bits, 48khz (core: DTS-ES, 6.1 channels, 24 bits, 1509kbps, 48khz) 4: AC3, Spanish, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB, -13ms 5: AC3, French, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB, -13ms 6: AC3, English, 2.0 channels, 224kbps, 48khz, dialnorm: -27dB, -19ms 7: AC3, English, 2.0 channels, 224kbps, 48khz, dialnorm: -27dB, -19ms 8: Subtitle (PGS), English 9: Subtitle (PGS), French 10: Subtitle (PGS), Spanish 11: Subtitle (PGS), Spanish 12: Subtitle (PGS), English Creating file "Z:\VIDEOS\Vid2eva - Chapters.txt"... [a03] The ArcSoft and Sonic decoders don't seem to work, will use libav instead. [a03] The libav DTS decoder doesn't decode the back channels. <WARNING> [a03] The libav DTS decoder doesn't decode the full DTS-HD information. <WARNING> [v02] Extracting video track number 2... [a04] Extracting audio track number 4... [v02] Muxing video to Matroska... [a05] Extracting audio track number 5... [a06] Extracting audio track number 6... [a06] Removing AC3 dialog normalization... [a07] Extracting audio track number 7... [s09] Extracting subtitle track number 9... [a03] Extracting audio track number 3... [s10] Extracting subtitle track number 10... [s11] Extracting subtitle track number 11... [s08] Extracting subtitle track number 8... [s12] Extracting subtitle track number 12... [a05] Removing AC3 dialog normalization... [a04] Removing AC3 dialog normalization... [a04] A remaining delay of -13ms could not be fixed. [a07] Removing AC3 dialog normalization... [a03] Extracting DTS core... [a05] A remaining delay of -13ms could not be fixed. [a06] Applying (E-)AC3 delay... [a07] Applying (E-)AC3 delay... [a07] A remaining delay of +13ms could not be fixed. [a06] A remaining delay of +13ms could not be fixed. [a03] Decoding with libav/ffmpeg... [a03] Remapping channels... [a03] Reducing depth from 64 to 24 bits... [a03] Encoding FLAC with libFlac... [a03] Creating file "Z:\VIDEOS\Vid2eva - 3 - DTS Master Audio, English, 6.1 channels, 24 bits, 48khz.flac"... [a04] Creating file "Z:\VIDEOS\Vid2eva - 4 - AC3, Spanish, 5.1 channels, 448kbps, 48khz.ac3"... [a05] Creating file "Z:\VIDEOS\Vid2eva - 5 - AC3, French, 5.1 channels, 448kbps, 48khz.ac3"... [a06] Creating file "Z:\VIDEOS\Vid2eva - 6 - AC3, English, 2.0 channels, 224kbps, 48khz.ac3"... [a07] Creating file "Z:\VIDEOS\Vid2eva - 7 - AC3, English, 2.0 channels, 224kbps, 48khz.ac3"... [s12] Creating file "Z:\VIDEOS\Vid2eva - 12 - Subtitle (PGS), English.sup"... [s08] Creating file "Z:\VIDEOS\Vid2eva - 8 - Subtitle (PGS), English.sup"... [s10] Creating file "Z:\VIDEOS\Vid2eva - 10 - Subtitle (PGS), Spanish.sup"... [a03] Clipping detected, a 2nd pass will be necessary. <WARNING> [a03] The original audio track has a constant bit depth of 64 bits. [a03] The processed audio track has a constant bit depth of 24 bits. [s09] Creating file "Z:\VIDEOS\Vid2eva - 9 - Subtitle (PGS), French.sup"... [s11] Creating file "Z:\VIDEOS\Vid2eva - 11 - Subtitle (PGS), Spanish.sup"... [a03] The libav DTS decoder doesn't decode the back channels. <WARNING> [a03] The libav DTS decoder doesn't decode the full DTS-HD information. <WARNING> [a03] Starting 2nd pass... [a03] Extracting audio track number 3... [a03] Extracting DTS core... [a03] Decoding with libav/ffmpeg... [a03] Remapping channels... [a03] Reducing depth from 64 to 24 bits... [a03] Encoding FLAC with libFlac... [a03] Creating file "Z:\VIDEOS\Vid2eva - 3 - DTS Master Audio, English, 6.1 channels, 24 bits, 48khz.flac"... [a03] Writing the destination file failed. <ERROR> [a03] One of the FLAC encoder's callbacks returned a fatal error. <ERROR> Aborted at file position 56623104. <ERROR> |
2nd July 2009, 00:53 | #9053 | Link |
Maybe eac3to try to encode a 6.1 flac but the decoder output (libav) is only 5.1
Try to decode first: "C:\VID2EVA\tools\eac3to\eac3to.exe" "F:\BDMV\STREAM" 1) 3: "Z:\VIDEOS\Vid2eva.wav" and encode to flac after: "C:\VID2EVA\tools\eac3to\eac3to.exe" "Z:\VIDEOS\Vid2eva.wav" "Z:\VIDEOS\Vid2eva.flac" But if you don't have the ArcSoft decoder you can't decode the DTS-MA and use flac like output is not necesary, you can convert the wav output to ac3: "C:\VID2EVA\tools\eac3to\eac3to.exe" "Z:\VIDEOS\Vid2eva.wav" "Z:\VIDEOS\Vid2eva.ac3" or extract the core DTS-ES, 6.1 "C:\VID2EVA\tools\eac3to\eac3to.exe" "F:\BDMV\STREAM" 1) 3: "Z:\VIDEOS\Vid2eva.dts" -core
2nd July 2009, 11:22 | #9054 | Link | |
2nd July 2009, 16:34 | #9057 | Link | |
2nd July 2009, 20:13 | #9060 | Link | |
eac3to |
