25th March 2010, 21:30 | #1721 | Link |
I don't think my audigy's or x-fi's are PAP... but 8channel truehd 24b48khz comes out of ffdshow the way it went in here. no 16bit-ness at all.
The only thing us (me and about 10 of my mates, anyway) geriatric soundcard-ed people are having is 96k stuff gets parsed as 48 and sounds all helium-ish. |
25th March 2010, 22:44 | #1722 | Link | |
25th March 2010, 22:46 | #1723 | Link | |
ffdshow > reclock is the recipe. For more; i think this thread is still contemporary : http://www.avsforum.com/avs-vb/showt...9#post15770959 |
26th March 2010, 01:42 | #1724 | Link | |
fyi: current behaviour re attempting to decode bitstream... (superb thinking...btw) audigy and xfi latest drivers on 7_64_rtm... with bitstreaming selected on a 24bit 96khz dtshdma track we all get 8channel 48khz as input and 8 channel 1520 (not 1536?)KB SPDIF as output but the file never plays. just sits at 0:00 - regardless of what ffdshow's connected to (cyberlink won't connect at all and attempting to connect anything in the windows media foundation resulted in the input pin saying only 2 channels) and we don't even get a pop or crackle if we actually connect our digital out's up (obv. not expecting anything sensible to come out of it). would also just like to add how much everyone's hard work is appreciated here. stunning work. |
26th March 2010, 02:09 | #1725 | Link |
There is another way to go about it but it's outside the realm of discussion for this thread. It has been found that if you have TMT3 and you only have a receiver that does analog, for example, an interesting work around can be applied IF you have a bitstream capable card. You could set TMT3 to use the bitstream capable card (xonar, ati 5xxx, etc) with PCM decoding, and then use ReClock to "redirect" that to your analog card for non-downsampled audio. It's nasty, but, it appears to work at the moment. The same kind of logic is what the OP was thinking when he asked about directing the bitstream from ffdshow into the ArcSoft decoder to see if non-downsampled PCM could be had. It's a neat theory but it's one I don't have time to try myself.
28th March 2010, 02:56 | #1727 | Link | |
hey samuriHL i assume you have the delux hdav? doing this do you set the xonar panel to the analog output and leave tmt3 to hdmi output but with pcm set? when i do this is i get no audio through my analog outputs but i do get sound with my hdmi output (i have a denon reciver with hdmi and 7.1 input) if i set tmt3 to 7.1 i get no audio with truehd and dts hd (all over codecs work fine) normally i would use the hdmi output but i prefer the sound of the analog |
28th March 2010, 02:59 | #1728 | Link | |
28th March 2010, 03:43 | #1729 | Link | |
analog has had lots of problems, not just with tmt3 but with all other players. me thinks it might be time for mine to be sitting next to my laptop too oh and also to all on this forum, great work! the way its going ill soon not have to worry about tmt3 as well Last edited by fishlogan; 28th March 2010 at 03:45. |
28th March 2010, 11:02 | #1730 | Link | |
A.K.A Mangoat
I should really try an evo file direct from disk and check for sure. |
28th March 2010, 15:04 | #1731 | Link | |
29th March 2010, 01:12 | #1732 | Link |
This may not be the right place to ask, but, I need some help. I've FINALLY gotten back to getting the latest and greatest ffdshow and mpc-hc set up. I want to get ffdshow dxva and subtitle support working, but, I'm not having a lot of luck. Could someone walk me through what needs to be done to get it working? I'd appreciate it. Thanks!!
29th March 2010, 14:55 | #1733 | Link | |
Pretty much enable ffdshow dxva, check subtitle support, play with some minor settings and it should work. Albain added some keyboard hooks so that you can control it via keyboard in any player, but personally I use his Media Control App within Media Center to manage the audio/sub switching. |
29th March 2010, 15:02 | #1734 | Link |
Ok, what I did was disable all the internal MPC-HC stuff. I added ffdshow audio and dxva video to the external filters and made them preferred. When I play a VC1/TrueHD Blu-ray in MPC-HC now, it stutters horribly bad and cpu usage is over 40% (which on my machine...that's bad). So there's no way it's using ffdshow dxva. Something is definitely wrong there. I've tried going about it multiple ways. So, the "enable ffdshow dxva" part of that is not as simple and straightforward as it seems.
29th March 2010, 15:07 | #1735 | Link | |
29th March 2010, 15:24 | #1736 | Link |
Right, that's what I'm looking for help on cause I can't seem to get it to work correctly. I'm sure I'm missing something but I'm not sure what. Media Center's fine and all but it doesn't know how to parse mpls files like mpc-hc does, so, on a seamless branched blu-ray you'd be screwed.
29th March 2010, 15:41 | #1737 | Link |
Adding ffdshow as a preferred external filter is usually not necessary. Just disabling the internal decoders is enough since ffdshow already has a higher merit than most other external decoders.
To use DXVA in MPC-HC you must select a video renderer that is compatible. On XP that is Overlay or EVR-9. On Vista/7 that is any of the EVR variants. You can see which filters MPC is using through: Play -> Filters.
MPC-HC 2.1.7.2 |
29th March 2010, 16:06 | #1738 | Link |
Yea, see, that's what I thought, too, and how I set it up. I'm using the EVR Custom Pres. renderer. When I look at the filters it shows ffdshow Video Decoder and ffdshow Audio Decoder. And it skips like hell. I'm using 1771 of mpc-hc and ffdshow 3326. Upgrading to 3335 didn't help unfortunately.
EDIT: And why is it only showing the ffdshow video decoder and NOT the dxva video decoder? It's simply NOT using it at all.
HTPC: Windows 11, AMD 5900X, RTX 3080, Pioneer Elite VSX-LX303, LG G2 77" OLED Last edited by SamuriHL; 29th March 2010 at 16:17. |
29th March 2010, 16:18 | #1739 | Link | |
29th March 2010, 16:20 | #1740 | Link |
No, it's the same. So yea, I fixed it. I had indeed taken it out of the external filters list. I put it back and now it's working. Thought I had tried this combination before but apparently not. Hey this is slick! Nice work, albain!! Very impressive.
