#241 | Link |
DVD Rebuilder!
@ogo,
The latest one 0.99d is very stable on my system, all are working well. Thank you for your great work. PS. to be honest, even I can't notice any difference between use/no use the ReClock, while playing on PC or TV use TVTool, even I've followed all the guides. ![]() Last edited by ookzDVD; 15th January 2003 at 08:08. |
#242 | Link |
I don't like to cause strife either. But I've uninstalled it as I found no use for it. It made no significant difference for me neither. The speedup/slowdown stuff would only come in handy for recording to VCR for me.
But I am sure it may help on some others systems. |
#243 | Link |
Anime Otaku
It certainly makes a difference for me. The latest version works very good except for occasional stuttering with ZoomPlayer 3 beta 5.5. It goes away if I pause and resume but it is very annoying. Great work OGO!
AMD FX8350 on Gigabyte GA-970A-D3 / 8192 MB DDR3-1600 SDRAM / AMD R9 285 with Catalyst 1.5.9.1/ Asus Xonar D2X / Windows 10 pro 64bit |
#244 | Link |
It definitly improves the playback on both tv and monitor!
excellent travail Ogo;-) I had quite many problems with version 0.99c, so I followed your advices of installing directx9 with 0.99d and that's much much better. Now with the latest version I could juste notice a few dropped frames from time to time but that's nothing compared to playback without reclock. I still have to test more material but what I tested was ok. Ill tell you if I discover problems. thanks a lot!
Minds are like parachutes - they only function when open. |
#245 | Link |
OGO,
Just to update... still working perfectly on my system and it has made a HUGE improvement. Have worked through several DIVX and DVD's with no problems! Ogo, if the latency increases to past MaxLatency when using "audio-slave mode", will Reclock still add/drop AC3 frames out of desperation? There are some areas of certain files where it is very difficult to keep sync... it seems to add/drop a few AC3 frames there consistently. Perhaps if I increase the MaxLatency SPDIF to past 100? Also, the only tiny issue I have is the following... when using default WaveOut, I can switch from PCM to SPDIF in real-time during a movie with no problem. Using Reclock, once I've started a media in PCM, I need to shut-down Zoomplayer and restart (not just re-load media) for it to recognize SPDIF. OOKSDVD/ODDBALL --> I don't notice a difference on 98% of my film, but just on certain very difficult panning scenes (even then, they are only microstutters for which you have to be slightly obsessive-compulsive to notice). I could post certain clips that are especially difficult to play smoothly, however Reclock seems to manage them fine! -Sumster |
#247 | Link | |||
I have another version ready with corrections for AC3 that correct all the remaining problems. I you want it now just let me know ![]() ![]() |
#248 | Link | |
#249 | Link | |
gabest.org |
#250 | Link | |
As already said I have written a frame Rate conversation utility for AVI files, and the results are good in my eyes. ![]() Greetings MS |
#254 | Link |
ReClock doesnīt work.....
wow first post!
well after several hour of trying to get ReClock running (which i really want cuz i can see the advantages with it) smoothly on my system i give up, i donīt know whats wrong and i donīt know what to do cuz when i run with reclock it just makes the clip even more jerky and stuttery than before, i think i have tried everything i could possible think of but still the same problems so maybe anyone can tell me if it has something to do with my hardware....hereīs my setup (this is for my standalone mediaplayer) PIII 500Mhz 128 MB RAM Windows 2000 PRO SP2 Geforce256 DDR (Detonator 41.09) Creative SoundBlaster AudioPCI 128 (Latest Drivers) Zoom Player 3.0B4 FFDShow 20030103 DirectX 9 ReClock 0.99d TV Out with TVTool to my PAL TV... thanks! |
#255 | Link | |
what's this for?
Re: ReClock doesnīt work.....
latest mix sets: http://soundcloud.com/sill |
#256 | Link | |
Re: Re: ReClock doesnīt work.....
#257 | Link | |||
what's this for?
Re: Re: Re: ReClock doesnīt work.....
#258 | Link | |
1.2 Ghz Celeron 256 MB RAM Windows XP BSPlayer / WMP DirectX 9 ReClock 0.99d Monitor 60hz refresh rate Playing back exclusively 23.976 fps I'm not sure the rest because I'm not there right now but it's a Toshiba laptop (i.e. everything comes built in). DivX plays reasonably smoothly without ReClock for me, except a couple days ago I tried using the built in S-VIDEO (I think that's what it is) video out thing on my friend's TV and it was ever so slightly messed up. I installed ReClock, now playing back just to my LCD gets a little jerky (like, I look at the filter and it hovers between 50 and 150 ppm, what I understand is that you want this near 0, but it never gets there... like at least in 10 minutes it gets better sometimes and worse sometimes). I tried my system with reclock on my TV out though and it's beautiful. Like really good. Is this because my monitor is not a multiple of 24? I was under the impression that ReClock would work best with a multiple of 24 or 25 but that it still helps otherwise. Is this true? Also, is it possible to change the refresh rate of all monitors? Because I was playing around in display properties and for my monitor (in the location I found) 60hz was the only choice. Is there another way to change this or am I stuck? |
#260 | Link |
what's this for?
best proof that it has nothing to do with ReClock
