#182 | Link |
I have some bad news... Now that I use the new version that doesn't eat memory I started to watch a whole movie just to enjoy the smooth playback. Well, now I _am_ able to hear drop-outs of the sound.
It doesn't happen very often, and as you say, seems to get more and more infrequent the longer I have the video playing. For me the smooth playback is well worth the occasional dropout, but if you somehow find another way to handle AC3-streams I'll be the first to test it. Still, I wanted to report this since you don't have an amp to test with. |
#185 | Link |
@oddball:
The "blip blip blip" you are hearing are probably repeating frames. As ogo has explained in the readme, the only thing he can do to keep the AC3-stream in sync is to remove or repeat frames. I also get some dropouts, but after a while they seem to stop. |
#186 | Link |
Nevermind. I finally figured it out. I've set my monitor to a multiple of 24 now as it was at 75Hz and what ReClock was trying to do was speedup an AC3 DiVX to 25FPS to match the screen sync (In auto mode) which causes drop out on AC3 audio as AC3 audio cannot be spedup like MP3 etc can.
#188 | Link |
I also get blips in the audio when I use spdif out. It happens about once per second. It would be nice if there was a option to turn of Reclock's spdifout support so that you don't have to uninstall it every time you watch a movie with ac3.
#189 | Link |
Kallekill in Zoom Player you can. Just switch it off in cutsom audio filters. Also the blips are caused by incorrect framerate to video Hz syncing. ReClock will push a 23.976FPS movie to 25FPS if running at 85Hz for instance. I don't know if this is intentional or a bug. I set my video card to 72Hz output (ReClock needs a video Hz that is either a multiple of 24 or 25) and the blips on SPDIF output went away. I use AC3Filter for SPDIF output also.
#193 | Link |
Ogo..
Again, great work on this filter! I am one of those who uses SPDIF out to an external amp along with TV out at 60Hz (my all-in-wonder Radeon only allows a refresh of 60Hz when using TV-out) I now have beautiful smooth video, but as others have noticed am able to hear repeats and drop-outs. My system clock is +/- 0.3 ppm accurate and drop-outs/repeats only occur about every 5-10 seconds (as long as I play video at original speed at 23.976 fps... if I increase the frame rate, there are too many repeats in order to stay in sync). I had two questions: 1) If my system clock can run that accurately, shouldn't drop-outs/repeats be extremely rare if the audio is trying to stay in sync with an accurate clock? 2) What is the current threshold of desync needed before the filter adds or drops a packet? (eg. once it desyncs 20 ms, 40 ms, etc) Apparently, as long as the AC3 stream is within +/- 100 msec of the video, the desync is not noticable. Therefore, if the threshold were increased before packets were dropped/added, perhaps over time the drop-outs and repeats could cancel themselves out. Of course, if the desync became too severe, something would have to be done. On the same note, perhaps there could be a monitor saying how many +/- msec of desync there currently is and the actual threshold before correction could be manually set. Just a thought.... keep up the good work!! This filter is the most impressive advance in home theater PC's in a long time! The number of times I have replaced hardware and tweaked software settings in order to reduce stuttering panning scenes is unbelivable! Take care... Sumster |
#194 | Link |
P.S. Safai... when I am not using AC3 passthrough but am using 60Hz NTSC with a 23.976 movie.... Reclock says nothing can be done. I manually set it to refresh/2.5... that scales the fps up to 24 fps. Not an exact multiple, but makes playback a bit smoother.
#196 | Link | ||||||
Hi guys
![]() The next version of ReClock should not be out until late this week. I'm trying to figure out some problems that are hard to solve. I will change the behaviour of frame rate adaptation for AC3 SPDIF. For now, reclock tries for example to play 23,976 material at 25 if your refresh rate is a multiple of 25. But that's not a good idea for AC3, because it causes a huge resampling. As you know resampling of AC3 means repeat/drop frames so 25/23,976 means 4% speed change, and it's too much. What i will do for AC3 (only for AC3) is : from 23,9 to 24,1 : play at 24fps if refresh rate is a multiple of 24 from 24,9 to 25,1 : play at 25fps if refresh rate is a multiple of 25 from 29,9 to 30,1 : play at 30fps if refresh rate is a multiple of 30 As of now if you play a 23,976 file on a PAL TV, you will get at "blip" every second. There is a hidden "feature" for AC3 on version 0.99b. If you check "disable clock correction", reclock will stop repeating/dropping AC3 frames. So you should hear "clear" sound. But sound will desync slowly, and you will loose system clock correction (that's a tradeoff for now). I'm still figuring how to improve AC3 support but making something round square is not easy ![]() Now to answer some questions : oddball> to attenuate "blips", you can choose the framerate instead of leaving it to "auto" Quote:
#197 | Link | |
Maybe that's what you meant anyway, thought it's not that clear, first you said 'ac3 spdif', but then 'ac3'...just to be sure ![]() |
#198 | Link |
Ogo, thanks a million.
Just a quick question... is there a way to log how many frames are being added/dropped in the AC3 stream by Reclock while playing a movie (ie. a log file)? I just wanted to see if my system tends to add frames or drop frames (and to calculate the percentages to see if they will cancel out over time, calculate the rate at which desync would accumulate, etc.). I also look forward manually playing with the "threshold to desync adjustment". Increasing it to 4-6 frames might get rid of the tiny micro-adjustements that are hard to handle. Thanks again! Sumster |
