Old 29th January 2009, 13:47   #621  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
I do enjoy features requests. It is in build 282.
Old 29th January 2009, 14:09   #622  |  Link
Solaris
Ok, Dean in that case her's another request
Solaris is offline   Reply With Quote
Old 29th January 2009, 14:09   #623  |  Link
Solaris
How about the possibility to set the font type, color and size in the menus
Old 29th January 2009, 14:12   #624  |  Link
deank
deank's Avatar
Font color is the only option that would be possible to change.
Font size and type - no. It is vital to have title names at the exact position, otherwise the navigational arrows won't be aligned properly.
Of course, most of us don't see the nav-arrow, but I'll fix it... i hope.
Old 29th January 2009, 14:15   #625  |  Link
Solaris
Maybe fontcolor would be a nice option to start with. On one of the custom backgrounds I want to use it is difficult to read the white letters.
btw keep up the good work!
Old 29th January 2009, 14:31   #626  |  Link
~bT~
н∂-ƒαиαтι¢
u went one better and gave us any choice of bitrate.
Old 29th January 2009, 14:42   #627  |  Link
deank
deank's Avatar
Yes.
And now font color for custom menu titles in Authoring.
Old 29th January 2009, 14:49   #628  |  Link
Solaris
Excellent, thanks.
Old 29th January 2009, 14:51   #629  |  Link
~bT~
н∂-ƒαиαтι¢
^ u can finally choose hot pink
cheers deank!
Old 29th January 2009, 15:35   #630  |  Link
deank
deank's Avatar
Will someone test if their SAP will play the custom menu with the nav-arrows?
Here is the post again.
Old 29th January 2009, 18:24   #631  |  Link
xeniste
xeniste's Avatar
Yes, me first. Build 282 I presume?
xeniste is offline   Reply With Quote
Old 29th January 2009, 18:27   #632  |  Link
deank
deank's Avatar
Current build is 286, but it doesn't matter.
Update, create a compilation, replace these 2 files, burn and test. And of course report
Old 29th January 2009, 19:13   #633  |  Link
openBA
SAP Samsung BD-R1500 after patching with two m2ts:
- menu OK
- direct selection OK
- cursor selection OK
PS3
- same as before
- menu yes (but w/o) cursor
- cursor selection NONE
Bravo Dean!
openBA is offline   Reply With Quote
Old 29th January 2009, 19:27   #634  |  Link
deank
deank's Avatar
So I guess I'll have to add an option for SAPs... I can test with PS3 and I know its not working... I tried about 20 different things today and there is some progress. I will try again later.
@openBA: is your SAP player PAL or NTSC?
And another thing - since build 287 multiAVCHD will
* not generate CERTIFICATE, AUXDATA, BDJO, JAR, META folders if create multiAVCHD button is used.
Old 29th January 2009, 19:37   #635  |  Link
openBA
.. the way one disc have to work everywhere (PS3 and SAP`s) correct ?
Old 29th January 2009, 19:37   #636  |  Link
xeniste
xeniste's Avatar
So, it works!
On my Sony, I have to wait a couple of seconds until the blue arrow arises on the left. Then, everything goes smooth.
But! With the computer player (Corel WinDVD in my case) arrow never comes, and it's impossile to launch playing.
Old 29th January 2009, 19:39   #637  |  Link
deank
deank's Avatar
I don't know... It seems that all players handle my files in a different manner.
Nero Showtime works fine... PS3 doesn't. Samsung SAP plays okay. WinDVD doesn't. Sony BD player plays okay... What should I do?!
After all - my goal is to make all work on HARDWARE players - SAP/PS3, not PC software. I will work in this direction.
@openBA: The files I uploaded seem to work both for PS3 and SAP. I will change it in multiAVCHD.
When I find a way to show nav-arrow in PS3 some of you will test with SAP and we'll call it a day.
Old 29th January 2009, 19:58   #638  |  Link
xeniste
xeniste's Avatar
Nothing!
Because with Acronis TotalMedia Theatre, after the first still screen, comes the other one with two non clickable titles, then the screen goes black with whe well known blue arrow, which allow to select file, but in a blind manner!
I guess (strictly IMHO!!) that the most interest of AVCHD is to allow to QUICKLY build a real BD-disc in order to write it then on a BD-R/BD/RW and to watch on a "hard" player. I this genre, AVCHD is unique! Trust me, I have tested a lot of such software of well known firms - 6 hours minimum per clip of 90 minutes and the total recoding. And I have a very powerful machine! And 27 minutes with AVCHD and 3 clips!!!
As for watching clips on the computer screen, there are a lot of SAP players, including Windows Media player and VLC, which can play m2ts/ts files. As for entire Blu Ray disc structure with menu, it depends on the video card and its settings, and on its interaction with the SAP player program code, so never mind!
And I wish you buy a player in order to continue - you are on the right way. I don't have PayPal account, but I will find out any other manner to participate.
(Confidential: Do you have gas?)
Old 29th January 2009, 20:05   #639  |  Link
deank
deank's Avatar
Okay.. now build 292 has the correct menu for SAPs.
Old 29th January 2009, 20:16   #640  |  Link
xeniste
xeniste's Avatar
Menu files for custom menu missing.
Downloading NTSC files
Custo title menu 1/6 downloaded
HttpSendRequest error
HttpQueryInfo: 12019
Download error!
