Old 25th February 2011, 14:12   #181  |  Link
codres
Is there a setting in the new version to change the temp folder. Is default in C:\. In the older one i could change it quickly. But in this I must be blind or maybe is not implemented? Thanks for your efforts in the development.
Codres A Bogdan
codres is offline   Reply With Quote
Old 25th February 2011, 14:19   #182  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
There is no such option currently.
Old 25th February 2011, 15:28   #183  |  Link
codres
That's too bad, I must downgrade then. I have under 1GB space on C. Also multithreading could be disabled?
Codres A Bogdan
Old 25th February 2011, 15:53   #184  |  Link
LoRd_MuldeR
Software Developer
Then it's probably time to clean-up your system drive/partition
You will run into all kinds of problems with low disk space on your system drive/partition (not only with LameXP!), that's for sure.
Anyway, I can add an option to manually choose the directory for TEMP files...
Not sure what you mean. But I recently added an option to manually overwrite the number of parallel instances (available in the latest snapshot build).
Settings this option to "1" effectively disables multi-threading, at least on the "batch processing" level. Although this usually isn't recommended...
Old 25th February 2011, 19:19   #185  |  Link
codres
Well, usually my comp also encodes x264 most of the times. So I don't want to stress too much with mp3 encodings. So, yes, I want to use only 1 core. Thanks for the tips. Right now I have 1.3 Gb free on C which usually is enough but for a movie of 2h30 min gave me an error.
Codres A Bogdan
Old 27th February 2011, 06:45   #186  |  Link
codres
Thanks for the new implementions! They work great mr. mulder
Codres A Bogdan
Old 28th February 2011, 19:07   #187  |  Link
LoRd_MuldeR
Software Developer
Yet another aoTuV Beta-6 update
aoTuV Beta6.02 [beta6.01 >> beta6.02] (2011/02/27)
# In the specific pattern (different from beta6.01), the bug that caused overflow was fixed.
Old 6th March 2011, 22:36   #188  |  Link
John_J
John_J's Avatar
Hello LoRd_MuldeR!
After a fresh reinstall of Windows XP, I also wanted to use LameXP again for my audio encodings and saw your update to v4.0.
First, I want to say that this new version became excellent...same simple workflow as before, but a brilliant new UI and nice updates.
I've played around in different ways and wondered myself where all extracted tool files have gone, because I couldn't find them in default temporary folder. After a look at Avast (Realtime-Scan is very useful in more than one way ), I found them in "\Documents and Settings\USER\Local Settings\App Data\Temp".
You've stated that temporary files go to the %TEMP% folder, but this folder is usually found at "\Documents and Settings\USER\Local Settings\Temp", isn't it? Or is this due to newer OS like Windows 7?
Regards,
JohnJ
EDIT: Forget above...looked at changelog of new beta build 350:
Changes between v4.00 and v4.01:
        * Added an option to select a user-defined TEMP directory
Thanks!!
EDIT2:
Spoke too soon! It only affects folder of temporary audio files, so please have a look at it.
John_J is offline   Reply With Quote
Old 7th March 2011, 00:26   #189  |  Link
Gabrielgoc
Member
LoRd_MuldeR, I was reading post #100 (http://forum.doom9.org/showthread.php?p=1473735 and I very interested about replaygain.
Replaygain main objective is not to adjust the volume without recompressing, but normalize the loudness based on the response of the human ear, so leave all the tracks on an even level. (http://en.wikipedia.org/wiki/Loudness). While replaygain is the most widely used algorithm, the EBU (European Broadcasting Union) has developed a new algorithm based on ITU-R BS.1770 as a loudness measurement method. This was standardized as EBU R-128. (http://tech.ebu.ch/loudness). If you are interested the following libraries can help you determine how to adjust the volume with SOX: http://www.hydrogenaudio.org/forums/...howtopic=85978 and http://www.hydrogenaudio.org/forums/...howtopic=86116.
I hope this info will be interesting to you. I apologize for my English. Greetings.
Gabriel
Gabrielgoc is offline   Reply With Quote
Old 7th March 2011, 11:38   #190  |  Link
LoRd_MuldeR
Software Developer
You can also use ProcessMonitor. Or look at the source code directly
The Windows operating system doesn't provide any API to detect the system's TEMP folder! Neither SHGetKnownFolderPath() nor SHGetFolderPath() knows about the TEMP folder. There is a function GetTempPath(), however this function does NOT return the path to the system's TEMP folder, but the current value of the %TMP% (or if that one isn't set %TEMP%) environment variable. Now %TMP% and %TEMP% will usually be set and they will usually point to the system's TEMP path, but they also may point to an arbitrary non-writable path or they may even contain complete garbage*! After all the environment variables are user-defined and may be screwed up. So it's something we better do not rely on! Question is: How do we detect the system's TEMP folder, if the Win32 API doesn't reveal it? Solution that works in practice: Obtain the path of the 'LocalAppData' folder (usually located at: "%USERPROFILE%\AppData\Local"), which is known to the Win32 API functions, and then simply append "\Temp" to that path. The result exactly matches the system's standard TEMP folder on Win7 (and probably Vista too), which is "C:\Users\John Doe\AppData\Local\Temp". It slightly differs from WindowsXP's default TEMP folder, but I see no problem there...
*from MSDN documentation: "Note that the function does not verify that the path exists, nor does it test to see if the current process has any kind of access rights to the path."
That is exactly how it is intended. The "primary" Temp folder needs to be accessed even before user-settings have been loaded, so it cannot be user-controlled. However that shouldn't be an issue at all, as the amount of data extracted to that folder is really small. The user-controlled ("secondary") Temp folder will be used for all intermediate/temporary audio files during the encoding process. So that's the place where the "big" files will go to. Consequently users with a small system partition may want to change the location of the "secondary" Temp folder, while the location of the "primary" one shouldn't matter for anybody.
(If you don't have the ~10 MB of free space, that LameXP will occupy on start-up, available on your system partition, you will run into all kinds of problems with other applications too)
Old 7th March 2011, 12:03   #191  |  Link
LoRd_MuldeR
Software Developer
The "volume normalization" filter in LameXP already is implemented using the "gain" filter of SoX.
SoX also has a "--replay-gain" parameter, but apparently this can only be used to re-gain files that have already been tagged with ReplayGain information before.
From the SoX manual:
One important use of audio file comments is to convey ‘Replay Gain’ information. SoX supports applying Replay Gain information, but not generating it.
Old 7th March 2011, 22:57   #192  |  Link
John_J
John_J's Avatar
Hello LoRd_MuldeR,
thanks for your fast response!
Yes, you're right ...but Process Monitor isn't installed, yet (fresh installation).
BTW: Is this the right function which specifies temporary tool path?
Global.cpp
 * Get LameXP temp folder
const QString &lamexp_temp_folder(void)
	static const char *TEMP_STR = "Temp";
	if(g_lamexp_temp_folder.isEmpty())
Yeah, I browsed MSDN too and didn't find any function which returns system's temporary folder. However...maybe you're thinking just a little bit too far ahead. It's the purpose of temporary environment variable to change the according folder in an easy way by the user and provide this information system-wide. I'v never seen any corrupted environment variables. Any software uses the correct path, even LameXP 3.18
Correct, but...
That's the reason why I did that post here. Exiting LameXP v4.0 running WinXP leaves behind an empty folder in the wrong path and no other applications are using it. I know, that sounds very pedantic
It's not the required disk space, but the folder left behind
Perhaps you could implement a function to delete it in an XP environment or create it in "%USERPROFILE%\Local Settings\Application Data\LoRd_MuldeR", if you really need this folder at this location and don't want to trust temporary variable.
--JohnJ
Old 7th March 2011, 23:38   #193  |  Link
LoRd_MuldeR
Software Developer
Yup.
Indeed.
Well, users do kind of all strange things, such as messing with environment variables, and then forget about it. Of course when something goes wrong they'll complain to the software author.
Moreover it can even happen that other programs/installers modify environment variables. Consequently we should avoid 'uncertainties' (like depending on environment variables) as much as possible.
BTW: LameXP v3.18 used GetTempPath(), because back at that time I hadn't realized that this function is just a wrapper for getenv("TMP")
Yes, I think this is more a pedantry than a real problem.
After all, given that all applications clean up properly, you should always find the TEMP folder empty, after exiting all running applications
Yes, of course I could do that. But I want to avoid OS-specific code paths as much as possible. This easily creates bugs, which are hard to identify/reproduce...
Old 7th March 2011, 23:39   #194  |  Link
mariush
In Windows, the correct way to do it is to actually use GetTempPath() ... It's designed to return the go through these one after another:
1. TMP
2. TEMP
3. User profile env. variable
4. The Windows folder
You're right, though, they're not guaranteed to be valid, even the example for this API function mentions it: http://msdn.microsoft.com/en-us/libr...=vs.85%29.aspx
However, it's your job to test if the folder actually exists and you can write in it, and only then if it fails, go on and use your own location.
The reason is because there are quite a few particularities and reasons why the TMP and TEMP variables are used - one I can mention from the top of my head is for example this one, where depending on how someone configures Remote Desktop, you get a different temporary folder *on purpose* : http://blogs.msdn.com/b/oldnewthing/.../10119675.aspx
If everything fails, I guess you can always fall back to Application Data and you to be careful which one to pick, because there's two of them: http://blogs.msdn.com/b/oldnewthing/...01/434647.aspx . You can use SHGetFolderLocation with the right CLSID to determine the paths: http://msdn.microsoft.com/en-us/libr...=vs.85%29.aspx
and btw, the correct wording is actually directory, because "folders" are a virtual thing (but encapsulate regular directories): http://blogs.msdn.com/b/oldnewthing/.../10129908.aspx
mariush is offline   Reply With Quote
Old 7th March 2011, 23:58   #195  |  Link
LoRd_MuldeR
Software Developer
That sounds like feasible solution, although it adds some more complexity.
Well, writing my stuff to a sub-directory inside the 'application data' directory should always be admissible.
(Google's installers even install the complete application there )
Actually I use SHGetKnownFolderPath(), if available, as SHGetFolderPath() and SHGetFolderLocation() have been deprecated since Vista.
Old 8th March 2011, 01:00   #196  |  Link
John_J
John_J's Avatar
Now, it goes really the pedantic way...
I'll write a VB script for my personal use to start LameXP and clean up directories afterwards.
Anyways, keep on the excellent work and I hope to see your website back online, soon!
Regards,
JohnJ
Old 8th March 2011, 01:14   #197  |  Link
LoRd_MuldeR
Software Developer
Regards,
JohnJ
I just changed the function like mariush suggested:
LameXP will now try the directory pointed to by %TMP% first and it will only fall back to "%LOCALAPPDATA%\Temp" if the former doesn't exist or isn't writable.
See for details:
http://lamexp.git.sourceforge.net/gi...e6330adf4b4600
Hopefully this will make everybody happy, finally
Old 8th March 2011, 01:35   #198  |  Link
John_J
John_J's Avatar
Yes, indeed it does! Thank you very much!
Old 9th March 2011, 05:39   #199  |  Link
Romario
Romario's Avatar
Location: Qetchua mountains in Peru, and Klingon battlecruiser D'Mar
Thank you for newest snapshot,but, where is changelog ???
Live long and prosperLive long and prosperLive long and prosper
Romario is offline   Reply With Quote
Old 9th March 2011, 11:59   #200  |  Link
LoRd_MuldeR
Software Developer
Changelog.html
And if you need even more details, you may look at the GIT repository's commit log:
http://gitorious.org/lamexp/lamexp/commits/master
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis
