Old 21st September 2015, 16:22   #33001  |  Link
James Freeman
Originally Posted by James Freeman
Can anyone please test for video freezing after pause and unpause several times.
I will try to find in what version this appeared.
Originally Posted by madshi
And you can reproduce this easily with v0.89.x but not at all with v0.88.21? Are you absolutely sure about that?
In that case I'd like to see a debug log with v0.89.3 where this problem occurs.
It's magically solved in 0.89.3.
I have no idea what is the reason and hope it does not come back in future builds, but if you want I can reproduce that in 0.89.2 and send a report.
Or we can lay it aside knowing your list way beyond full, until it pops again (if).
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410.
James Freeman is offline   Reply With Quote
Old 21st September 2015, 17:22   #33002  |  Link
Dlget
Can we use nested if else statement for condition??
Without nested statement,there may confusion if many profile & many parameters are checked
ex-
i want to 1st check fps.
then subdivide them into 480p,720p,1080p,4k etc
Win 7 Ultimate x64
Core i5 2500K 4.2Ghz,Asus p8z68 v pro gen 3
Corsair 2x4GB DDR3 @1600Mhz
Asus Gtx 960 strix OC
Dlget is offline   Reply With Quote
Old 21st September 2015, 18:33   #33003  |  Link
digitech
can somebody help me and post a proper MadVR Profile to use 480p,720p,1080p resolutions for all video files please, i haven't found one like that
digitech is offline   Reply With Quote
Old 21st September 2015, 18:59   #33004  |  Link
kasper93
MPC-HC Developer
@madshi I find extreme black bars case. BlackBars.mpg This is official DVD release. I just wanted to share a sample for reference. I don't really expect madVR to detect such noisy bars.
Ps. I'm even surprised how bad DVD release can get o_O
kasper93 is offline   Reply With Quote
Old 21st September 2015, 19:01   #33005  |  Link
Asmodian
Originally Posted by Serhiyko View Post
What can I do then?
Don't think so
Use xySubFilter instead of the internal subtitle renderer.
ex-
You cannot, also it is possible to be too long if you want to check too many parameters. Do you really need that many though?
How about?:
if (deintFPS > 31) and (srcHeight > 1080) "Fast"
elseif (deintFPS > 31) and (srcHeight > 720) "1080p60"
elseif (deintFPS > 31) and (srcHeight > 480) "720p60"
else "Fast"
I am not sure what you mean. Do you want to have madVR set your monitor resolution based on video resolution?
madVR options explained
Old 21st September 2015, 19:02   #33006  |  Link
avinab
I am on 0.89.3. I am using gtx 980 card latest drivers.But when i am selecting NNEDI3 its showing Jinc3 in OSD.I am using pot player x64.What other setting i have to follow to enable NNEDI3 in windows 10 x64?
avinab is offline   Reply With Quote
Old 21st September 2015, 19:13   #33007  |  Link
Asmodian
Nothing special is needed, it is working well for me using a 980Ti, 855.82, and Win10 x64.
Try resetting to defaults (the batch file in madVR directory), and also try deleting the registry key:
HKEY_CURRENT_USER\Software\madshi\madVR\OpenCL
Old 21st September 2015, 19:35   #33008  |  Link
avinab
I did run the batch.In the registry i didn't find OpenCL dword in madvr folder.please suggest what will i do.I uninstalled Madvr and again installed it,still showing jinc AR.Do i have to reinstall nvidia drivers.?
Old 21st September 2015, 19:52   #33009  |  Link
chros
chros's Avatar
Nnedi3 not working anywhere not even croma upscaling.
MadVR just working fine now....(why?)
It was not working just 4 hours ago here.Now it's working just fine magically.
Nnedi3 is ok.Image doubling is ok
That's pretty interesting: not for me (see my signature, using nvidia), simple Nedi is working, not NNedi3, it crashes MPC-HC immedietly.
Edit: and a huge thanks for the black bar reporting to players! Now it uses less gpu with wide movie content!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config
Old 21st September 2015, 19:53   #33010  |  Link
avinab
I reinstalled the nvidia driver.Now nnedi3 is enabled (in OSD)but player fully freezes.i have to kill the player through task manager.
what more i have to do?i can see render and present queue are 0. i have set it to 19.
Old 21st September 2015, 19:56   #33011  |  Link
digitech
I always have 60 hz Smooth Motion on but on the scaling algorythms profiles i want to be able to have three differents madvr configurations, one for SD (around 480p) HD (720p) and FullHD (1080p) for all kind of video files, not just some of them, i have found some configurations online but in some particular cases they dont apply correctly, example: im playing a sd file but madvr highlights and report like a full HD is playing and viceversa so some configuration must be wrong
Old 21st September 2015, 19:56   #33012  |  Link
yok833
Hello Madshi,
I have the same problem with a freeze and black screen immediately when I launch the new built with NNEDI3 (chroma or doubling - no problem with jinc or other..)
here is a link
https://drive.google.com/file/d/0B6N...ew?usp=sharing
Thank you for your support.. can't wait to use NNEDI3 again
yok833 is offline   Reply With Quote
Old 21st September 2015, 20:06   #33013  |  Link
Asmodian
Maybe 19 is too big? Try the defaults, or even lower.
How about this very simple one:
if (srcHeight > 720) "1080p"
elseif (srcHeight > 480) "720p"
else "480p"
Old 21st September 2015, 20:17   #33014  |  Link
avinab
else "480p"
tried defaults.but still player freezes but audio keeps on playing.
Old 21st September 2015, 20:26   #33015  |  Link
digitech
else "480p"
Thank you for your help Asmodian, just need to copy and paste? or do i have to add something after or before in these three lines
Old 21st September 2015, 20:40   #33016  |  Link
Asmodian
Just a copy and paste.
Also make sure to have your profiles named 480p, 720p, and 1080p.
I have never used potplayer, have you tried MPC-HC as a test to see if it might be a player setting?
I would also try lowering the queues a lot as a test, 3 or below. Present queues too.
Maybe give Windowed Overlay mode a try?
It is a bit of a mystery as your system is very like mine only I am using Zoom Player instead of potplayer and have a 980Ti.
Old 21st September 2015, 23:29   #33017  |  Link
Hprd
Ok, here's a log. Hope this helps.
https://www.dropbox.com/s/qngz0cxw6y...20log.zip?dl=0
Hprd is offline   Reply With Quote
Old 22nd September 2015, 00:08   #33018  |  Link
XRyche
Don't use admin privileges, just double click it. If that still fails, just do the following manually:
1) rename "madVR.ax" to "madVR [release].ax".
2) rename "madVR [debug].ax" to "madVR.ax".
That's basically all the batch file is doing. When you're done, just undo both renamings.
If I try to run the batch file without giving it Admin rights it says "Access Denied" in all cases.
When I rename the files and run the batch without Admin rights its states:
Access denied
Access denied
Access denied
Access denied
Activating release mode failed
Intel i5 3470, EVGA GTX 1050Ti SC ACX 2.0, Windows 10 Pro 64 bit, 16 GB 1600 mhz DDR3 RAM
XRyche is offline   Reply With Quote
Old 22nd September 2015, 00:39   #33019  |  Link
Asmodian
Access denied
Access denied
Access denied
Access denied
If madVR is in program files it needs admin rights.
Old 22nd September 2015, 02:24   #33020  |  Link
XRyche
It is in program files, actually. The issue is that even when i run the batch file with admin rights it says it cannot find madVR.ax. Both madVR.ax and madVR64.ax are both in the same folder as the batch file, plain as day. As they should be.
I've uninstalled, using the uninstall batch file, and deleted the madVR folder and unzipped and used the install batch file 2 or 3 times to make sure I haven't been doing something obviously wrong on my end.
