#1 | Link |
Standalone Compatibility and PQ
I've been encoding for sometimes using AK and Xvid. I'm starting to convert my TV show collection over to Divx for play on My Pocket PC and on a New RJ-1500MKII I bought at New Egg. Since this will be my first standalone Divx player I want to know if I should use Divx 5.21 or Buy Pro for better compatibility ? Also How is Divx compared to Xvid at the same filesize? I'd like all you pros out there to give me your impressions.
Thanks Guys |
#2 | Link |
Is that unit DivX Certified? If not, it is probably better that you use DivX rather than DivX Pro. This will ensure your encodings are limited to MPEG-4 Simple Profile features, which should be the most compatible without knowing the details of the device.
Generally speaking, the latest build of XVID can produce higher quality video than that of DivX 5, but this is partly because it is not designed to be constrained for compatibility with CE, e.g. the portable hardware you are trying to use or DivX Certified DVD players. While very careful tuning will allow you to create compatible files, you should note that some core elements, such as VBV, required for reliable playback are still under development, while other tricky options (e.g. packed B-frames) can easily trip you up if you get it wrong. By limiting XVID in such a way that it also produces CE-compatible files you lose much of the potential quality benefit. DivX Fusion, available from DivX Labs, will produce substantially better quality video than DivX 5.2.1 and, despite my slightly biased opinion , I believe that when working within the bounds of CE compatibility it does produce slightly better quality than XVID (101 forum members will read this far and hit "Reply" to argue the point no doubt! heh).XVID is also working towards compatibility with DivX Certified profiles, so very soon you will have two great codecs to choose from. Doom9 is a great resource for all the latest XVID happenings, as is XVID.org if you are more technically minded. For all the latest on DivX, including access to the DivX Fusion downloads, visit DivX Labs: http://www.divxlabs.com .
DivX Plus Web Player 2.0 Beta DivX Tech Preview - MKV on Windows 7 Developer portal Last edited by DigitAl56K; 2nd March 2005 at 08:51. |
#3 | Link |
RJ-1500DVXII is a new multiregional slim-line design player with the latest and most advanced technologies available in home entertainment today. RJ-1500DVXII is not just a Progressive scan DVD Player, it is a Multi-Media player. RJ-1500 is a DivXR Certified DVD Player, making it one of the first DVD players to pass the stringent certification requirements and be fully certified to play the popular DivXR video format from DivXNetworks , Inc. The RJ1500 is based on ESS's Vibratto family of DVD decoder chips. The Karaoke Function allows connection of 2 microphones for karaoke with all formats of karaoke discs! Adjust echo as well as all other karaoke functions.
Features: Plays DivX 5, Divx 4, DivX 3, and DivX VOD video content in compliance with DivX certified technical requirements and AVI files Full DVD function Format compatibility: DVD/DVD-R/DVD-RW/DVD+R/DVD+RW/VCD/SVCD/CD/CD-R/CD-RW/JPEG/CD+ Full karaoke f unction Enjoy singing by connecting to your amplifier and use our professional karaoke song selection program for songs in DivX, CD+G , DVD, VCD, and MP3 Progressive scan video out 5.1 Channel audio out Region free Multi-TV System Multi-Voltage Specifications : Dolby digital AC-3 VFD display OSD in multi-language Full-function remote control Zoom at still or running mode Frame by frame advance Screen aspect ration (16:9/4:3 letter box/pan scan) Parental lock with password Continuous repeat A-B Repeat mode (chapter/title all) Capable of playing PAL/NTSC discs Automatic screensaver Super slim loader mechanism featuring super error correction Menu driven setup screen Video: NTSC/PAL TV system video output Progressive-scan output (Y, Cb , Cr) Audio: Dolby digital down-mixed 2-ch stereo (L, R) Dolby digital (AC-3) 5.1-channel decoder Dolby digital/DTS/LCPM bit stream output Connectors: Analog mixed 2-ch stereo (L, R) audio S/PDIF coaxial digital audio S/PDIF optical digital audio Composite Video, S-Video Component video (Y, Cb , Cr) 5.1-channel RCA audio Power: 110V-220V, 50Hz/60Hz AC universal power supply Automatic short circuit protection Net weight: 5.3 lbs (2.4 kg) Dimensions (W x D x H): Unit size: 255 x 300 x 43mm Gift box size: 460 x 310 x 60mm Carton size: 490 x 326 x 130mm |
| Thread Tools | |
| Display Modes | |
