11th September 2015, 11:55 | #32861 | Link | |
If running my display in 1920x1080@60 and madVR 10bit (or higher) present queue never gets filled (1-8 / 8) the same with render queue (1-8 / 8) Upload queue is fine (7-8 / 8 If running my display in 1920x1080@23 and madVR 10bit (or higher), then no problems. and If running my display in 1920x1080@60 and madVR 8bit, then no problems. EDIT: Render times: around 5ms, present going crazy 13ms at 1920x1080@60 10bit and 0.10 at 1920x1080@60 8bit and 1920x1080@23 10bit Last edited by MSL_DK; 11th September 2015 at 12:01. |
11th September 2015, 12:02 | #32862 | Link | |
I have a friend with exact the same problem where his PC is using less powerful card for madVR even though he wants to use a better one. I'm not sure about possible solutions. You can google how to activate your cards as the default one or how to quickly switch between the two. I'm pretty sure it's a common issue. I might be wrong. Just shot in the dark but it makes sense to me. Last edited by creativeopinion; 11th September 2015 at 12:19. |
11th September 2015, 14:31 | #32866 | Link | |
Disable ffdshow & SVP. Evrything is doing fine. Does anybody know why this is happening? Last edited by Magik Mark; 11th September 2015 at 14:35. |
11th September 2015, 15:59 | #32868 | Link |
@SweetLow, creativeopinion.
This is not madVR related but I have to ask this. Can you please explain the reason of registering to a forum without posting a single message for MONTHS/YEARS then suddenly popping out with a first post? How did you remember your UN and PW? This is something I have witnessed several times on internet boards, but I truly wonder why? All in good spirit. PS. Welcome!
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410. |
11th September 2015, 16:43 | #32869 | Link | |
btw. what do you mean by how did I remembered my UN and PW. I'm using 1Password. Last edited by creativeopinion; 11th September 2015 at 16:54. |
11th September 2015, 17:29 | #32870 | Link | ||
And that's why I asked the other shortcut question. (see below) Quote:
@James Freeman: then what about me?!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
11th September 2015, 17:47 | #32871 | Link | |||||||||||||||||||
All BT.2020 HDR streams I've seen so far were properly flagged. So I think for now it might be the better option to default to BT.709, unless the flags say otherwise. I'm happy to change this if time proves it would be better. But for now I see no urgency in changing anything. Quote:
The madVR settings are stored in "madVR\settings.bin", if madVR has write access to that folder. Or in HKCU\Software\madshi\madVR\Settings otherwise. Quote:
There are two different kinds of AR changes: 1) The active video area could become bigger. 2) The active video area could become smaller. Case 1) is rather easy to detect. If there are bright pixels in what madVR thought were black bars, obviously the black bar detection is no longer correct. In that case I discard the old detection immediately. So in case 1) madVR should react *immediately*. Case 2) is troublesome because there's a *big* potential for false positives. E.g. look at this image: http://madVR.com/doom9/stuff/falsePositiveDanger.png If I'm not careful, I'd detect pillarboxing in this image. But actually it's a wide screen image which just has a black/dark left and right image area. Things like this do occur in movies once in a while. If I change black bar detection too quickly, I would often fall into such a false positive trap. Because of that, in case 2) I'm intentionally delaying the detection of a modified AR, to avoid false alarms. Practically this means if the active video area gets smaller, I'm waiting a couple of seconds to confirm the new AR, just to be safe. How long I'm waiting depends on the circumstances. Could be anything between 5 and 35 seconds. If I detect heavy pillarboxing in the newly detected AR then there's an increased risk of it being a false positive, so in that case I wait up to 35 seconds. In your sample video there are some such cases where the AR changes and the active video area gets smaller. madVR detects the AR change practically immediately, but it intentionally stays with the old AR detection, just to be safe. You can double check this like this: When the video switches to a new AR which madVR doesn't immediately switch to, pause playback for 40 seconds. Then continue playback. Now the new AR should be detected quickly. This is actually a hack showing that my waiting for 35 seconds can be screwed up by pausing playback. But I don't think this is worth worrying about so I'm probably not going to "fix" that. In order to speed up things with e.g. IMAX movies, I'm storing ARs which were already detected and confirmed, and I'm switching to them immediately. So in IMAX movies this 5-35 second delay should not occur. It only occurs the first time a new AR is detected which is smaller than the previously detected AR. Makes sense? Quote:
A debug log would be great!! |
11th September 2015, 18:17 | #32872 | Link | |
11th September 2015, 18:25 | #32873 | Link | |
11th September 2015, 19:11 | #32875 | Link | ||
MPC-HC Developer
Also there is another issue with this sample. madVR incorrectly detect "stretch to window" instead "touch window from inside" if you start playback after size change. Easiest to reproduce "mpc-hc64.exe AR.ts /startpos 0:30" (or with different sample). This is probably because mpc-hc sets video size to one reported from splitter before starting playback and then after running graph video decoder send proper video size. This change apparently fool madVR to think that we want "stretch to window" while we don't. Or whatever else happen, you will probably know instantly after looking at it. Quote:
11th September 2015, 19:29 | #32876 | Link | |
My laptop actually has two graphic cards, the main one is an independent Radeon Mobility HD4700 series. The secondary one it's the one on the i5 cpu, Intel HD 2000 I think. But this one is disabled by default, actually there are folks who own the same series of laptops trying to enable it with no luck as far as I know. I don't think it is active in any case. Maybe you misunderstood me and thought I was talking about a desktop computer. Anyways, I reproduced the frame skipping this afternoon after a fresh start with the HDMI cable connected from the beginning. So I don't know what to think... I would like to know how to dump as much info as I can into a file in both cases, with frame dropping and with smooth playback, and see what's causing the first scenario. Do you know how to do it? Thanks. |
11th September 2015, 20:19 | #32877 | Link |
madshi,
I just checked the Blu-ray disc again and it's working the Osd shows 1416 1065, 4:3, I was confused about how the current detection method works. What I would like to be able to do is crop the black bars completely and then have the renderer upscale the video to the displays native resolution so that the image fills the screen, ignoring the original AR. Even though it may be technically wrong to do so I personally can't stand Pillarboxed videos, maybe a method similar to EVR's non-linear stretch could be applied in this case. |
11th September 2015, 21:12 | #32878 | Link |
DVD jerky playback
Error report:
DVD playback with madVR results in what seems like frames going back and forth. This looks epileptic shock inducingly bad. It goes something like this 1-2-3-4 3-4-5-6 4-5-6-7 6-7-8-9 When I choose System default or VMR as renderer everything's fine. So that's why I don't think it's MPC-BE or LAV's causing it. Running: Windows 10 64 bits MPC-BE (64-bit) 1.4.5 (build 677) beta LAV filters (splitter, video and audio decoder) 0.65.0 (64-bit) madVR 0.89.2
MPC-BE 1.4.5 | LAV filters 0.65.0 | madVR 0.89.2 |
11th September 2015, 22:16 | #32880 | Link |
Render time 3ms and smooth motion is off always.
off-topic: I've deleted the DVD rip cause it did not have the DTS stream. I'll use handbrake or somesuch to make a single container file (mkv/mp4) next time. Who uses DVD nowadays anyway?
