27th December 2011, 22:08 | #7801 | Link |
They do say talking about your problems helps......
28th December 2011, 00:43 | #7802 | Link |
Just posting this in case it's helpful to anyone having the same problem.
I was having problems with inaudible voices with 6ch AC3 in AVI container (I assume it's commonly caused by the audio not being converted to Stereo), so I thought it was LAV Audio's fault, installed ffdshow (after trying a couple of old LAV Splitter versions) and made sure AC3 was decoded using it inside of MPC-HC, now the audio worked fine. But I didn't settle for that, I then disabled AC3 decoding in ffdshow and re-enabled it in LAV Audio, and played the file using GraphStudio, the audio worked fine too. Turns out the culprit was actually MPC-HC's internal AVI splitter, as soon as I disabled it and let LAV Splitter do its thing, the problem disappeared. Edit: D'oh! Same thing happens with Haali if there's 6ch AC3 on MKV. Edit #2: Everything started to magically work again without any workarounds, I don't know what the hell happened, but I'm glad it did. Last edited by [ReX]; 28th December 2011 at 01:49. |
28th December 2011, 14:03 | #7804 | Link | |
User of free A/V tools
Just for clarification - I do not want to use WMP as my preferred PC media player but I need it to be able to play MKV as this is the way how I stream media files from Windows 7 to my Samsung TV over LAN. |
28th December 2011, 14:17 | #7805 | Link |
The runtimes are not needed anymore.
This will make WMP/WMC recognize mkv files: Code:
Windows Registry Editor Version 5.00 [HKEY_CLASSES_ROOT\.mkv] "PerceivedType"="video" [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MediaPlayer\MLS\Extensions] "mkv"="video" [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Multimedia\WMPlayer\Extensions\.mkv] "Runtime"=dword:00000007 "Permissions"=dword:0000000f "PerceivedType"="video"
MPC-HC 2.2.1 |
28th December 2011, 14:44 | #7806 | Link |
Thanks clsid, much appreciated. Unfortunately, though this registry hack indeed made MKV playable in WMP they're still not visible on my TV. Other containers (AVI/WMV/MP4) stream just fine, oh well, I'll have to live with portable USB HDD (un)plugging once in a while between my PC and TV for the time being...
28th December 2011, 17:51 | #7807 | Link | |
Windows Registry Editor Version 5.00 [HKEY_CLASSES_ROOT\.mka] @="WMP11.AssocFile.MKA" "Content Type"="audio/x-matroska" "PerceivedType"="audio" [HKEY_CLASSES_ROOT\.mkv] @="WMP11.AssocFile.MKV" "Content Type"="video/x-matroska" "PerceivedType"="video" [HKEY_CLASSES_ROOT\.mkv\ShellEx\{e357fccd-a995-4576-b01f-234630154e96}] @="{c5a40261-cd64-4ccf-84cb-c394da41d590}" [HKEY_CLASSES_ROOT\WMP11.AssocFile.MKA] @="Matroska Media File" [HKEY_CLASSES_ROOT\WMP11.AssocFile.MKV] @="Matroska Media File" [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MediaPlayer\MLS\Extensions] "mka"="audio" "mkv"="video" [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MediaPlayer\Player\Extensions\Descriptions] "819"="Matroska Media File (*.mkv;*.mka)" [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MediaPlayer\Player\Extensions\MUIDescriptions] "819"="Matroska Media File" [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MediaPlayer\Player\Extensions\Types] "819"="*.mkv;*.mka" [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Multimedia\WMPlayer\Extensions\.mka] "Extension.Handler"="WMP11.AssocFile.MKA" "Extension.MIME"="audio/x-matroska" "MediaType.Description"="Matroska Media File" "PerceivedType"="audio" "Permissions"=dword:0000000f "Runtime"=dword:00000007 [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Multimedia\WMPlayer\Extensions\.mkv] "Extension.Handler"="WMP11.AssocFile.MKV" "Extension.MIME"="video/x-matroska" "MediaType.Description"="Matroska Media File" "PerceivedType"="video" "Permissions"=dword:0000000f "Runtime"=dword:00000007 [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Multimedia\WMPlayer\Groups\Audio\MKA] @="Matroska Media File" "Extensions"=".mka" "MIME Types"="audio/x-matroska" [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Multimedia\WMPlayer\Groups\Video\MKV] @="Matroska Media File" "Extensions"=".mkv" "MIME Types"="video/x-matroska" [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Multimedia\WMPlayer\MIME Types\audio/x-matroska] @="Matroska Media File" "Extension.Key"=".mka" "Extensions.CommaSep"="mka" "Extensions.SpaceSep"=".mka" [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Multimedia\WMPlayer\MIME Types\video/x-matroska] @="Matroska Media File" "Extension.Key"=".mkv" "Extensions.CommaSep"="mkv" "Extensions.SpaceSep"=".mkv" [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\MediaPlayer\MLS\Extensions] "mka"="audio" "mkv"="video" [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\MediaPlayer\Player\Extensions\Descriptions] "819"="Matroska Media File (*.mkv;*.mka)" [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\MediaPlayer\Player\Extensions\MUIDescriptions] "819"="Matroska Media File" [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\MediaPlayer\Player\Extensions\Types] "819"="*.mkv;*.mka" [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Multimedia\WMPlayer\Extensions\.mka] "Extension.Handler"="WMP11.AssocFile.MKA" "Extension.MIME"="audio/x-matroska" "MediaType.Description"="Matroska Media File" "PerceivedType"="audio" "Permissions"=dword:0000000f "Runtime"=dword:00000007 [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Multimedia\WMPlayer\Extensions\.mkv] "Extension.Handler"="WMP11.AssocFile.MKV" "Extension.MIME"="video/x-matroska" "MediaType.Description"="Matroska Media File" "PerceivedType"="video" "Permissions"=dword:0000000f "Runtime"=dword:00000007 [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Multimedia\WMPlayer\Groups\Audio\MKA] @="Matroska Media File" "Extensions"=".mka" "MIME Types"="audio/x-matroska" [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Multimedia\WMPlayer\Groups\Video\MKV] @="Matroska Media File" "Extensions"=".mkv" "MIME Types"="video/x-matroska" [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Multimedia\WMPlayer\MIME Types\audio/x-matroska] @="Matroska Media File" "Extension.Key"=".mka" "Extensions.CommaSep"="mka" "Extensions.SpaceSep"=".mka" [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Multimedia\WMPlayer\MIME Types\video/x-matroska] @="Matroska Media File" "Extension.Key"=".mkv" "Extensions.CommaSep"="mkv" "Extensions.SpaceSep"=".mkv"
Intel UHD Graphics 750; Win 10 22H2 |
28th December 2011, 19:24 | #7808 | Link |
Mercury, thanks for info but I installed AllShare software (DLNA server provided by Samsung) meanwhile and it works just fine. Its configuration is also much more convenient for me so I'll just stick with that
29th December 2011, 02:52 | #7809 | Link | |
29th December 2011, 16:42 | #7813 | Link | |
It doesn’t work if i ad LAV Audio to External Filters in MPC-HC so it gets loaded, then MPC-HC crash!
You shoot me in a dream, you better wake up and apologize. |
29th December 2011, 17:20 | #7814 | Link | |
I just find out that disabling the "use DTD-HD framing for all DTS types" option allows lavaudio to bitstream without crashing MPC, but the sound is really pitchy, it's like 1.5x faster than it should(I've never heard the chipmunks singing a Beatles song before) Last edited by mllmx; 29th December 2011 at 17:29. |
29th December 2011, 17:59 | #7816 | Link |
Well it’s really more of a personal preference thing, but I can tell you from my own experience that for instance the PCM signal is fairly quitter than the bitstreamed one so I have to use more power to achieve the same volume, I can’t use any sound mode with PCM (PLIIx, etc), I have to rely on windows mixer that may or may not alter the original signal or use reclock with WASAPI exclusive hence adding one more link to the filter chain, you also may encounter with the Bluray swap surround thing (BS-SS) and finally I really like to see my receiver lighting up the DTS, DTS-HD logo instead of the “MULTCH IN 7.1” legend.
29th December 2011, 20:26 | #7817 | Link |
I have an MKV file that plays fine when using the MPC-HC decoder but not when using the LAV Video Decoder (CUVID disabled). It plays a second or so, then freezes, then continues, with a crazy graph. Here's a sample:
http://www.mediafire.com/?54asyk494jkgd20 It doesn't seem to matter if I tick or untick LAV Splitter (which is set to "preferred") within MPC-HC, although I'm not entirely sure whether it's being used or not. |
29th December 2011, 21:29 | #7818 | Link | |
30th December 2011, 15:22 | #7819 | Link |
Nev,
This is going to sound like a rather dumb question. Using Lav + MPC HC, if I have these settings checked off only subtitles that have been flagged as forced will be presented to MPC HC, correct? The reason why I ask, I was doing a test to see if MakeMKV was setting the forced subtitle flag. I created an mkv of District 9, and using the LAV setting above the forced subtitles appear properly in MPC HC (which would indicate that the forced flag has been properly set). However, if I take the same mkv and dump it into mkvmerge the subtitles are not flagged as forced, just default. I am guessing now that this may just be an issue with how mkvmerge shows (possibly not keeping the flag MakeMKV creates)
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net |
30th December 2011, 15:32 | #7820 | Link |
Sounds like mmg has it wrong.
You can always check in MPC-HC by going to the Filters -> LAV Splitter context menu, which would show the flags it detected.
