9th April 2009, 11:34 | #341 | Link |
HDConvertToX author
for all having problem with final size
please try this build: http://www.64k.it/andres/data/hdconv...rtToX-size.exe THANKS! BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
9th April 2009, 11:49 | #342 | Link | |
Give it a hour or 2 |
9th April 2009, 11:52 | #343 | Link |
HDConvertToX author
you can ALREADY check the bitrate , and see if different then encode before
BHH
9th April 2009, 12:35 | #345 | Link |
HDConvertToX author
yea
i have added some check for audio (since it's the culprit!) now HDC will be able to correct handle bitrate when: more then 1 audio track is selected when copy audio is selected i will wait your report! (please post the "make report", but don't forget to edit file name...) BHH
9th April 2009, 14:10 | #347 | Link |
HDConvertToX author
thanks A-star!
i suggest to paste text in post (attachment requires a mod approval and days) BHH
9th April 2009, 15:38 | #349 | Link |
HDConvertToX author
@vgiozo
please post the make report and a sample for file causing problem to dgavcindex BHH
9th April 2009, 15:46 | #350 | Link |
HDConvertToX author
update hdc
>fixed bitrate computing (beta) >fixed every time you open a h264 video, a Copy Video was added >added audio and sub tag language when input file is mkv >fixed copy HD audio from source file to avi >other minor corrections and cosmetic fixes BHH
10th April 2009, 08:28 | #351 | Link |
HDConvertToX author
update HDC
>fixed bitrate computing when audio is VBR based (mp3 vbr , nero quality, ogg ) (beta) BHH
10th April 2009, 09:52 | #352 | Link |
Even when I enable <Force DirectShowSource>, DGIndex (or DGAVCIndex) is launched. I this intentional?
Any possibility to use the NV CUDA version of the DG tools? Perhaps with a Hidden Options file pointing to the directory of these tools? Could you add a hidden options file for <x264+m2ts>? Any possibility to customize the default type of resizing filter? (I could possibly edit the hdconverttox....avs during the audio extraction phase, right?) Thanks for considering. No hurry. |
10th April 2009, 10:19 | #353 | Link |
HDConvertToX author
update HDC
>fixed launch of dgindex/dgavc when Force Direct Show Source is checked >added x264+m2ts.txt as hidden options for starting with x264 as codec and m2ts as container @Sharc about resing: i will actually don't add an option to change it. you will be hable to edit the avs during audio encoding about nv cuda: while i have the license from Neuron2 (i buy it several weeks ago), my building environment is LINUX or a WIN2003 Server without discrete video cards so.. i can even add support for it, i cannot test it BHH
10th April 2009, 23:10 | #355 | Link |
I got a whole bunch of :
[fraps @ 0x2e90060]reget_buffer() failed [fraps @ 0x2e90060]picture size invalid (0x0) [fraps @ 0x2e90060]reget_buffer() failed [fraps @ 0x2e90060]picture size invalid (0x0) [fraps @ 0x2e90060]reget_buffer() failed [fraps @ 0x2e90060]picture size invalid (0x0) [fraps @ 0x2e90060]reget_buffer() failed [fraps @ 0x2e90060]picture size invalid (0x0) [fraps @ 0x2e90060]reget_buffer() failed [fraps @ 0x2e90060]picture size invalid (0x0) when trying to encode Fraps video (in AVI container, no audio) to x264 in MP4 |
11th April 2009, 07:14 | #358 | Link |
HDConvertToX author
@Mgz
try checking "Force DirectShow Source" @Crono141 with 5.1 support check the audio preset BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
