7th February 2008, 01:13 | #22 | Link |
Hey Now!
Xolo can you somehow host those bluray profiles somewhere that I can download them? Your attachments are still pending approval. I used the HD fast profile seems to work good with bluray.
8th February 2008, 11:02 | #23 | Link |
http://rs91.rapidshare.com/files/900...y_profiles.zip
How long should one usually wait to see them aproved? |
8th February 2008, 13:48 | #24 | Link |
Mr. Sandman
depends on the moderators, maybe they didnt read this thread or just forgot to approve it.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 8th February 2008 at 13:52. |
8th February 2008, 15:04 | #25 | Link | |
Hey Now!
8th February 2008, 21:29 | #26 | Link |
Hello
thank's to this tutorial but i've error message step 3 mui generator with video encoded h264 with megui and your bluray profile. this is the message: "Error: invalid_vui_parameters_present_flag_value=0" Where mistake? thanks |
8th February 2008, 22:41 | #29 | Link |
unmodifed?
Did you do something with the file before using MUI, like h264info or something like that? Do you have last megui? That makes no sense to me...I created the profile modifying HD DVD profile, which has vui_parameters_present_flag_value=1 Do this happen to anyone else? Last edited by XolocoTuxmaster; 8th February 2008 at 22:46. |
8th February 2008, 23:01 | #33 | Link |
Using tsremux to extract is never a good idea...better use xport
But vui parameters present flag value is set by x264, and it normally turns to 1 if you use any vui parameter (like --sar). And in addition...I used the HD DVD profile to create this and HD DVD profile is supossed to turn vui value to 1 As I said...this makes no sense to me, have asked "megui profiles expert" Sharktooth http://forum.doom9.org/showthread.ph...39#post1097939 |
9th February 2008, 12:53 | #35 | Link | |
Now i want to mux this h264 video file with ac3 6ch dolby digital original audio..... and it not works... I must convert ac3 6ch in aac 6 ch? thanks |
10th February 2008, 00:05 | #36 | Link | |
Hey Now!
one thing i did notice is that your profile takes some 2 hours longer than the hd profile, what is the difference are you using really higher bitrates? To fit on a dvd-9 my avg bitrate is around 7100 so I am wondering if it is overkill using your profile over the dvd-hd one for a 720p video. Last edited by jamos; 11th February 2008 at 15:38. |
11th February 2008, 07:39 | #37 | Link |
I have many problem with vc-1 encoded to h264 when I choose file format to RAWAVC (for using tsmuxer after). the video .264 obtained is white flashed many times !.... Do you know why?
Thanks Last edited by toftrem; 11th February 2008 at 07:43. |
11th February 2008, 23:35 | #38 | Link | ||
Be patient wait for Sharktooth overview |
13th February 2008, 23:13 | #40 | Link | |
most mkv got borders ripped. your resolution must be 1280x720 or 1920x1080 else you get sound & black screen! so you must re encode to add the borders and then it works fine on powerdvd and bluray PS3! i did also change the resolution with h264info 0.18 but i did allways get black or green screen.. until i did resize it with avisynth script. but anyway nice work! maybe you can make and easy automatic made disc menu guide and howto import into scenarist? is there a easy way todo? Adobe encore? or other tools? edit: i also found out that when i try to convert srt to scenarist sub format.. it only generates 1 png pic with xml file. and seems to repeat allways that 1 subtitle image in the movie!? weard..?.. am i doing something wrong? or is it becoz Subtitle Workshop4 is behaving weard on vista? best regards, PleXuS Last edited by PleXuS; 13th February 2008 at 23:37. |
