30th May 2007, 08:58 | #341 | Link | ||
MKVToolNix author
http://www.bunkus.org/videotools/mkv...20070530-1.rar
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
31st May 2007, 02:39 | #342 | Link | |
Mmmmmmmmangoscam!
I'll be trying it on DTS for Pirates of the Caribbean in a bit. Last edited by Neo Fagin; 31st May 2007 at 02:41. |
31st May 2007, 09:32 | #343 | Link | |
Emperor building empire
@Mosu
Thanks for your time... Pascal |
31st May 2007, 22:42 | #344 | Link | |
Mmmmmmmmangoscam!
1st June 2007, 07:39 | #345 | Link |
MKVToolNix author
Hmm, so it still does not skip the appropriate amount of byets... I hate MPEG. Could you please upload 10 MB of your file? Thanks.
8th June 2007, 14:54 | #348 | Link |
Pain and suffering
@Mosu
Any news on fixing Nal-Size on H.264 muxed .mkv files? The ones with nal size 3 can't be played with the latest cyberlink H.264 decoder. If no news yet, or not possible soon, can you advice me on how to "fix" the nal-size by remuxing, but keeping the same audio delay? (extra question: How can we see audio delay used in a muxed .mkv file?) A method used now is: Demux video from .mkv Open wrong bad .mkv, select audio only Then open the H.264 video again and remux with nal-size 4 P.S. Why is nal-size 3 still selectable? For H.264 its not valid, but for other video formats it is? |
15th June 2007, 12:41 | #349 | Link |
Multiple video tracks ???
I made 3xH264 encodes of 'Band of Brothers 1'... over-sampled or upscaled to 1440x800, 1280x720 and 1024x576... @ Q23, Q22 and Q19 respectively...
I also made 3xMP4a audio tracks... 5.1 surround @ 48 KHz (full dynamic range), 5.1 surround @ 44.1 KHz (reduced dynamic range) and 2.0 stereo (reduced dynamic range)... I then muxed the lot, hoping that a friend of mine could do a quality comparison of BoB 1 at each of the 3 encode resolutions on his 40 inch HD LCD TV. The muxing goes fine but I can't switch video tracks in Zoom Player... the other track is ticked, but not played... what gives... ??? Pascal Last edited by delacroixp; 15th June 2007 at 12:42. Reason: TV |
16th June 2007, 19:19 | #351 | Link | |
@KoD
Also, each video has the same content... so the audio tracks relate equally... for the response... Pascal |
18th June 2007, 08:28 | #355 | Link | |
@foxyshadis
Pascal Btw sorry for editing your post... |
21st June 2007, 16:47 | #356 | Link |
Pain and suffering
@Mosu:
AC3 issue with .mkv (mkvextract(gui)) Delaycut 1.2.1.2: http://www.free-codecs.com/download/..._Corrector.htm Source file: skyone_ac3_fuckup.ts mkv file with Haali's gdsmux.exe: skyone_ac3_fuckup.mkv AC3 file demuxed from .ts with mplayer: skyone_ac3_fuckup_ts_demuxed_mplayer.ac3, info: Code:
====== INPUT FILE INFO ======================== File is ac3 Bitrate (kbit/s) 384 Act rate (kbit/s) 384.000 File size (bytes) 1702880 Channels mode 2/0: L+R Sampling Frec 48000 Low Frec Effects LFE: Not present Duration 00:00:35.476 Frame length (ms) 32.000000 Frames/second 31.250000 Num of frames 1108 Bytes per Frame 1536.0000 Size % Framesize 992 CRC present: YES ============================================= ====== TARGET FILE INFO ====================== Start Frame 0 End Frame 1107 Num of Frames 1108 Duration 00:00:35.456 NotFixedDelay 0.0000 ============================================= Or: mkvextract tracks gegdsmuxed.mkv 2:ditisdusfuckedup.ac3 mkvextract -V mkvextract v2.0.0 ('After The Rain Has Fallen') built on Apr 16 2007 08:48:50 info: Code:
====== INPUT FILE INFO ======================== File is ac3 Bitrate (kbit/s) 64 Act rate (kbit/s) 64.000 File size (bytes) 1653652 Channels mode 2/0: L+R Sampling Frec 0 Low Frec Effects LFE: Not present Duration 00:03:26.706 Frame length (ms) 16.000000 Frames/second 62.500000 Num of frames 12919 Bytes per Frame 128.0000 Size % Framesize 20 CRC present: YES ============================================= ====== TARGET FILE INFO ====================== Start Frame 0 End Frame 12918 Num of Frames 12919 Duration 00:03:26.704 NotFixedDelay 0.0000 ============================================= (all files packed as ac3_issue.7z and uploaded to your FTP) EDIT: The source .ts file (ever muxed to .mkv) won't play here at all, only takes 100% cpu, and then i can stop it with alt F4. Hope Haali can examine the .ts file for us, but it seems the audio file is very fucked Last edited by bob0r; 21st June 2007 at 17:04. |
22nd June 2007, 10:17 | #357 | Link | ||
MKVToolNix author
22nd June 2007, 10:19 | #358 | Link | ||
MKVToolNix author
22nd June 2007, 14:47 | #359 | Link |
Pain and suffering
@Mosu:
When i open a .mkv H.264 file in: 2.0.2 - 22 Jun 2007, i still can not change the nal-size in Format specific options. The option is greyed out. (Note: all my .mkv are now nal-size 4, i have fixed them manually, so does it detect nal-size 3, or is it a bug?) |
22nd June 2007, 15:35 | #360 | Link |
MKVToolNix author
Hmm you're right, I haven't updated mmg yet, only mkvmerge. No, mmg does not detect the current NALU size length at all, it just defaults to '3'. I'll change both.
