11th February 2007, 03:00 | #301 | Link |
Didée Fan
Leak,
Neuron2 made kernel deinterlacer, AND Leak Kernel Deinterlacer. Link I want the Leak Kernel Deinterlacer in the Deinterlacer section of FFDshow. Pretty please, somebody please put it in there. haruhiko_yamagata, I can't see the FFDshow video decoder icon when I use YUY2 and use the HW bob deinterlacing. What output colorspace do I use to both see the icon and use HW deinterlacing ? Last edited by Jeremy Duncan; 11th February 2007 at 03:08. |
11th February 2007, 06:02 | #302 | Link | |
http://forum.doom9.org/showthread.php?t=81322
Narrator: And of course, with the birth of the artist came the inevitable afterbirth - the critic. (History of the World part 1) |
11th February 2007, 09:33 | #305 | Link |
Use ffdshow only in:
I coded for the feature request "Use ffdshow only in:".
http://ffdshow-tryout.sourceforge.ne...hp?p=1000#1000 I think the default should be off, but I would like to add exe names as many as possible so that users can do by just checking it. Please add as many as possible (Send Private Messages for me or reply there). |
11th February 2007, 10:00 | #306 | Link | |
ffdshow user
FFdshow should work with some media players.No more games trouble or other untested applications.More like a software compatibility list. |
11th February 2007, 10:07 | #307 | Link | |
To be on by default, the list has to be comprehensive. |
11th February 2007, 12:11 | #309 | Link | |
- ffdshow can be loaded only by applications on the list ? It should be easy for the user to add new entries to the list or to remove some. A text box like the one for blacklists that the user can edit on its own would allow such user editing. |
11th February 2007, 12:33 | #310 | Link | |
like this, the text box is small. Adding one is easy, while removing one is not. Currently the list is alphabetically sorted automatically (Should it be sorted?). |
11th February 2007, 13:27 | #311 | Link |
The text box certainly wouldn't win the 1st prize in a usability contest but since there's not much space, I think this is the best option.
Sorting makes entries definitely easier to find (especially when you can't scroll). Last edited by fastplayer; 11th February 2007 at 13:42. |
12th February 2007, 00:32 | #312 | Link |
Edit: I have removed the sections for each builder on the tryouts forums. There is not really a need for those. The only real activity takes place in bugs/features/other.
Shall I also remove language forums that are currently empty? http://ffdshow-tryout.sourceforge.net/phpBB2/
MPC-HC 2.2.1 Last edited by clsid; 12th February 2007 at 00:51. |
12th February 2007, 00:50 | #313 | Link | |
Yes, I can confirm the above. For me it works correctly if: - I either choose XviD as a decoding library, - or I choose libavcodec + XviD MMX iDCT manually. Libav + libmpeg2 is buggy, as shown on screens and tested by the others (thanks, fastplayer), and the auto setting is still playing tricks on me, but it seems only on me, so don't worry - must be some software's witchcraft in my case. I've just downloaded rev 910 by xxl and rev 895 by clsid (ICL9, sse - since this is what I usually use). I guess the 910 also has the above feature. Gonna test this week, when I find enough time. cheers, HDBR77 PS. This is the sample I've cut out of my full encode, and this is the only one I've used for testing so far (the others are short one-pass samples with various cqms, but I haven't tried them with the given revision). EDIT: Revision 902 - Directory Listing Modified Sat Feb 10 12:06:28 2007 UTC (36 hours, 8 minutes ago) by h_yamagata new OSD item IDCT(libavcodec) Gonna try auto iDCT with 910 and report back.
"Only two things are infinite: the universe and human stupidity, and I'm not sure about the former."
12th February 2007, 00:59 | #315 | Link | |
I don't care if it's on or off by default, however it should containt as many players' executables as possible, if it should be enabled by default, as you stated. Here is a thread that contains some exotic ones (at least for me) too, so you might have a look at this: http://forum.doom9.org/showthread.php?t=120112
12th February 2007, 01:05 | #316 | Link |
A lot of video conversion progs should also be added to the list.
Perhaps instead of a tiny textbox, it should get its own page (together with "don't use ffdshow in ..."). Then a scrollable textarea could be used, with 1 item on each row.
MPC-HC 2.2.1 |
12th February 2007, 07:08 | #317 | Link | |
12th February 2007, 23:33 | #318 | Link | |
Good luck with your work, guys!
13th February 2007, 06:48 | #320 | Link |
Can you tell me why deblocking filters don't work in that file?
http://akross.ruweb.net/videos/ac2006/[AKROSS_Con_2006]_AlexDaikou_-_DANSU_preview.avi |
