Old 16th August 2009, 21:02   #4581  |  Link
m0nkie
when encoding audio file output file has very distinguishable click (sound of the click) in the beginning. i found out it disappears when i uncheck 'normalize peeks'. is there a solution for using normalize?
m0nkie is offline   Reply With Quote
Old 16th August 2009, 21:29   #4582  |  Link
owais
guys what is the latest version? i m having build 1051, is this the latest one?
p.s i just went to megui sourceforge bla bla there was 1053
owais is offline   Reply With Quote
Old 16th August 2009, 22:12   #4583  |  Link
St Devious
Hardware Aspirin
megui hasn't updated anything in a while, don't know what's up
St Devious is offline   Reply With Quote
Old 16th August 2009, 22:15   #4584  |  Link
cy
question about threading
Not sure if i should ask this here or in the AVC forum, but anyway;
I've been wondering if it's "normal" that when thread input is set to "0" (auto), my cpu (q9450 @ 3.4GHz) usage
never reaches 100%, but fluctuates between 65% and 97%, with ~75% being the average.
I seem to remember that when i had a dualcore cpu (E6600), cpu usage always was at 100% when encoding.
I don't think avisynth is bottlenecking anything, because i don't use cpu intensive filters or such.
Here's an example of a script i might use:
# Set DAR in encoder to 37 : 20. The following line is for automatic signalling
global MeGUI_darx = 37
global MeGUI_dary = 20
DGDecode_mpeg2source("Y:\MOVIES\Absence of Malice (1981) PAL DVD\VIDEO_TS\VTS_02_1.d2v", info=3)
ColorMatrix(hints=true, threads=0)
crop( 10, 12, -10, -16)
Undot() # Minimal Noise
I've been doing some testing and i've noticed, that when i manually change the thread input to something higher
than 6 threads, cpu usage goes up and so does fps encoding rate.
I need to at least set threading to 10 or 12 to fully saturate the cpu.
For example, using the above script to encode a pal dvd with:
- unrestricted 1 pass const. quality HQ
- tuning = film
- CRF18
- threads=0
- otherwise default settings
program --profile high --preset fast --tune film --crf 18 --thread-input --deblock -1:-1 --b-adapt 2 --b-pyramid
--ref 5 --no-mbtree --me umh --subme 6 --partitions all --trellis 2 --output "output" "input"
encoding speed is ~20.5 fps.
However, if i manually set threads=10, i get 99-100% cpu usage and ~26.8 fps, which is a ~30% speedup.
I've searched around to find more information regarding threading and cpu usage, especially with quadcore cpu's without hyperthreading, but
haven't found conclusive information, so i'm still wondering if this is "normal" or not.
I thought leaving threading at 0 (auto), which in my case would make 6 threads ( 4x 1.5) would be the best, but this doesn't seem to be the case.
Are there any "important" downsides to me upping the threading to 10 or 12 to saturate my cpu?
Are there folks with a quadcore cpu who get 100% cpu usage and max encoding speed with threads set to auto?
(Btw, i'm using the latest megui and x.264, avisynth 2.5.8, ffdshow beta6 rev 2527)
cy is offline   Reply With Quote
Old 17th August 2009, 00:25   #4585  |  Link
St Devious
Hardware Aspirin
strange errors with 1053
Old 17th August 2009, 01:20   #4586  |  Link
ztomic
ztomic's Avatar
--[NoImage] Standard error stream: C:\Program Files\megui\tools\x264\x264.exe: unrecognised option `--no-mbtree'
Just installed megui and got this error on first job try. Fixed with x264 r.1206 downloaded from sharktooth-- see post http://forum.doom9.org/showthread.php?t=89979
ztomic is offline   Reply With Quote
Old 17th August 2009, 02:00   #4587  |  Link
tebasuna51
tebasuna51's Avatar
Please and samples (short samples is enough).
Old 17th August 2009, 02:05   #4588  |  Link
owais
i m alive !!!
but i hav seen latest version of x264 1210
Old 17th August 2009, 09:27   #4589  |  Link
SacredCultivator
Just wondering... with the new patches for x264(1210), mkvmerge(2.9.8), nicaudio(2009-08-12), anyone NOT able to update to the latest?
When I try to update those three I get:
Updating x264. File 1/3.
Updating mkvmerge. File 2/3.
Updating nicaudio. File 3/3.
Update completed.
0 file was completed successfully
3 files had problems.
EDIT:
Nevermind, seemed to have fixed itself after trying again.
SacredCultivator is offline   Reply With Quote
Old 18th August 2009, 11:07   #4590  |  Link
easy2Bcheesy
easy2Bcheesy's Avatar
Oops... answered earlier!
easy2Bcheesy is offline   Reply With Quote
Old 18th August 2009, 16:10   #4591  |  Link
m3mbran3
I'm not sure what has happened to the original megui update servers but they have not been updated for a while. i'm using a server kurtnoise mentioned somewhere in this thread, you can add it by going to the settings then
extra config -> configure servers
delete what you have and add
http://kurtnoise.free.fr/MeGUI/
I'm not sure on how upto date it is with the various programs but it is picking up 0.3.1.1053 as the latest version.
m3mbran3 is offline   Reply With Quote
Old 18th August 2009, 16:22   #4592  |  Link
St Devious
Hardware Aspirin
thank you
Old 18th August 2009, 16:34   #4593  |  Link
nakTT
That link is for experimental version. The 'official' version is still unchanged.
nakTT is offline   Reply With Quote
Old 18th August 2009, 17:18   #4594  |  Link
m3mbran3
I like to live life on the edge
Old 18th August 2009, 21:27   #4595  |  Link
chuck67
will i need a codec pack installed before i install meGui?
chuck67 is offline   Reply With Quote
Old 18th August 2009, 21:29   #4596  |  Link
St Devious
Hardware Aspirin
no, just install Avisynth, ffdshow tryout and Haali Splitter and you should be fine.
Old 18th August 2009, 21:31   #4597  |  Link
nurbs
No, in fact it's not recommended to install codec packs. It might be helpful if you installed ffdshow.
edit:
Late again. I agree with everything St Devious said.
Old 19th August 2009, 03:17   #4598  |  Link
chuck67
ok thank u guys for ur help.
Old 20th August 2009, 00:27   #4599  |  Link
Rodger
I found a bug! But it has to be added recently?!
I´m sure otherwise I´d have it noticed quicker.
See the video HERE for what I mean.
greetz
Rodger
Rodger is offline   Reply With Quote
Old 20th August 2009, 14:59   #4600  |  Link
rapscallion
NY Frame of Mind
rapscallion's Avatar
libmpeg2 or libavcodec ?
I'm processing an BD mpeg2 stream and the ffdshow video setting gives 2 choices for the codec, libmpeg2 or libavcodec.
I've done a search and can't find info on which one is preferred. They both work, however in the video preview libav starts the video a a few frames later, with a pixelated screen (still). Once play is started it's fine. I don't know if that's significant, so thought I'd ask here which one to use?
"Talk to me Goose"
rapscallion is offline   Reply With Quote
megui
