11th August 2009, 15:58 | #1781 | Link |
Acid fr0g
Sir, aye, sir!
analyze.avs #HDConvertToX Analyze Avisynth Script LoadPlugin("D:\eseguibili\media\hd convert\filters\DirectShowSource.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\FFMS2.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\autocrop.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\DGAVCDecode.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\DGDecode.dll") try { DGSource("E:\in\FULL_METAL_JACKET_B5A\BDMV\STREAM\00003.m2ts") last = IsYV12(last) ? ConvertToYV12(last) : last sep=" " WriteFile("D:\eseguibili\media\hd convert\analysis\info.txt", "Framecount","sep","Framerate","sep","WIDTH","sep","HEIGHT") autocrop(mode=2,wmultof=4,hmultof=16,samples=34,aspect=0.000000,threshold=28,samplestartframe=125) Trim(0,2) } catch (err) { BlankClip() WriteFileStart("errorlogfile.txt", "VersionString()", "err") } Code:
error.avs #HDConvertToX Analyze Avisynth Script LoadPlugin("D:\eseguibili\media\hd convert\filters\DirectShowSource.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\FFMS2.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\autocrop.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\DGAVCDecode.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\DGDecode.dll") directshowsource("E:\in\FULL_METAL_JACKET_B5A\BDMV\STREAM\00003.m2ts",audio=false) last = isRGB(last) ? ConvertToYV12(last) : last last = isYUY2(last) ? ConvertToYV12(last) : last sep=" " WriteFile("D:\eseguibili\media\hd convert\analysis\info.txt", "Framecount","sep","Framerate","sep","WIDTH","sep","HEIGHT") autocrop(mode=2,wmultof=4,hmultof=16,samples=34,aspect=0.000000,threshold=28,samplestartframe=125) Code:
errorlogfile.txt AviSynth 2.58, build:Dec 22 2008 [08:46:51]Script error: there is no function named "DGSource" (D:\eseguibili\media\hd convert\analysis\analyze.avs, line 8)
@turment on Telegram |
11th August 2009, 16:17 | #1782 | Link |
HDConvertToX author
use the live update button
thanks (grazie!) BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
11th August 2009, 19:53 | #1783 | Link |
Hi again
I have an problem encoding multiple episode dvds. Ripped with DVDFAB in full disc mode. In Hdc loading the ifo file and analyze. Selecting the first episode. Do my settings crop, resize. Save to queue and than begin to select the 2 episode But when using visual cropping and preview it loads the first epsiode again. Rembember i analyze each epsisode! is this a bug or working as intended? thx Last edited by Jaspa; 11th August 2009 at 20:02. |
11th August 2009, 20:56 | #1784 | Link |
Acid fr0g
problems with nvtools beta 7
analyze.avs #HDConvertToX Analyze Avisynth Script LoadPlugin("D:\eseguibili\media\hd convert\filters\DirectShowSource.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\FFMS2.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\autocrop.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\DGAVCDecode.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\DGDecode.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\DGDecodeNV.dll") try { DGSource("E:\in\FULL_METAL_JACKET_B5A\BDMV\STREAM\00003.m2ts") last = isRGB(last) ? ConvertToYV12(last) : last last = isYUY2(last) ? ConvertToYV12(last) : last sep=" " WriteFile("D:\eseguibili\media\hd convert\analysis\info.txt", "Framecount","sep","Framerate","sep","WIDTH","sep","HEIGHT") autocrop(mode=2,wmultof=4,hmultof=16,samples=34,aspect=0.000000,threshold=28,samplestartframe=125) Trim(0,2) } catch (err) { BlankClip() WriteFileStart("errorlogfile.txt", "VersionString()", "err") } Code:
error.avs #HDConvertToX Analyze Avisynth Script LoadPlugin("D:\eseguibili\media\hd convert\filters\DirectShowSource.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\FFMS2.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\autocrop.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\DGAVCDecode.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\DGDecode.dll") LoadPlugin("D:\eseguibili\media\hd convert\filters\DGDecodeNV.dll") last = isRGB(last) ? ConvertToYV12(last) : last last = isYUY2(last) ? ConvertToYV12(last) : last sep=" " WriteFile("D:\eseguibili\media\hd convert\analysis\info.txt", "Framecount","sep","Framerate","sep","WIDTH","sep","HEIGHT") autocrop(mode=2,wmultof=4,hmultof=16,samples=34,aspect=0.000000,threshold=28,samplestartframe=125) Code:
errorlogfile.txt AviSynth 2.58, build:Dec 22 2008 [08:46:51]DGSource: Invalid index file, not DGA, DGM, or DGV! (D:\eseguibili\media\hd convert\analysis\analyze.avs, line 9)
11th August 2009, 21:16 | #1786 | Link |
WMV problems
Just tried this program to day, thought I may replace the aging Encode360 and the "works most of the time" WME Assistant but can't get it to work at all.
When I try to convert an mkv file to wmv the program ends with a error result. It demuxes the mkv into a .h264, .avs and .AC3 but then flashes a message "failed with error" but it goes so fast you can't read it before the window closes. There is no record of any failure or error in any of the generated log files. Also, if I select anything aside from "use best decoder" it doesn't demux the video, only the audio. Bottom line: If I use the "use best decoder" option I end up with the audio and video demuxed in a "job" directory and it fails before transcoding. Below is the report. Code:
HDConvertToX v.2.1.458.3528 "Isotta" report Input File: z:\__hd to convert - tv\test file s05 e10.mkv ( Z:\__HD to Convert - TV\TEST FILE S05 E10.mkv ) Codec Video: avc Width / Heigh : 1280 / 720 Framerate / Framecount: 23.976 / 35703 Duration(hh:mm:ss): 0:24:50 Aspect Ratio: 1.7778 Resized resolution: 1280 / 720 Crop Values : 0:0:0:0 No Resize & Crop: On Start Video Configuration -> Encoding Settings: WMV in WMV Encoding Preset: 10 Final Size: 100 Priority: idle Denoise Level: Super Light Video Handling: Use Best Decoder -> End Video Configuration Start Audio Configuration -> Audio Codec: WMA Audio Audio Bitrate/Quality: 384_48_6_16 Audio Channels: 2 MP3 Mode: abr Normalize: On Audio handling: Use Eac3to as demuxer Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 2: ac3, 2.0 channels, 384kbps, 48khz, dialnorm: -> End Full Audio List Full Subtitle List-> (*** mean selected) *** NONE -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> ColorMatrix: On -> End Advanced AviSynth Start Queue -> prompt $d $t $_$P$G "C:\Program Files\HDConvertToX_2.1.458.3528\applications\eac3to.exe" "z:\__hd to convert - tv\test file s05 e10.mkv" 1:"C:\Program Files\HDConvertToX_2.1.458.3528\analysis\hdconverttox.h264" "C:\Program Files\HDConvertToX_2.1.458.3528\applications\DGAVCIndex.exe" -i "C:\Program Files\HDConvertToX_2.1.458.3528\analysis\hdconverttox.h264" -o "C:\Program Files\HDConvertToX_2.1.458.3528\analysis\movie.dga" -f 0 -e "C:\Program Files\HDConvertToX_2.1.458.3528\applications\eac3to.exe" "z:\__hd to convert - tv\test file s05 e10.mkv" 2: "C:\Program Files\HDConvertToX_2.1.458.3528\analysis\hdencodertox-pid2.ac3" cscript.exe "C:\Program Files\HDConvertToX_2.1.458.3528\applications\WMCmd.vbs" -input "C:\Program Files\HDConvertToX_2.1.458.3528\analysis\hdconverttox_test file s05 e10.avs" -output "C:\Program Files\HDConvertToX_2.1.458.3528\analysis\hdconverttox_full_test file s05 e10.wmv" -v_codec WVC1 -v_preset better -v_mode 2 -v_quality 100 -a_codec wmapro -a_mode 0 -a_setting 384_48_6_16 -> End Queue AviSynth Script -> Working with files: Z:\__Downloads\job0\hdconverttox_test file s05 e10.avs AVCSource("Z:\__Downloads\job0\movie.dga") hqdn3d(1) video=last NicAC3Source("Z:\__Downloads\job0\hdencodertox-pid2.ac3") Normalize() AudioDub(video,last) return last -> End AviSynth Script |
11th August 2009, 22:59 | #1788 | Link |
something is wrong
complete APP is crashing when i try to test interlace pattern. (Vers. 2.1.458.3528 & 2.1.459.3530) Hitting the button > crash with the complete same input the test works fine with 2.0.445.3436 and lower All other functions i used are still working (making h264 mkv from my DVD's) just these test-button seems broken Working under Vista HP SP2 If i can help with anything to let you find the bug, let me know greeting OLP |
12th August 2009, 07:22 | #1789 | Link | ||
HDConvertToX author
when you start encoding, HDC will "split" the vobs in correct episodes, and encode the single episodes when using visualcrop, HDC don't have already splitted dvd in episodes.. so it will show just the main vob. Usually the first as Neuron2 stated (thanks!) DGSource cannot parse m2ts directly. So the analyze function use dss Feed HDC with DGM or DGV and HDC will use DGSource (and btw reuse the update fuction) [QUOTE=IzzyDeadYet;1313643]When I try to convert an mkv file to wmv the program ends with a error result. It demuxes the mkv into a .h264, .avs and .AC3 but then flashes a message "failed with error" but it goes so fast you can't read it before the window closes. There is no record of any failure or error in any of the generated log files. plese see this thread http://forum.doom9.org/showthread.php?t=148700 and remember to install ffdshow tryout and haali and xvid Quote:
moreover launch deinterlacer_test.bat and spot the error BHH
12th August 2009, 08:20 | #1790 | Link | |
the input is standard DVD-Folder (Video-TS) with *.ifo and *.vob, ripped from a DVD without doing anything with the source.
I choose the ifo, then analyse and then try the test > crash Quote:
12th August 2009, 08:29 | #1791 | Link |
Found Issues with newest Version
After converting lots of movies with your great application, I have found two Issues:
1.) Converting a DVD to MKV (copy Audio AC3 german/english, 2pass x264) with given Filesize of 2240MB ends up in a File with 4,5GB, tried it twice - is this a bug? 2.) Converting a MKV 1080p H264 to 720p, with 2 pass x264, fixed Filesize of 4482MB, conversion of two Audio tracks from DTS to AC3 ends up in a file with 4000MB and only one Language? Are these known restrictions or is there a bug? best regards, Daniel |
12th August 2009, 08:39 | #1792 | Link | ||
HDConvertToX author
fixed, use the live update Quote:
BHH
13th August 2009, 18:36 | #1795 | Link |
Hello,
I was just curious to know what other people are experiencing for speed/time to convert Blu Ray to h264. I have a pretty powerful machine Win7 x64, i7 2.66Ghz, 6GB ram…. right now it’s showing ETA 12 hours?! This cant be right? Andy |
13th August 2009, 19:01 | #1798 | Link |
1920x108 source VC-1, DTS Master Audio 5.1
Crop: 20 pixels top and bottom, resized to 1280x688 Video: Xvid to Avi, 2pass, Bitrate: 5591, Quality: 4th tick from right, Xvid Extreme Quality Audio: AC3, 448 5.1 I would like to use x264, but heard you cant mux an AC3 or Audio Copy into mp4 or mkv. Andy |
13th August 2009, 19:11 | #1799 | Link | |
ffx264/ffhevc author
Also, you *can* mux AC3 into mp4 and mkv. Who told you you can't? AC3 is even officially supported by the mp4 container |
13th August 2009, 19:24 | #1800 | Link |
HDConvertToX author
extreme quality isn't so slow
are you using deinterlacer ? xvid bundled is smp ready... also.. vc1 source aren't easy... BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
